Question about Keurig Elite B40 Coffee Maker
I turn the power on and after a short time it automatically shuts off (but the auto shut off light is not lit). Also, the heating light does not light and the small cup light does not flash. (The add water light is working). Can you help me?
  • Keurig Master
  • 12,061 Answers
Hi, well what happens usually is the little thermistor goes open circuit, and this then stops the heating element. It's part of the thermostat controller.
Sometimes it is the thermal fuse, again inside, this is a device that if overheated it goes open circuit and cut off power to the element.
If one is repair inclined then replacement of these things are not too difficult, however, one needs to be able to order spare parts, and to do this one needs the all important parts numbers, usually only available from a service manual, or a repairer.
so unfortunately like with a few things that i see in my shop these days it is most likely an uneconomic repair?
The cheapest and best way to sort this out, is to get the unit looked at by a professional, however before just giving the go-ahead to repair it, please ask for a "Quote", this way at least you will know what's what.
Posted on Mar 24, 2011
Premature shutting off
Have you try with lower heat setting?
It seems like it might be thermostat or thermal fuse that is not working properly.
Apr 21, 2008 | Rowenta Effective DX1700 Iron with Auto...
Kholer power systems generators 18RESL auto shut down code UU
UU is generator under voltage. Check to see if it does it without laod also. if it does you will need a pro to check and ohm the rotor and stator for shorts
Jul 11, 2012 | Kohler Electrical Supplies
Head light problems sometimes they will not shut off sometimes they (low beams) come on by themself high beam will not shut off
Are you sure there not running in daytime running light, when you think high beams are on
Also, there is sensor on the dash, usally on the speaker grate, that senses night and day. In the daytime your headlights will automatically come on when your car is in drive, and be on the high beam bulb, but dimmer than regular. At night, or in low light conditions, your lights will automatically switch from daytime lights to regular low beams. And yes, even when your switch on the dashis turned off, your lights work automatically.
To turn of the auto setting, just push the override button for your dome light, in and out 3 times, you should hear a chime, and your lights should shut off. This setting resets everytime you shut your vehicle off. Or to turn the auto setting back on, push the over ride button 3 more times.
Apr 15, 2011 | 2002 Chevrolet TrailBlazer
Maytag LDG7400 gas dryer does not stay lit long enough to heat the drum. Can see flame turn on for about 10 seconds then back off for 20 to 30 seconds. Continues cycle of on and off until end of time....
Light sensors detect when burners are lit. If they become blocked with lint, dust, etc., they will not detect the flame and, for safety purposes, automatically shut off the gas flow.
Dust and lint are a dryer's worst enemy. Be sure that all sensing devices (particularly optical sensors) are clear of dust and lint so that light can pass unobstructed into the lens.
If they sensors are all clean, they might be defective. Something is erroneously telling your dryer's control that the burners are not lit and thus the gas supply is shut down.
Jan 01, 2010 | Maytag Dryers
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Automatic drying doesn't shut off
its the switch problem its got tripped internally so its not getting shut off.if the switch would have tripped to the opposite side that the dryer would have nit turned ON. so the switch needs to be opened the tripper needs to be replaced.easy job but very technical. thanks
Feb 26, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Heater will not stay lit on auto procom ml 300 blue flame
If you have an ML300HGA, it is a manual-control heater, which means you turn it on and you turn it off. No thermostat. It does not have an AUTO setting.
Likewise, the thermostat-controlled models do not have a Manual mode. If you have the ML300TBA, it has a thermostat and will turn itself on/off in order to maintain a room temperature.
On manual models, the numbers (if any) on the dial are heat output selections. Set the control to the highest heat setting and that's what it does until you turn it off.
On automatic thermostat models, the numbers on the dial are temperature selections. Set the control to the highest heat setting and the heater will continue running until it is 85-90 degrees, then shut off. Set it around 2 and it will maintain a temp of around 70 degrees.
All Procom heaters are either automatic (thermostat-controlled) or Manual. None are both.
Oct 05, 2008 | Procom ML300HGA Heater
Keurig Elite B40 Coffee Maker Logo
117 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
