Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Minimal flow of water and ice from dispensers and water leaking onto floor under the frig.
    Genius:
  • 1,157 Answers
Hi merlaine273,
If you're experiencing water leaks outside the refrigerator, it is often caused by the drain pan. There are some ways on how to correct this issue, either you clean the pan and reposition the tray. In addition, here are some tips that you can apply to solve this problem. Please follow the steps below.
Before conducting any repair, please remember your safety. Unplug the machine or shut off the power at the breaker panel to avoid any electric shock.
1. Remove the drain pan and clean it with a warm soapy water or water and baking soda.
--> the drain pan is located at the bottom of the refrigerator behind the front grill.
--> Please remove the grill which snaps into place. Hold the drain pan while pulling slightly upward and forward.
2. If you noticed that the pan is too closed to the compressor please reposition the tray.
3. You may also try to check water invelt valve. It is located behind the refrigerator. Look for a water supply line coming into the valve and turn it off at the source. Now disconnect the supply line. It has screws so you need to remove them.
4. The water inlet valve is connected by two wires. Before disconnecting the wires please label the wire placement on the water inlet valve.
5. The wires are connected to the terminal with slip on connectors. Firmly pull the connectors off of the terminals ( don't pull on the wire ). You can use a pair of needle-nose pliers to remove the connectors. Please check if the connectors and terminals has corrosion. If corroded they should be replaced.
Hope it helps.
Thank you for using FixYa.
Posted on May 11, 2011
I have the Kenmore top-mount 106.76232402 leaking
hi.turn water supply to fridge first.cont drip might be a faulty valve.hope this helps.Ali
Jun 26, 2012 | Kenmore Refrigerators
How do I remove the drip pan from under the freezer? It's full and leaking onto the floor?
There should be a decorative kick panel underneath that will snap out revealing the drip pan which will then slide forward and out to pour the water off.
Nov 25, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
No water is coming from the water dispenser and ice cube are hollow water is coming out the bottom of frig on the floor could it just be a stopped up filter?
You definitely have a water flow problem. Plugged filter, broken line, low water pressure will all create these symptoms.
Eric
Feb 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Water collects in bottom of freezer, then it runs out in the floor after ice has filled the bottom of the freezer. I have a frig with water and ice in the door. The ice maker is working fine, but the water...
there is a chance that the bottle that holds your water in the fridge compartment.could be broken or a line maybe disconnected this would cause water to leak in the fridge compartment.this bottle is designed to hold the water and get it cold before dispensing to your glass
Sep 16, 2009 | Refrigerators
Fan not working and sides are still hot
For your water flow problem and leak; Check in back of the refrigerator bottom right side facing the back. You will see two plastic tubes, one is for the water dispenser and the other is for the ice maker. Check for a loose connection at that point for the water leak.
May 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Defrost Problem
there is a drain in the middle of the defrost water collector and it is probably blocked - usually with ice. dry ot the tray and put very hot water in to melt the ice. you may have to do several times. do this until water flows away freely
Jul 25, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
