Question about Edu-Science (10166) Telescope
View finder displays are upsidedown - Edu-Science (10166) Telescope
  • 3 Answers
Telescopes generally will display images upside-down, due to the way the image is magnified. On many telescopes, the eyepiece is removable, and can be exchanged with many different attachments and lenses. One of which being an image rectifier (or image flipper), which flips the image back to normal. Unfortunately these lenses can be pretty expensive, and will reduce the amount of light being passed through the telescope due to the addition of more lenses, so are only primarily used for day terrestrial viewing. Hope this helps.
Posted on Mar 24, 2011
Cant see through my view finder on powershot s3 is
Your camera has an electronic view finder. To switch between the view finder and the display, you have to press the DISP. button several times and look what happens in Shooting mode and what in Playback mode. If only the display will come on, and the viewfinder stays black the camera will have a defect. If you can't use the camera anymore, because you only can shoot with the viewfinder, consider buying a new camera, because any repair will be more expensive than a new camera with the same quality.
Jan 19, 2014 | Canon PowerShot Cameras
Off lens,view finder is not workink
The view finder is the little window on the top left of the camera. If you want to use the display as a view finder, you have to press the button with the camera logo. It is called the life view mode. you use the same button to switch off the display. Be aware using the display, will drain the batteries quicker. Somewhat faster then with modern cameras.
see page 19 of the manual.
Dec 02, 2013 | HP Photosmart M307 Digital Camera
There is a line appearing from the center of the view finder till the end. This comes on only when the camera is switched on
if the line came in photos when you seen them from PC then its a Camera CCD fault, Or If the photo clear in PC view then its a LCD fault.
Aug 04, 2012 | Nikon D70S Digital Camera with AF 28-80mm...
Turn on camera..view finder and/or display screen
The s7000 has three different display modes: Screen, viewfinder, and off. Screen is for looking at the big screen, viewfinder is for looking through the digital viewfinder, and off should turn off all the displays. Try pressing the DISP button once. That should reactivate the screen and make it possible to use the camera again.
Jul 25, 2010 | Fuji FinePix S7000 Digital Camera
View Finder Problem on Sony HDR FX1E
Hello Sir,
Well this sound like the shutter may be trapped, either by a knock or heat on the system, maybe you could take it to camera shop and let them see.
May 27, 2010 | Sony HDR-FX1000 Mini DV Camcorder
Query Regarding No Display on LCD (view finder) in Canon Digital IXUS 750
With the camera on, have you tried pressing the DISP button once? It's the lower left button on the back of the camera. It manually turns the display on or off as desired to save batteries (you can then aim through the optical viewfinder).
Mar 02, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
LCD image upsidedown
There is a switch on the LCD pivot that detects which way the LCD is being viewed from. Check this switch.
Oct 21, 2007 | Sony Handycam CCD-TRV107E Camcorder
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Sep 16, 2007 | Sony Handycam DCR-TRV140E Digital...
Edu-Science (10166) Telescope Logo
283 people viewed this question
Top Edu-Science Optics Experts
Craig Butler
Craig Butler
john cordey
john cordey
Geoff White
Geoff White
Are you an Edu-Science Optic Expert? Answer questions, earn points and help others
