Question about Dryers
I got a new belt but unable to put it on the motor shaft which is beteen the moteor and the blower. My dryer model is Asko T721
  • 3 more comments
  • josephtanmai Mar 24, 2011
    Firstly there is no pulley behind the motor. the shaft has groves to guide the belt.
    My question is how to loop the belt onto the motor shaft which is connected to a
    fan unit on the other side.
    Not sure I have sent my reply correctly. So here it goes again.
    1) My question is how to loop a new belt onto the motor shaft which is between the motor and a blower unit.
    2) For your info, there is no pulley on the motor shaft. The motor shaft has groves to guide the belt (The belt has same kind of groves).
    Regards
    Thank you Kelly.
    I did it the stupid way - I loosened up the motor, rerouted the wiring and managed to slip the belt in. But that took me 5 hours.
    Now I cannot put the front panel back in. Well, I will do it tomorrow.
    May be you can stop your research.
    Thanks anyway.
  • josephtanmai Mar 26, 2011
    Hi:
    I fixed the damned dryer!
    The air blower is not removable and perhaps my way is the best - remove the motor from
    the base and loop the belt over.
    However, I mixed up with one wiring in the process. Luckily, I managed to reverse it - it is the switch
    that turns off when you open the door. I connect to the wrong terminal so it runs when open and stops when door closed!
    It was a learning cursve - should have paid someone $150 to fix it.
    Thanks for the help. I will accept your comments as positive but please look further into the manual.
    God bless!
    A lot of work but I overcame it.
    Asko should re-design it with connector between the motor shaft and blower shaft to let the belt to slip in.
  • Dryers Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
The ribs go against the drum and the belt is routed like this:
There should be a pulley BEHIND the motor that drives the drum which is where you should install the belt.
Thanks for choosing FixYa,
Kelly
Posted on Mar 24, 2011
  • Kelly
    Kelly Mar 24, 2011
    My error for passing you incorrect information. After much more research I note this is a condensor dryer and although I have worked on appliances especially washer dryers and refrigerators for over 40 years... this is not one that I have worked on. I am sure I could figure it out quickly but that does not help you right now. I have to ask that you reject my solution so that an expert with the skills that you need can respond to you. Again my apology.
    Kelly
  • Kelly
    Kelly Mar 24, 2011
    Usually when the front panel gives you a fit there is something wrong with the drum seals. Very carefully place the shank of a phillips screw driver somewhere on the front and rear bulkheads pointed inward and slowly rotate the drum so that the folded over drum seal is back where it belongs. If there are drum rollers under the drum make sure they are not pushed up against the rear bulkhead. Usually they run in a groove near the back of the drum on the outside. If the rollers get pushed back it is nearly impossible to put on the front panel. As far as the screwdrive shank trick depending on how your drum is sealed you may have to unfold the rear seal first then do the front seal as you ease the front panel back into place.
    As for the belt change I did more research and everything I read has you removing an air duct and the blower housing to change the belt. Obviously it is a little late for that now.
    Kelly
My asko T721 dryer won't start. If I hold the start button down it will work, but the second I let go of it the dryer stops. It was running fine yesterday and then it stopped and now I can't get it...
the start button is bad. you will have to get it replaced take the model and serial# and go to your local appliance part store and they should have one.
Dec 17, 2010 | Asko T721 Electric Dryer
Asko T721 dryer. Support rollers started to fall to bits (dryer making bumping sound as it rotated) so I bought a new set and replaced them. Not a single electrical connection was removed bar the door...
  • If you took the drum out and took the belt off you may have put the belt on wrong as there is a switch under the drive or idler pulley that must be pushed on from the pressure of the belt on the pulley. Also go and make sure both breakers are ok in the breaker box as it runs on a 220 volt sys. and if one is tripped this type of thing can occur.
  • Good luck and please rate me if this helped! thanks again for choosing fixya
Oct 12, 2010 | Asko T721 Electric Dryer
What may be the cause of excessive vibration in my asko T731 electric dryer?
One of the most common causes of what you`re describing on an Asko dryer is lint build up or static sheets getting into and on the blower wheel or the blower wheel has been busted some how. To check you`ll need to remove the lower panel so first things first...**Unplug the unit from the source or shut off the power at the breaker panel**
With the power now off, remove the 2 philips (star) or torx head screws at the bottom on either side of the panel. Once that is removed you`ll see a white plastic housing which is the vent/exhaust duct.
On this duct there is a small round cover to the left which provides access to the blower, but you may need to remove a sensor/thermistor held in place (and can be hidden in fact) with black puddy, so you`ll need to observe and handle it carefully. The small round cover will be held in place with clips molded into the plastic, a small flat/spaded screw driver will be required to remove the cover.
Once the cover is removed you`ll know almost immediately if the blower is full of lint (or anything else) and causing an unbalanced or excessive vibrating scenario.
Also check the blower nut/fastener to insure it hasn`t come loose or the blower shaft isn`t cracked or become rounded because it should be in the shape of a D where it slides onto the motor shaft.
That is the most common occurrence with the Asko dryer`s when it comes to vibrating. It can manifest from any number of thing`s though really, such as...worn drum rollers or roller shaft`s. Worn rear drum bearing or belt, and even belt tensioner (idler pulley).
I`ve just explained the likeliest cause with the blower wheel, so try that and let me know how it goes.
Hope that help`s you out. Good luck.
macmarkus :)
Nov 21, 2009 | Asko T731 Electric Dryer
Overheat trips Asko T721 dryer
If you have a condensate tank that fills up too much the float inside the pump housing will shut the dryer off also.
Jul 24, 2009 | Asko T721 Electric Dryer
Asko Dryer won't spin...need to tighten belt
Does the Motor turn... We have had many motors with bad capacitors .. check the white capacitors for cracks or metal coming out of it...the motors will run with out a load on the but put a few clothes in the drum and they will just hummm..
Jul 19, 2008 | Asko T721 Electric Dryer
ASKO T721 dryer - Squeaking
the dryer needs a service you need to replace the front rollers,jockey pulley and grease the jockey pin,check or replace the belt.remove the lint build up from the front frame and element assy.also check that the felt and rubber seal arond the front frame hasnt come out.you can replace it but its hard to get in and you may have to replace the front frame.i find its any easy repair but i see a lot of asko dryers (not because there bad they just need a service about every 5-7 years).hope this helps.
Mar 17, 2008 | Asko T721 Electric Dryer
Dryers Logo
170 people viewed this question
Top Dryers Experts
