When i open may computer there is no display on the monitor even if the cpu is running,
  • 36 Answers
You should describe more precisely, which computer it is?
Desktop PC, notebook ?
which brand which series ?
What is the last action you do to your computer.
Posted on Mar 24, 2011
My monitor s19a100n displays slowly when the command is already givento to Pc. What might be the solution for this problem?
That your PC is busy, the display has an offset of somewhere aroung 5 ms for your display. You won't even see more than just a slight blur even in quick movements. Anything above that orgiginates in the computer.
You might have set a bigger resolution for a new monitor, thus increasing the workload for your graphics adapter.
Example:
For a 1024 x 768 resolution, the PC must compute 786,432 pixels. Your display (1366 x 768 pixels) has about 30% more pixels to compute. (for an HD display that number increases to two and a half times as many)
Test:
(presuming, you run windows) start the task manager (right klick the status bar, usually on the bottom of the screen), select task manager and then the tab "performance", where you can see how busy your CPU is and whatamount of ram / swap is used.
Resolution:
Reduce your resolution, get a better graphics adapter, upgrade CPU / ram, decrease background programmes.
Nov 27, 2014 | Computers & Internet
My cpu is not shutting down even i shut down. But my monitor showing shuttingdown and display is turning off as if like the system is shut down Still cpu is running. and also my monitor is not turning on...
Shut down by holding in Power button for 5 secs... press F8 continuously on start up, go into Safe Mode with Networking.. have a look around at some of the Devices in Device Manager, check Drivers, also default to normal mode in Bios/Uefi
Aug 13, 2017 | ASUS M2N-MX Motherboard
Powers on then back off in two seconds...I don't know how to open the case without destroying it..
hello,
Seems that your problem is not your Samsung Monitor. Please check very well. Since this is basically an indication that your CPU is not working that is why there is no display in the monitor and the yellow light turns to orange.
  1. Please try to use another monitor if you still have one that is working well. Then power up your computer and see if there is display on the monitor. If there is, then your reported monitor really has a problem. And if there is no display even in the new working monitor, then the CPU is in frozen state that is why there is no display on the monitor.
May 08, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
When i run cpu but monitor display donot showing
I assume you have already try it with other PC and get the same problem.
Next step will be taking it apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas of what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further, it will also help out other people with the same problem.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 05, 2010 | Samsung 933SN Monitor
My monitor is not responding to anything. what can i do aside from rebooting?
do you see the light blinking in the monitor? I mean the POWER led light up? If so, then the monitor is ok and is working good. It is your CPU which has a problem and not sending digital signal for the monitor to display.
Try to turn off your computer. After 3 minutes turn it back on. then notice if you will hear a short beep from the CPU. That signals a successful video initialization. If you went through that process, then your computer will get back to life.
However, if you dont hear a short beep from the CPU, then definitely your CPU is frozen therefore there is nothing to display to the monitor.
You need to open the CPU case, pull out memory modules then plug them back in. Then try booting.
If not successful, try to open case and pull out the processor. Put it back in after 30 seconds. Try booting again.
Do ALL THESE while your PC is UNPLUGGED.
Good luck.
Oct 09, 2009 | Computers & Internet
L1932TQ Fails on Desktop, works on Notebook
it simply means that your cpu is not giving back signal to your monitor to process, in fact, it is a cpu problem that is why there is nothing to display in your monitor.
Your cpu froze because of that usb thing. the only way to unfreeze it is to manually reset your hardware in this order.
1. RAM modules. If you can unplug your RAM (memory modules) connected in your motherboard, please do it. Just unplug the modules and then plug it back in. if you have 2 rams, then interchange them when plugging it back. this will force your mobo to refresh its resources.
2. CPU. if you can pull out your cpu chip, then do it. this will refresh your cpu setting in your mobo. (mobo = motherboard)
Regards!
Jul 12, 2009 | LG L1932TQ LCD Monitor
Cpu does not connected to monitor
I am guessing that you see lights on your computer, but no display on your monitor.
Have you tried another monitor? If you have and still no display, try unplugging everything from outside the computer except the monitor and then try again.
If no display, unplug power from computer and open the computer. Remove all expansion cards other than the video card. Disconnect all the cables from all of the drives, then connect power and try again.
Let me know if you need more help.
Honest1abe
Feb 25, 2009 | ASUS P5V800-MX Motherboard
DO ANYBODY KNOWS WAT TO DO IF DISPLAY NOT APPEARS
The 280W may not be supportive enough for the computer requirements and is not diverting its power correctly to power the VGA part of the motherboard.
Jan 31, 2009 | Compaq Refurbished 280WATT POWER SUPPLY...
Monitor problem
Hi, sandjkroll, this kind of problem could be because of ur monitor or even because of the on board display  card on ur motherboard. To check ur monitor, u unplg display cable which goes to ur cpu and the power cable which goes to ur cpu.
Them connect the power plug to mains, so no cable from the monitor should go to the CPU. Then u swithch on the the poower suply, and on the monitor. I
If ur monitor displays elongated screen still, and shows signal not found,and no display comes that means ur monitor needs to be send for service. and if there are no elongated screen and says no signal found, ur monitors fine, ur motherboad has a problem
From
Deepak
Sep 28, 2008 | Microsoft ChiMei CMV938D 19" Widescreen...
Philips lcd monitor!!
invest in a better monitor. Philip has never put out a good product.
Nov 14, 2007 | Philips 170B4MG 17" LCD Monitor
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
