Question about Microwave Ovens
Can a 3 wheel bacino sherpa pram lie right back...i got it from a second hand & ma daughters only 2mnths ...I cant seem to figure out if its seat can lie right down or not..
I have a Maytag microwave UMV1152cas. I recently replaced the magnetron because it was not cooking food. I began putting it back together and have it all back together except for a plastic piece.
HI,
Maybe this will help. Here is a link to an explode view of your Microwave. There are other exploded views on the right-hand side of the page.
http://www.appliancepartspros.com/02-body-cavity-parts-for-maytag-umv1152cas.html
Jul 22, 2015 | Maytag Microwave Ovens
My microwave heats & shuts off with timer But it comes back on when I open the door (not heat) just turntable spins in opposite direction, and fan & light come on.
OOHH this could be dangerous to use, seems your door interlock switch is not operating , Id unplug it right away and refer it to a qualified service center
microwaves on live flesh (such as your hand) could explode !!!!!!!
Feb 20, 2015 | In Microwave Ovens
We have a kenmore over range microwave that on the right hand side of th einterior seems to spark or catch on fire? It is a 2005 model.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 14, 2011 | Kenmore Microwave Ovens
My Goldstar MA 781M microwave has a "mica" like
That sheet is called the Waveguide Cover and its function is to stop debris and food entering the aerial and magnetron.
Replacement is essential and must be made of mica.
It can be purchased from a dealer at a reasonable cost.
Google the manufacturer and find a dealer.
Hope that helps.
Nov 06, 2010 | Goldstar MA-7801 Microwave Oven
How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Jun 25, 2009 | Frigidaire FMV156DC Microwave Oven
GE microwave (jvm1740dm1bb) - Control panel inop
That model number is not quite right. I'm going to assume it's JVM1740DMBB01.
(If that's not right, please check the tag inside the oven & reply back)
The membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
The part number you need is WB07X11040 and you can find helpful exploded view diagrams and order this part here for $107.00 (compared to $164.75 from GE!)
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 02, 2009 | GE JVM1790 1000 Watts Convection /...
Key pad inoperative
replace the keypad,and spray the terminal with wd40.
Mar 31, 2009 | Goldstar MA-1012 Microwave Oven
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
