Question about Fisher and Paykel Washing Machines
I have a gw509au 5.5kg smart drive washing machine. it is not pumping water in properly and starts beeping and 2 green, orange and red lights come on. any suggestion on whats gone wrong
SOURCE: F & P Smart Drive Model MW0I5K - BEEPING
If the washer is also filling slowly it's likely to be the hot or cold water solenoid (either one or both - not that an expensive a repair)
Posted on Jul 26, 2008
SOURCE: Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Posted on Dec 16, 2008
SOURCE: error code 131
http://www.docstoc.com/docs/25379715/Fisher-_-Paykel-Washer-Diagnostic-Fault-Codes/
A;; fault codes above.
Posted on Apr 08, 2010
  • 14 Answers
SOURCE: fisher and paykel washing machine stopped
If the light that stays on when beeping is 7th from the right then the machine has a pressure transducer which is out of range, the motor controller module (electronic) will need to be replaced.
Posted on Apr 22, 2010
  • 251 Answers
SOURCE: my fisher & paykel smart drive excellence 7.5
Although slightly unclear these are the only possible error combinations for the leds on the machine as you look at it with red always on the end right hand side.
(11) 1011 (Green - nil - Orange - Red) - pressure problems perhaps a blockage in the tube to bowl.
(13) 1101 (Green-Orange-nil-Red) - pump is faulty
(15) 1111 (all lights on) - display module is faulty
I do not recall that the leds across the spin speed actually means something.
Good luck
Posted on Jun 08, 2011
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
My fisher & paykel smart drive excellence 7.5 washing machine squirts water in a few times and then stops and beeps and displays 3 lights red orange and (short wash) green as well as low and med speed...
Good luck
Jun 06, 2011 | Fisher and Paykel Washing Machines
My Kelvinator pride 5.5 Smart drive 8 washing machine started beeping. It had one green light and one red light error message. I tried to get it to start, and it just hums. I removed all the clothing and...
I would remove the water outlet pipe and lay it as flat as possible to drain the remaining water out you will be amazed how much water there is left in the machine
the humming will be the inlet water valve or the motor trying to start when you have the door open try turning the drum by hand to see if it turns easily eric
Dec 26, 2017 | Fisher and Paykel Washing Machines
Machine stops and the following lights (in UPPER CASE) are lit with a beeps sound: Green, Green, GREEN, Green, GREEN, Orange, ORANGE, RED
Hi just read your posting.Now when the machine stops and beeps a series of lights will light up.They will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine stops and beeps,Is it the 1st and 4th or the 3rd and 6th ---etc---?Also please supply the model number of your machine which is on a sticker on the back of your machine, top left.Looking forward to your reply.
Sep 26, 2010 | Fisher and Paykel Washing Machines
I have a Fisher & Paykel Smart Drive 9 Excellence 7.5 GW709 washing machine and when turned on it tries to pump water into the machine a few times but then stops and i get an error code X000000XX...
Hi just read your posting.From the information in your posting the error on your machine is called, Repetitive Rotor Sensor Error.This means that the most likely cause of the fault is the Rotor Sensor.This component is located underneath your machine attached to the motor.The other 2 reasons that this fault is occurring is faulty wiring to the rotor sensor or a faulty control module.To test the rotor sensor unfortunately you need an RPS TESTER.But if you have an electrical test meter I can help you test the wiring to the rotor sensor.Please reply and let me know how you would like to proceed and I will help you as much as I can.
Aug 24, 2010 | Washing Machines
Have kelvinator smart drive 503, water won't run
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
Jun 16, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Apr 14, 2009 | Washing Machines
FP GLW10spins but clothes are still wet and lights/beeping are on
Most likely your filter is blocked, check out where this is and clean out well. Second there could be block in your exit pump preventing the water from being pumped out. If possible call or see your dealer for help, but you could do the thing yourself. You can click on troubleshooting above in blue. There should be several solutions for your model. The washing machine companies do not tell you how to do these things, so they can send in their techs to make more money.
For new buyers - ASK WHERE THE FILTER IS, WHAT ARE THE VARIOUS CODES, SERVICE. Where is the tech sheet?
Feb 26, 2009 | Fisher and Paykel Fisher & Paykel Washer
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
54 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
