Question about Dryers
I have a kenmore 600 series dryer. I replaced the heating element since my wife noticed there wasn't heat anymore. Upon removing the old element there was visual evidence of a break. After i replaced the element and pushed the start button for a trial there was a momentary spark somewhere. I couldn't tell exactly where. It did trip the main house circuit breaker as well. Since that time, whenever the unit is plugged in the heating element goes hot and starts glowing. The wires that go to the bottom fuse are live with voltage. Also the motor now makes a binding noise. I took the blower houseing off and emptied it out. It definilty needed it. I reattempted a start with the blower housing shrowd off so that i could see if the motor was actually turning. It is not. I can take a screwdriver and manually start turning the motor almost like you would for an old airplane and the motor will take off and spin. One, I am not convinced this is a bad motor since the heating element is hot as soon as you plug in the unit. The motor will spin so it seems like maybe there is something electricly going on. I have checked the fuzes and all are active. Is this some kind of conrol switch problem?
  • 96 Answers
Sounds like the centrifugal start switch located inside the blower end of the motor is stuck in the run position
Posted on Mar 24, 2011
My 600 series Kenmore dryer will tumble clothes but not heat-dry them. This happened during a too-large load, and it hasn't heated on any size load since then. I was thinking the heating element might...
send model number and also you'll need a meter to do some checks for me,i'll be happy to work with you but need model numberalso is it gas or electric,if the lint filter is inside you can do everything from the front.
Sep 21, 2013 | Dryers
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
600 series gas drier runs but no heat
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 25, 2011 | Kenmore 600 6962 Dryer
Kenmore 80 series dryer approx 7 years old not heating anymore. Cleaned the vent pipe using semi-rigid vent tube only three feet to outdoors. Vent on exterior blowing cool air forcefully. It is an...
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Here is a link to a video that will help you.
Nov 26, 2010 | Dryers
I have a Kenmore 80 series gas dryer that will not heat up anymore. I took off the small clip in front and can see the heating element start but no flame or heat . Also the dryer will make an intermittent...
check the thermal fuse on the blower housing,if it shows good then possibly the gas valves are weak on the burner tube and wont let gas into the burner
Nov 18, 2010 | Kenmore Dryers
Why doesn't the 600 series kenmore dryer have heat?
remove the back and check the heater box fuse and heating element,the heater box is on the right,the fuse is on the left side top,the element is the bottom half of heater box-mike
Feb 17, 2010 | Kenmore Dryers
I have a Kenmore Serie 400 Dryer. It goes on and never stops. It doesn't heat up anymore, it just tumbles. How do I go about finding the problem ?
remove back cover, check with an ohm meter the heat element and also the hi temp thermal fuse above the element for continuity, if open replace.
Aug 18, 2009 | Kenmore 400 6942 Dryer
Kenmore Dryer won't heat up
thermal fuse is bad. replace fuse. clean out vent duct. thermal fuse usually blows when there is restricted air flow over heating element.
Jun 24, 2009 | Dryers
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
No heat
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Apr 21, 2009 | Kenmore 62802 Electric Dryer
Dryers Logo
79 people viewed this question
Top Dryers Experts
