Question about Ridgid Wts2000l 10" Wet Tile/stone Saw Cash Saver Lk
My ridgid wts dont runs when the switch is on but the water pump does. what can i do
3 Suggested Answers
SOURCE: ridgid tile saw wts
I cut mine off!! then put a normal plug on it. Works great.
Posted on Oct 23, 2010
  • 354 Answers
SOURCE: need to buy a switch
You need the guts of the switch not the entire switch and he guts csan be foud at the shack or an appliance store
Posted on Feb 16, 2011
Need to rewire a sump pump
If sump pump is under water, I would buy new one.
There is no certain method to ensure that wiring is sealed, and that electricity will not flow live.
Apr 12, 2013 | Ridgid 85937 SP-500 1/2 HP Submersible...
Ridgid mobil airpressure switch trouble
This condition will occur when the in-tank check valve is stuck open. Pressure from the tank increases load on the motor by flooding the pump with tank pressure not allowing motor to start thus reset opens. Easy test. Run compressor for one minute then unplug cord from wall. Remove hose at the check valve and test for leak with soapy water. If leaking remove valve and attempt cleaning or replace with generic valve. Cost about $20. Good luck.
Sep 08, 2012 | Ridgid Compressor With Toolbox On Top
The vertical float switch won't trigger when the water levels exceed extreme water levels
Sounds like the switch is faulty. You have to get the model of the pump and get a switch at a electrical repair center.
Mar 19, 2011 | Ridgid 85942 SP-330 1/3 HP Submersible...
How do you overhaul a submersible sump pump when it runs too often and takes a long time to shut off?
in most cases that is the switch that is attached to the pump you can buy a new one at home depo about 35.00 dollars that will make the sump go on and off properly
Mar 08, 2010 | Ridgid 85942 SP-330 1/3 HP Submersible...
Ridgid Wet Tile saw water pump operates, however the water is not getting directed onto the blade. Hose partially plugged? How to clean nozzle?
You could clean the hose ... however, I think Id get to the hardware store and get a new piece.
Clean the end with a broom straw. You could trim a small piece of the hose off. Dont neglect to clean the filter on the pump. Slide the bottomoff the pump to expose the filter.
Oct 21, 2009 | D Cut CS-070 Wet Tile Saw
Ridgid Wts2000l 10" Wet Tile/stone Saw Cash Saver Lk Logo
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
