Question about Garmin nuvi 200W GPS Receiver
My Garmin nuvi can not find satellite or displays lost satellite message
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
I also own a Garmin, the only time I get that message is when I am driving through a tunnel or there is lot of cover over head like trees. Also if your in a big city by that I mean the down town area and your surrounded by tall buildings you may get that message intermittently because the Garmin may loose the satellite signal.
Garmins don't run off one satellite usually its a minimum of 3 or more. The problem your experiencing is a common one and not to worry Im sure it happens to all GPS units when the signal is blocked to them.
I hope this helps you out if it does please leave me some feed back.
Posted on Apr 02, 2011
Ive been getting the message ''acquiring satellites'' since yesterday morning
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Dec 02, 2009 | Garmin nuvi 200W GPS Receiver
Acquiring satellites
The problem might be that your GPS is not able to connect to the satellite.
I'll see what the problem might be.
Mar 15, 2008 | Garmin nuvi 350 GPS Receiver
Lost satellite connection
Please see this link for more information on this problem. Too much info to cover here:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Aug 05, 2009 | Garmin Nuvi 660 GPS Receiver
My Garmin Nuvi 360 lost satellites during use and can't locate
I had the same problem with mine...I shut it down and left it off while giving it a full charge...
Jan 14, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
Garmin NUVI 660 - can not locate satellite
Please read this solution, which might help you. On the 660, you press and hold the upper-left hand corner of the screen while turning on.
http://www.fixya.com/support/t1155473-garmin_nuvi_660_not_locate_sattelites
- Jim
Nov 06, 2008 | Garmin Quest 2 GPS Receiver
Lost maps in garmin nuvi 200
Form Message You need to have Garmin Tech support send you this attachment; "gmapprom.unl" Then follow the instructions below.
1.) Save the attachment from our message to the desktop
2.) Right-click the file gmapprom.unl, and click copy
3.) Click on My computer
4.) Click on the Garmin Nuvi drive
5.) Click on the Garmin Folder
6.) Rightclick a blank white space in this Garmin folder
7.) Click Paste, and note gmapprom.unl file is listed, please also delete gmapsupp.img if present
8.) Unplug the device, and allow to start up
Nov 04, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin 680 -cannot acquire satellites
If a factory reset does not work, your antenna will need to be replaced.
- Jim
Oct 28, 2008 | Garmin Nuvi 660 GPS Receiver
Unable to acquire satellites
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} My Gamin Nuvi 660 Solution
External antenna - Garmin 25MCX low profile remote GPS antenna
I have been experiencing the same problem many have been having with the Nuvi 6xx and 3xx series giving an error message “Lost satellite reception”.
My problem started mid April 2008 and got progressively worse. I would use my GPS on weekends and it would work perfectly for the first 10 – 30 minutes and then would loose satellite reception, rendering it useless.
I bought my Nuvi 660 when it first came out in October 2006 for just under $700 and is now out of the 1 year warrantee.
I called Garmin Technical Support and we checked my Software version (4.40) and more importantly my GPS SW version (3.00). According to the tech I had on the phone, the GPS SW version was more important then the Software version. It was in fact already updated to 3.00, I did master reset, after master reset, but regardless, nothing helped.
I contemplated what I should do.
Return mine and get a refurbished unit from Garmin for $225 with only a 90 day warrantee?
Buy a new Nuvi 660 for around $300
Buy a new Nuvi 2xx series with fewer features for $200 to $275.
Buy a Megellian GPS?
I read through this forum and came across one person that was told by Garmin “that they are aware of an issue with some Nuvis involving the failure of a diode in the unit that senses whether or not an external antenna is connected.” Apparently this diode failure is caused from the high heat these units experience from being left in a hot car for long periods of time. This would explain why mine would work in the beginning and then die.
So my thinking was, if the diode “thinks” there is an external antenna attached when it isn’t, what would happen if I “did” connect an external antenna?
Garmin recommends the Garmin GA 25MCX low profile remote GPS antenna for the Nuvi 660 and costs $31.49 (not sure about additional costs for tax and shipping)
So I purchased the NEW antenna from a seller on eBay for $25.90 total and IT WORK FLAWLESSLY.
Just to make sure it really was the new external antenna that was working and not the unit coming back to life, I started my 3 hour journey with the external antenna NOT connected. As usual it lost satellite reception in about 15 minutes. I plugged in the GA 25MCX and it immediately connected to the satellites and never lost them.
I repeated the same process coming home and once again, I connecting the external antenna after the unit reported loosing satellite reception, and it worked perfectly.
Conclusion: if your unit is experiencing loosing satellite reception, and is under warrantee, return it ASAP. If it’s out of warrantee, get an external antenna. There are other manufactures of external antennas and all should work as long as it has an MCX connector.
Side Note: This external antenna also worked perfectly on a friend’s Nuvi 350 with the same problem.
I wanted to share this with everyone because I’ve been racking my brain for months over this. I hope this helps.
May 04, 2008 | GPS
Nuvi 660 not locating satellites
Try this and see if it fixes your problem...first disable bluetooth then follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Dec 25, 2007 | Garmin 010-00358-00 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
234 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
