Question about Sony Playstation 3 (PS3) Console
Ok my ps3 will read blu ray movies but will not read my games
  • warlock_wu Mar 24, 2011
    woooooooow well ok thanks can i put all my backup things on a cd or do i have to have a flash drive
    Novelist:
  • 102 Answers
Unfortunately a similar issue happened to me as well, and I had to send my PS3 in for repair (hardware issue; the disc drive broke). But maybe what I was told to do will work for you! Here's what I tried.
Easiest solution? Make sure your system is updated. Who knows, maybe it's a firmware thing. Go to XMB > Settings > System Update and run it.
For the next couple of things, you're going to want to backup everything on your PS3. The Backup Utility can be found in the System Settings Menu on the Settings Menu on the XMB menu (XMB > Settings > System Settings). More info on how to backup your information can be found on the Playstation website, found here.
With your data backed up, try the different options in Safe Mode. This link will show you how to access it. Try options 2, 3, 4 and 5, in that order, and see if it's reading discs in between each one. Anything after 2 will delete your data; thus the need to make a backup.
If that doesn't work, either try the online Knowledge Center (but it'll probably tell you do try things I've already outlined here) or send in your PS3 for repair (if it's under warranty, it's free!)
Hope you're able to fix it! Sending it in takes forever; you won't get your PS3 back for a month or two.
Posted on Mar 24, 2011
    soo did that work for you or did you have to send your ps3 off for repair
  • Ed
    Ed Mar 24, 2011
    Mine turned out to be a hardware issue; I ended up having to send it in to Sony.
    Right before I actually sent it in it stopped working all together (wouldn't even eject discs anymore and had to pry out my DVD).
On PS3 80 GB no sound when playing blu ray
I have not personally experienced this problem but reading up on the problem looks like changing the blu ray at 24hz setting (if on turn off and vice versa) resolves the issue. Other than than double check to ensure you are not set up for component in the settings, if that fails may want to replace your HDMI cable as it is not carrying the sound signal as it should.
Jun 29, 2014 | Sony Playstation 3 (PS3) Console
My ps3 slim won't play games and blue ray disk but I can still play eve movies on it, please help want to try an fix if before nhl 12 hits the stores.
Hi, It sounds like there's an error with the laser that reads blu ray media as PS3 games and blu ray movies are both stored on blu ray disks which is read by a different type of laser then a dvd is read by. There's nothing you could do to fix that on your own, the only fix I've heard of is sending it in to Sony.
Aug 29, 2011 | Sony Playstation 3 (PS3) Console
PS3 will play games but not movies
Well if the regular dvd's dont work.. I would recommend you to buy Blu-Ray movies instead.. PS3 is the best known blu-ray player. buy at least one blu-ray movie and try that.
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
My ps3 will not read my disc sometimes and other times it will read it but it will not work
The disc may be quote, "Corrugated", hence the laser is having a hard time following mis ~ aligned structural pattern. Try to use a CD ~ Lens Cleaner. :)
Apr 02, 2010 | Sony Playstation 3 (PS3) Console
My ps3 will still play movies but not games, what may b the prob?
You probably need a blu-ray drive. A blu-ray drive is essentially three parts, a CD type player, A DVD type player and a Blu-ray type player. Any one or combination can fail. DVD type games may work but not Blu-ray movies. Blu-ray games OK but not DVDs, etc. a blu-ray drive needs alignment so this is a sevice shop issue.
Mar 22, 2010 | Sony Playstation 3 (PS3) Console
My ps3 turns on and off ok, plays movies off the hard drive and will play ps3 games but has suddenly stopped playing movies ( dvd & blu ray ) it recognises the disc and goes to play it but the screen...
That is actually a poor conclusion. There are three different lasers, one for blu-ray, one DVD and one for CD games all in one holder inside. It certainly CAN be the laser. The description id the DVD/Blu-ray part is having focus problems. Contact Sony for a service center that can install a new drive (It needs to be calibrated on install)
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
My PS3 will play PS3 games sometimes. It quit
sounds like a dead Laser they are a dual laser will read DVDs n CDs but wont read Blueray movies or PS3 games Laser might need replacing
Oct 19, 2009 | Sony Playstation 3 (PS3) Console
Ps3 not reading discs!
what is wrong is when you got the blue ray set up it was probly set up diff.if it is not reading games or movies then you eye is scrached.the eye if u dont know is what reads everything
May 27, 2009 | Sony Playstation 3 (PS3) Console
Isnt reading games
it Depends on the model but usually this happens because of dust or dirt on the lens so a cleaner may help. although if that doesn't work it means the laser has gone bad, which is a common problem with ps3's. Some newer models of ps3 have dual lasers so if the blu-ray laser fails you wont be able to play blu -ray disc (games, movies) but the other laser will still read dvds (non blu ray) and cds
Apr 20, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
97 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
