Question about ASUS Computers & Internet
I have a m4a88td-m usb3, and after running for two days it detected a power surge in my new power supply. Now it will not read the Sata ports for the hard drive or the cd-rom. What do I do?
  • ASUS Master
  • 27,725 Answers
Since you had a power surge i would be checking or replacing the leads
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Posted on Mar 24, 2011
  • 135 Answers
You have to update the ACPI driver for your motherboard.
Hp simplesave not recognized xp
Unfortunately XP is no longer supported. You could try reinstalling the OS from your CD.
Jul 31, 2017 | HEWLETT-PACKARD Hewlett Packard HP...
Work around for USB Device Software for Compaq nx6110, Windows xp SP 3. my laptop some times refuse to detect and read the USB devices like : flash disk, external hard disk, modem,... it use to write that...
first off why run XP the Virus magnet?,Microsoft and hp dropped
support on this 3 years ago,,
not only that XP does not support most USB devices.
sure some old devices, but not new ones. (unless maker says otherwise and offers software to run on XP)
you are direct connected. to USB to external HDD.
That external disk, my guess has no external supply right?
that means it will overload many Latptops
the power spec, on USB varies, by different ports used and maker of the laptop...
I solve that horror by only buying external HDD what have wall power pack connected, mine is 12vdc 2amps, and will work on any PC made , ANY !
it uses its own power, so never overloads that weak PCs USB port.
here is the USB spec from WIKI page "USB" 0.5amps is gutless.
  • 0.5 A (USB 2.0)<<<<<<<<<<<<<<<<<
  • 0.9 A (USB 3.0)
  • 5 A (BC 1.2)
  • 3 A (type-C)
  • Up to 5 A (PD)
0.5 amps that is, 500mA, about 1/2 what hdd needs. to be happy.
yours is the first one, the weakest they made.
that is not enough current to spin up any HDD, from dead start.
cures: (all)
  1. get an external SSD drive,
  2. use and external case on external drive with its own powerpack
  3. buy and an EXTERNAL USB powered hub that is USB3 rated and it might run your drive connected to it.
  4. get newer laptop, one with USB 3 and runs w7 or newer.
Jun 27, 2017 | HP Computers & Internet
M4a88td-v evo/usb3 5 minute boot
Try resetting the BIOS to defaults. This will clear any custom settings, so make sure you are comfortable doing so.
Nov 28, 2012 | ASUS Motherboard M4A88TD-V EVO/USB3 AM3...
How to add a second hard drive to a tower pc
I'll state basic information, and also more detailed info using an Asus M4A88TD motherboard;
The Asus M4A88TD-V EVO motherboard, with USB 3.0 technology, and an AMD AM3 processor socket,
[Plus the motherboard chipset is an AMD 880G - Northbridge chip, and AMD SB850 - Southbridge chip,
http://en.wikipedia.org/wiki/Comparison_of_AMD_chipsets#A-Link_Express_III ]
Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131646
Under the main view photo at the top left; there are 4 views shown underneath. Click on the third view from the Left. Shows a top view of the motherboard.
Now it is the main view. Click on the main view to enlarge it.
See the 5 blue SATA connectors under the Blue and Black ram memory slots? Red line points to them, and subheading states;
SATA connectors; 6Gbps
IF you are going to add a SATA harddrive as a Secondary harddrive, use one that is open. (Nothing plugged into it)
Which one? Does NOT matter.
The beauty of SATA is, that you can plug into any one of those SATA connectors, and BIOS will find the device that is plugged into it.
(SATA 1 connector is usually reserved for the Primary harddrive, though. The one with the Windows operating system on it.
[Windows XP, Windows Vista, Windows 7, etc )
This is a general example of a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Note that it's connector is longer, than a SATA data cable's connector.
It has 15-pins.
General example of a SATA data cable,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Looking at the connector for the SATA data cable at the top, note the L-shaped opening.
Looking at the SATA connector for a motherboard, shown on the bottom, note the L-shape where the SATA data cable plugs in.
The SATA power cable has the same L-shaped opening.
Only plugs in one way.
Caution!
IF, the SATA harddrive you are going to use, has a provision for a SATA power cable, AND a 4-pin Peripheral power cable, ONLY use just a SATA power cable!
Why?
Because you will burn the SATA harddrive up! Maybe not right away, but I assure you down the road it will.
(Also know erroneously as a Molex power cable.
Molex was the first manufacturer of that type of power cable connector.
Name kind of stuck. Just like calling an adjustable open-end wrench, a Crescent wrench ),
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
A) Computer unplugged from power, computer case open, FOLLOW Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
B) Plug the SATA data cable into the motherboard. Bring the SATA harddrive closer to the computer case, and plug an unused SATA power cable into it.
Find a slot in the metal harddrive bay, that you can slide it into.
Install the screws in the side, if the harddrive bay is of this type.
Otherwise there will be plastic clips on the side of the slot.
That's it.
Close the computer case, plug the computer back into power.
WAIT 1 minute, turn the computer on.
General example shown in 3 videos,
1) http://www.youtube.com/watch?v=kCgFYNLzn18
2) http://www.youtube.com/watch?v=OmTyu8jAfDg
3) http://www.youtube.com/watch?v=3a9n7G4q30M&feature=fvwrel
That Asus motherboard also has one IDE connector. (IDE/PATA)
[40-pin connector, Blue, and below the round CMOS battery ]
More than likely if there is a device plugged into it, it would be an optical drive. (CD/DVD drive)
I would Not plug an IDE harddrive, and an optical drive (CD/DVD drive), on that same flat ribbon IDE cable.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 03, 2012 | ASUS Motherboard M4A88TD-V EVO/USB3 AM3...
I purchased a ASUS M4A88TD-V EVO motherboard and a AMD Phenom II X4 955 Black Edition.... i have everything plugged right and its not getting any bower, it's a 480W... Do i need more?
Hi
The Power Supply Unit might either be faulty or under-powered, or their might be another cause.
Eliminate the posibilities one-by-one.
Remove the motherboard and make sure there are no misaligned mounting points or loose screws under the motherboard, shorting the solder points under the motherboard when you switch the power on.
Reinstall the motherboard carefully, making sure the Power Sopply Unit connector is fitted correctly and fully pressed into its socket. If it is a 2 part connector 20 + 4 pins, make sure the 2 part fit together in the correct orientation.
Make sure the Front Panel Control Header Pins are fitted in the correct orientation.
Make sure the CPU and Heatsink are fitted correctly.
Make sure the CPU fan is connected.
Make sure the RAM is properly in the RAM slots.
Make sure the Graphics Card and any other PCI cards are properly in their slots.
Connect only the CPU Power Cable, the Hard Drive power cable and any Graphics card power cable (if you have a separate Graphics Card and it has a power connector) and, leaving the computer open and flat on the floor so you can see all parts inside, test the computer again.
If it works, shut the computer down, add the CD/DVD drive power cable, and then the case fans, testing as you add each extra device.
Upgrade to a 650W PSU if you experience any failure or slow spinning of fans.
Afre installing the new PSU, clear the BIOS by disconnecting the power cable and removing the small, silver CMOS battery for 2 minutes and then reinstalling it and then restarting the computer.
If none of this works, then the Motherbard might either have a BIOS corruption or a power management fault and should be returned to the supplier under warranty for like-for-like or higher specification replacement or a full refund.
If this answer helps you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and helps us explore the best ways to provide useful, high quality answers.
If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa.
Aug 30, 2011 | ASUS Motherboard M4A88TD-V EVO/USB3 AM3...
NO SCREEN RED LIGHT IS FLASHING
Test the PSU if the units fan is not working the power supply unit is faulty
if you are having trouble with your graphics card
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket hope this helps
May 20, 2011 | ASUS Motherboard M4A88TD-M/USB3 AMD AM3...
Asus M4A88TD-V EVO/USB3 BIOS: 1702 AMD Phenom II X4 955 PSU Ultra 500watt ATX RAM Patriot DDR3 1600Mhz 2x4Gb Mobo will not POST, no beeps, fans turn for one second and stop. Mobo replaced with same,...
So you changed everything except 1 thing, power supply. Try another power supply or power suply cord.
If it doesn't work, try another graphic card, maybe there is some shor circuit.
May 07, 2011 | ASUS Motherboard M4A88TD-V EVO/USB3 AM3...
Amd athlon ii x3 450 best compitible mother board
asus makes the Best mainboards in my opinion, All AM3 boards. You get what you pay for so it's worth spending a bit more to get a good mainboard.
Example: ASUS M4A88TD-V EVO/USB3 is a really good option, however I myself would pair this mainboard with a AMD Phenom 2. Though your X3 450 will work well in this mainboard too.
The best compatible mainboard would be the ASUS Crosshair IV Formula or Extreme edtion, however your CPU will be a bottle neck in the system.
The ASUS M4A88TD-V EVO/USB3 is really good looking and it performs really well too.
You could go for an ASUS 785/790/870/880/890 North Bridge chipset AM3 Socket.
You could even purchase an AM3+ mainboard that will support AMD's new Phenom module CPU's.
Go to www.asus.com and check out the AMD mainboard range that they produce.
Take care!
damnor01
Feb 11, 2011 | AMD Athlon II X3 450 / 3.2 GHz processor
I CANNOT LOAD WIN7 I cannot get my system to boot from a CD disk (Win 7 Ultimate) I set the BIOS to boot from a CD device - the priority is set for CD first. All other values are default. In...
try to reset bios if does't work try using a usb dvd drive (external dvd drive) remember you do not will be able to read a dvd CD(WINDOWS 7 CD) using a cd burner.
you will need a dvd drive.
Feb 07, 2011 | ASUS Computers & Internet
Computers & Internet Logo
55 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
