Question about Fisher and Paykel 24 in. DS-603 Built-in Dishwasher
How do you replace the electrical cord on a dd603
    Problem Solver:
  • 10 Answers
Unplug and turn off water. On the sides of the drawer you will find a plastic pin about the size of a quater. Turn and pull them out. This will release the front of the drawer. Pull out at bottem then down. Carefully dis connect any wires connected to front. Now the fun starts. Disconnect any wires that go down under drawer. Under drawer, remover moter cover and diconnect wires to moter. Let wires hang and carefully remove drawer. You may have to wrangel some wires and a swing arm. On the bottem left side you will find control board. Remove cover. The power cord connection is there. You may have to pull the housing to change the cord. It might be zip tied in the back. Good Luck. If you can just cut the cord and spice in a new one under sink.
Posted on Mar 24, 2011
  • 55 Answers
You would need to remove the lower drawer and the plastic cap on the mains filter board. The link below explains how to remove the lower drawer and access the main filter board.
The plastic cap is held down with small tabs, depress the tabs and slide the cover off. The power cord is screwed down to the mains filter.
Fisher Paykel Dishwasher Repair Video
How do i repair fisher paykel dd603 problem top drawer stuck on fast cycle, bottom drawe stuck on normal cycle
you will need to replace both draws control boards, with the dd603 control boards they have a small touch button panel on the top of the board which they didn't put a protective layer or plastic over and basically what happens is steam gets on the copper tracking and corrodes it hence the fact it doesn't work anymore, all new control boards even the replacement for yours comes with a plastic strip over the board. hope this helped
Oct 06, 2014 | Fisher and Paykel Dishwashers
MY FISHER /PAYKEL DISHWASHER DD603 DOES NOT HAVE A POWER CORD
Not sure why the power chord would have gone missing. I am assuming you may have an integrated model.
In any case you will have to take the bottom drawer out to gain access to the power filter board which is located at the base of the cabinet under the drawer.
To take out the bottom drawer follow instructions on page 7 of this installation manual.
http://www.fisherpaykel.com/vault/pdfs//pdf_installations/526609O_DDinstall_NZGBw.pdf
Make sure the drawer is not pulled too much out to avoid damage to wires and hoses underneath. Leave it on soft material on the floor. Next locate the power filter board at the base. It looks like the pcb in the attached parts diagram. The power cable is meant to go to the block connector on this pcb. Make sure you check connections carefully as mains voltages are involved. Put everything back.
http://www.searspartsdirect.com/partsdirect/part-number/Fisherpaykel-Parts/Dishwasher-Parts/525959P/0022/426/Model-DD60388445B/3068/0130000?keySuffixId=&pathTaken=partSearch&pathRender=modelComponent&documentCompId=50042566&diagramPageId=00003&productTypeId=&searchModelNumber=DD60388445B&subCompDesc=Cabinet&brandDesc=FISHERPAYKEL&modelDesc=DISHWASHER&blt=11&shdMod=&keyId=15
Aug 05, 2014 | Fisher and Paykel Dishwashers
Motor problem on a DD603. Where can I obtain spare motors in the Norwich,Norfolk,uk area. Post code NR93JP
Your best is to give Marks Electrical a call
See this site.
Hope this helps.
Please rate this solution to make sure Fixya can maintain its quality of service.
Aug 27, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Dd603 info only acrid smell/smoke from upper
INFO ONLY- POTENTIAL FLUIDS CONTAMINATING CIRCUIT BOARD
EDGE CONNECTORS
Jan 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I need to repalce the elctrical supply cord and water supply line to my Fisher & Paykel DD603 dishwasher, but I'm unsure as to how to remove the terminal box cover. Could you please help? Thanks.
THIS IS SIMALAR TO THE BOSCH UNIT, IF THERE IS NO BOTTOM COVER TO REMOVE YOU NEED TO TAKE THE SCREWS OUT OR THE TOP INSIDE THAT HOLD IT TO THE COUNTER TOP, PULL THE UNIT OUT SLOWLY, TURN OFF THE WATER SUPPLY SHOULD COME OFF THE HOT SIDE OF YOUR FEED LINE TO THE FAUCET UNDER THE KIT SINK, THE WATER SUPPLY IS ON THE LEFT LOOKING AT IT AND THE ELECTRIC IS ON THE RIGHT IF YOU CAN PULL IT OUT ABOUT 8 INCHES YOU CAN GET TO BOTH CONNECTIONS TO BE ABLE TO DISCONNET PULL OUT ALL THE WAY GET BEHIND IT AND CHANGE WHAT EVER YOU NEED TO
May 29, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher model DD603 Fisher&paykel
try to check the plug and the wire
Jun 27, 2008 | Dishwashers
Fisher and Paykel 24 in. DS-603 Built-in Dishwasher Logo
206 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
