Hi, I am using IBM E74 black color monitor. Frequently Monitor settings menu keeps popping up. This popup will remain on the screen even after pressing the Exit button on the monitor. Please let me know what can be done to resolve this problem.
  • 36 Answers
If the monitor setting menu is from the Operating System (windows xp the like ...)
then this can be that your system is not that clean, try some clean up program
(like ccleaner from ccleaner.com) and also run antivirus full scan of your system
might helps. Try cnet.com, there u can find many tools or antivirus to download.
If the popout is from the monitor it self. then you might try to check the cables
connecting the your monitor to CPU also the power cord. sometime lack of power
can badly affect the monitor or even damage it.
Hope that helps.
Posted on Mar 24, 2011
Color problem
Hi, it is more likely from an open green and/or blue picture tube's electron gun transistor driver.
If you have an experience on electronics / or use of solder gun, you can just open your monitor and look for the electronic board at the back of the picture tube. Take a look in all transistor ( components with three legs) and solder / check if their legs are not fully soldered to the board. Note: just be careful on the high voltage diode / line ( the one with a thick (like the car distribution wire cable) single wire going to the tube). good luck
Dec 19, 2008 | IBM E74 17" CRT Monitor
Monitor Menu Poping up again & again
1. First U can change Microswitches on front pannle (Menu,select,+,-)
2.check dry points in MICOM&EEPROM IC,HV IC and It's related.
3.check 5V supply and replace 5V Regulator.
Oct 05, 2008 | IBM E74 17" CRT Monitor
Automatic popping up of the monitor menu
i hav got fed up of this problem in my ibm e74 17'' crt monitor......isnt there any solution other thn replacing the transistors & diode coz its a very diffficult option......plzz help me if u can.....thanx
Jun 11, 2008 | IBM E74 17" CRT Monitor
Blank screen (led indicator is orange)
it could be the cable from the monitor to the pc it is defactive try a new one cuz if the monitor works then it is the cable that is makeing your screen go blank
Oct 10, 2007 | IBM E74 17" CRT Monitor
Crt computer monitor model 6332-03n
Hi, you can try lowering the screen resolution, the color quality and the screen refresh rates. Work from there and observe each setting/increment. soon as the monitor quits, press escape to revert to previous setting. I get the impression that you are familiar with electronics, the problem is your monitor horz. freq is playing catch up and eventually fails. Lowering your PC setting then might do the trick. To lower the settings, right click on desktop, properties, settings tab & advance button - Monitor. Hope this be of some help. Good luck
Apr 24, 2007 | IBM E74 17" CRT Monitor
Won't turn off and cylces through colors
Hi. This evening, I had the exactly the same symptom. I found a way to fix it.
When you power up the screen, keep the power and auto buttons both pressed. That seems to reset the screen. After that when you open the menu, a small F appears on the left side of the contrast icon. Go to that red F with the arrows and press menu. Another menu will popup. Choose 'Burnin' and set it to off. That's all !
Note: do not try to change other settings, they depends of the harware...
Apr 30, 2007 | Acer AL1715 17" LCD Monitor
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
