Question about Maxtor QuickView 160GB 7,200 RPM Ultra ATA/133 (6B160P0QV) Hard Drive
Re:Maxtor Quickview 160GB hard drive 3 yrs old Makes loud screech sound which gets louder when left on. Doesn't respond when asked to show recorded list,play or record. What might this indicate? Hard drive has been removed from dvr. Could I send it to you to be repaired or to retreive the recordings on an external hard drive?
  • 36 Answers
Maxtor has tools like maxblast or powermax.
try to follow the support link from their site maybe maxtor.com
find download for your series of harddisk, download the tool suitable.
Run the tool to cure possible error, etc ...
Posted on Mar 24, 2011
  • 135 Answers
Seems the problem is on the physical sector of the hard drive. It is bettter for you to sent it to me and I will try to transfer all you data to another hard drive. The hard drive I think its on his way out. PM me if you want my service dicxs_lpt2 at yahoo.com. It will not cost you too much, it will be affordable service.
    Top Expert:
  • Maxtor Master
  • 74,630 Answers
Hello
It is going to be out within no time. If the bios still detects it, retrive the data from it to an other drive as fast as possible. Otherwis you will lost all data. Screech sound is due to its takeup record tip touches the media by anyway. The disc may have got a stron hit, shock etc.OK.
What makes this drive so special?
They are about 200 dollars in value. They are 1/2 terabyte in size.
Apr 29, 2014 | Maxtor 3H500R0-0804P2 QuickView 500 500GB...
How do i reformat (NTFS) my maxtor Basics 160gb external drive to get it back to 160 - it only shows 149gb
it is usual, that you wont be able to access entire 160gb...certain amount of disk space will be reserved in the HDD for boot sector...
Sep 29, 2010 | Maxtor BASICS Personal Storage 3200...
Maxtor 320 GB mini not working
If it shows up as a USB mass storage device it:-
1. Has power
2. It is connected to the computer via USB.
3.The correct software has been loaded for the hard drive.
The beep sound is probably an error message saying that the drive is not responding properly inside the case.
Hard drives Drives have been known to stick or not start up due to power cables or ribbon cables being dislodged. Try pushing these back into place.
If this is not the problem go to the Maxtor site (maxtor.com) and report the problem with the drive, not the USB which appears to functioning correctly.
Mar 07, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
I need to buy one used 300gb maxtor external hard disk
I have it right here; I returned my cable box. What do you want to do? dan_caldwell@yahoo.com.
Mar 25, 2009 | Maxtor OneTouch II 300 GB Hard Drive
Whenever I use my Maxtor Onetouch 3 I have quite a loud whirring noise with it.
This is probably normal, some hard drives are noisier than
others, and the tend to get louder as they get older.
The old Maxtor drives were very loud and quite unreliable,
but I have not tested their new ones.
(once burned, twice shy)
Personally I prefer Seagate. I have 8 Seagate drives in a single
machine including a RAID, and they perform very well.
They are also much quieter than Western digital or Maxtor.
Finally, whirring is OK, grinding is not. If it is louder than
you feel comfortable with, erase is with a secure file wiper,
such BC wipe by Best Crypt, and then take it back to where
you bought it (give them hell)
Also if the drive suddenly got a lot louder than it was before,
this could mean that the spindle bearings are gone and you
need to replace it before you loose all data on it.
Also, if this is used only as a backup drive, as the manufacturer
intended, then you should power it down when you are not using it.
Before turning of the power switch on the drive, though, make
sure that Windows has completed and committed all the
pending write-back cycles. Click on the green arrow on
you task-bar /icon tray: and click "Safely Remove Drive"
windows will then tell you when its safe to turn off the drive.
Hope this helps, please rate my answers.
Martin
Jun 14, 2008 | Computers & Internet
5-yr old Maxtor 160GB fw/usb down
drives dead. Head crash problem.
The read head, has clattered the disk(s)
the only other option is to swap the logic boards over ( if they,re identical ) ** circuit boards on the drives**
Mike @ Compurepair.
Feb 22, 2008 | Maxtor Hard Drive
Candy condenser dryer cdc 266
Forget purchasing anything, i had the same problem. Slide the lid back and spary the belt with WD40..... noise goes and works a treat and no money spent!
Justin
Sep 20, 2007 | Candy CDC266 Dryer
Maxtor QuickView 160GB 7,200 RPM Ultra ATA/133 (6B160P0QV) Hard Drive Logo
116 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
