Panasonic Viera 50" flatscreen won't
    President:
  • 1,654 Answers
The flashing light is a service code for the repair tech. You have a board failure on the set and it needs to be looked at by a qualified repair tech. Very common issue these days. Bad capacitors were used in the making of these sets and they are failing, making it a pain for all owners. Better hurry and get itr repaired if you want to keep it, cause electronics parts are starting to dry up since the earthquake in Japan.
Posted on Mar 24, 2011
  • Norman Skinner
    Norman Skinner Mar 25, 2011
    There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
    Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
    If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
    Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
    If you aren't tech savvy, this unit needs to go in for repair.
    If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
    Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
    IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
    Most of the caps that go are 10V 1000uF or 3300uF.
    I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.http://www.youtube.com/watch?v=Mm51C_RDI...http://www.youtube.com/watch?v=BNHHrgX_6...http://www.youtube.com/watch?v=8l0AUj8QU...http://www.youtube.com/watch?v=Y7b_nTaZY...
    As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
    The parts are cheap, and skill required is minimal.
Why does power light flash off &on
Check the capacitors on the power board. Looks for split tops with leaking stuff .
Jun 21, 2014 | Panasonic Tc-p50g20 Viera G20 Series 50"...
How to reset tv
hi Tracie,
is the set making a clicking noise?
is the power light flashing on the front?
or no power light at all just dead?
if the set is just dead, just put your ear to the back vents can you hear like a very faint screaming noise and can you smell and burning in the vent?
if so it just could be capacitors on the power board.
if its clicking the that will need a service kit on the power supply board.
if the power led is flashing then you will need to count how many flashers from start to finish when you first turn set on.
hope this helps.
Panasonic TH 42PX75 80 TH C42hD18 Dead TV Repair Fix TXN P1XGTUS HNTUS... Panasonic TV Won Turn On Learn How to Replace Your Power Supply FIX Panasonic Viera 42 inch Plasma SU BOARD TH 42PX75U Diagnosis Repair...
Jun 20, 2014 | Panasonic "Viera Tc P65 Gt30 65"" Class 3...
My panasonic viera 50 inch plasma wont turn on. When i turn it on a red light comes on and nothing else
I had the same problem with a Panasonic Viera Plasma TC-P50S3 with 14 flashes. I used an ohm meter tocheckcontinuity of the boards inside, starting with the power board (power to TV off). Check YouTube for videos on how to do this. The SC card showed a fault (It was reading close to zero ohms on both pins. I could find no one who supplied SC boards and could only find repair kits. Repairing a circuit board is outside of my ability, time and tools. I found a place online to send the SC board in for repairs. $65 plus shipping. I was getting $350 "ballpark" quotes from Panasonic authorized TV repair shops. If none of this works for you, there are TV salvage companies who will pay you some cash and pick up TV from you. You can also sell it on craigslist for salvage parts or part it out separately. The various boards seem to cost around $100 each and you likely have four or five in your TV. At least for my TV, the parts don't seem to be out there, so there is a demand for the salvageable parts.
Aug 27, 2013 | Panasonic VIERA TH-65PV500 65 in. Plasma...
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Panasonic viera tv won't turn on, power light flashes
Hello The problem of your television is cause of faulty power supply.The power supply have abnormal voltage output supply because of leak capacitor.If you want to fix the problem of your TV,this is the procedure,First is remove the back cover and find the power supply.You can see the bulging tops of capacitors,thats the leak capacitor.Replace all new capacitor with the same value.Avoid short circuit in PCB board of power supply.If you can't do the to repair, call a technician or repair to authorized service center.Thanks..
Sep 03, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Aug 01, 2011 | Panasonic Televison & Video
Everytime I turn my tv off and back on again it seems to go into standbye mode.Get flashing red light on front.It is the viera 50" plasma 1080P.Have to unplug and let it sit for a bit before I can turn it...
Check and change the capacitors in the stand by circuit parts.The problem is in the command parts 12V and 5V circiut.Check the active and the passive components.30% you need change the power supply board(Panasonic Viera).
Aug 14, 2009 | Panasonic Televison & Video
Panasonic 50" Viera will not turn on
Sounds like if no lights or LED's are lit then the power supply blew. Could be just a fuse but not likely. Did you try unplugging and trying again ?
Mar 30, 2009 | Panasonic 50 in. Plasma TV
Televison & Video Logo
181 people viewed this question
Top Televison & Video Experts
