Question about Toshiba 50A62 50" Rear Projection Television
Toshiba 50A62 50-Inch Projection TV displays black lines across screen running from top-to-bottom and the resolution goes off the screen. When I apply force to the top of the television and or back of the television where the connections are made from my DVD Player, Xbox 360, etc. the lines go away for awhile and then come back. I read somewhere that, to fix this, I would need to do something to the area that makes the connection between the projection and the actual input. I am horrible with televisions, so hopefully someone may help me out here? Thank you very much, Aaron
    Problem Solver:
  • 8 Answers
Wadasdasdasdasdasdaw
Posted on Mar 24, 2011
  • aaron42491 Mar 24, 2011
    I'd really appreciate some seriousness here. Thank you :).
Samsung TV thick black line running across the bottom.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 08, 2016 | Samsung PN51E450 - 51" Class 50.73...
Black horizontal lines top and bottom
This is called "Letterbox" and is common among sources. There is nothing wrong with your TV. When a movie or TV show is filmed, the camera it is filmed on has a certain resolution. It also goes through alot of processing before it reaches your TV. Your TV also has what is called a "Native Resolution". If the output resolution of your DVD, or TV station is not the same as your TV's Native Resolution, the TV "scales" the image to fit on the TV, hence the black bars on the top and the bottom of the image.
Nov 10, 2012 | Televison & Video
Black line running vertical from top to bottom toshibia tv 42
Model listed here is 46 inch---what is correct model of your TV?
Jun 15, 2012 | Toshiba 46H84 46" Rear Projection...
I can't get the display to fill the whole screen area. Sideways is good but I have a 4cm wide black stripe across the top and bottom of the screen.
Connect it to a different computer, to see if that computer's video-card can "fill" the screen.
What is the "native" resolution of your monitor? 1280*1024, 1920*1080, 1400*1024 ?
What resolutions are supported by your computer's video-card?
Nov 15, 2010 | Toshiba Computers & Internet
Fault on TV
something fried .. sounds like the vertical has gone ,
call a tech.
Mar 07, 2008 | Televison & Video
DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
Rca projection screen problem
I have a Toshiba 27D46 TV that comes on great.. but within 5 minutes goes black with a white line horizontal midway across the screen. Any fix solutions? HELP..!!! Chip
Jan 06, 2008 | Televison & Video
Black lines and menu problem
Check for bad caps in vertical circuit. Solder any/all bad connects. REPLACE vertical o/p IC w/OEM or better quality. I usually use Tosh,Hit,or Pana. 2)Check/replace tactil switch (menu)on front panel.
Sep 28, 2007 | Toshiba TZ50V61 50" Rear Projection...
Toshiba 50A62 50" Rear Projection Television Logo
179 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
