Question about Dryers
Can the dryer condeser tank be connected to the waste pipe to drain automatically
    Genius:
  • 1,400 Answers
Hello
Yes it can, but you need to install a p trap so you dont get a bad smell from the waste pipe.
Posted on Mar 24, 2011
Where to drain the bad gas from I mixed it with diesel
There is NO drain on the tank bottom.....Disconnecting fuel line/add extension if/as needed,place hose/extension in aux fuel tank,add 'Modis',request fuel pump 'on' & drain tank.....Add fresh fuel,replace fuel filter & ad fuel injector cleaner (Preferably Lucas #10020) & PROPERLY dispose of waste fuel.
May 01, 2015 | 2006 Nissan Maxima
How to connect drain pipe
There is a great video on youtube for installing a dishwasher, How To Install Dishwasher Plumbing - Replacing a Dishwasher
http://www.youtube.com/watch?v=gIr8avJFrKw
Hope this helps you.
Dec 16, 2013 | Dishwashers
Does anyone know how a septic tank works?
Take a look at this good YouTube video so you can see how a septic tank works;
http://www.youtube.com/watch?v=uuORuwb4cfs
Jan 28, 2013 | Plumbing
Water is draining continously from tank
its over filling its the soilnoid valve letting by u will need to replace it
Aug 26, 2012 | Electrolux Washing Machines
AEG 73630: wont take water in, cant pump water out, when choosing a program the timer seems to have changed minutes with seconds, and when choosing af program, the only thing happening is, af few spins...
The machine knows what the water level should be at every step of the program, so if its full when it should be empty, is not filling when it should be or is taking too long to fill or empty the program will abort and count down in seconds as you describe.
First - check the drain filter for blockage!! if clear, can you hear the drain pump running on 'drain' program? a chug chug chug noise. If not pump may be jammed or seized - or the drain tube maybe be blocked at the waste connection on the sink, etc. Or maybe the water supply pipes have blocked or got turned off? Possibly the waste pipe may not have been installed correctly and the machine is syphoning empty? ie the end of the waste pipe is lower than the water level in the machine - so it syphons empty like draining petrol from a petrol tank! That would empty the machine when it should be full.
Check all the basics of filling, draining and filter before suspecting anything else.
Feb 01, 2018 | AEG Washing Machines
There was a puddle of water coming from underneath the refrigerator. what would cause this problem
This is due to condesation water overflowing from the defrost collection tank which is normally located on the bottom of the fridge and above the compressor.
Normally sometimes if the fridge was set to lower temperature the defrosted water will be more than normal. So set the fridge to normal settings and check after draining the tank if the fault recurs.
If so check if the drain pipe from the evaporator collection tray is damaged.
Aug 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I drain down the tank on a ford transit connect where is the tank
I take it you mean the gas tank, follow the filler pipe down and it will lead to the tank. To drain the tank remove the fuel pump of it is located in the tank andsyphon the fuel out there, if the pmp is inaccesable find a fuel supply pipe in the engine compartment and draw the fuel out of there. It is usually inpossible to gain access to the tank through the filler point. Another possibility is to disconnect one of the breather pipes and draw the fuel out of there.
Jan 16, 2011 | 2010 Ford Transit Connect
AEG Lavamat 16830 washer dryer
can anyone tell me how to remove the rear panel of a AEG lavamat dryer. regards Roy
Jul 20, 2008 | Washing Machines
Hotpoint dishwasher
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Feb 14, 2008 | Dishwashers
Kenmore washer drains too fast
Unfortunately the only way to restrict the flow directly would almost certainly cause the machine to malfunction, as the drain pump and valve system is not designed to deal with significant downstream pressure. The only way I can think of would be to install a small tank (a jerrycan or similar may be ideal) that will take a full load's worth of waste water. Connect the tank to the washer, and ensure there is an air-hole/breather at the top. Fit a pipe low down in the tank through a normal (ball-valve type ideally) tap, and open that tap just enough for the new tank to drain slowly into your drain system. (some camping shop type water cans may already be fitted with a tap that may be suitable). The height of the tank would be the only thing you would have to be careful with, as the bottom drain would have to be above the outlet drain pipe, and the top inlet from the washer would have to be below the maximum level permissible (usually described in the leaflet with the washer, normally only a few inches/centimetres above the top of the washer is the maximum recommended, sometimes just below the top of the washer). Get a plumber to check for blockage in the drain line, as the amount of waste water from one of these machines should rarely be too much for a properly functioning drain unless the pipe from the machine to the main drain is too small or blocked, or the main drain is at least partially blocked. If you wish to go with my first idea, then I am more than happy to supply rough drawings of what would be needed, and I would not expect parts to cost too much - only issue would be if you had the space to put a small tank, and that you would have to ensure the tank was empty each time before starting a new load. An alternative solution would be to lead the waste from your washer into a garden water storage tank, checking first if the detergents you use are harmful to plants or the environment generally (many are not and plants sometimes thrive on this sort of water) - you can then water your plants for free and solve the drain issue. Obviously having some sort of garden is a pre-requisite for this, but it could be a good solution if this is the case. Please check local environmental regulations before discharging anything about which you are unsure, as fines can be quite steep. I believe a plumber should be your first port of call to check the drains.
Feb 12, 2007 | Kenmore 80754 Top Load Stacked Washer /...
Dryers Logo
Top Dryers Experts
