Question about Compaq Presario Laptop Cooler
Overheats, what cooler would be the best - Compaq Presario Laptop Cooler
  • Compaq Master
  • 27,725 Answers
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line dust causes static to build up in a computer causing it to overheat any many other problems then you could get a usb 3 fan laptop cooler pad this will keep your laptop very cool
hope this helps
Posted on Mar 24, 2011
My 30 hp ingersoll rand screw compressor overheats even though I've changed the filters, Oil, cleaned the cooler
thats a very expensive compressor to be looking here or anywhere for answers as to why it's over heating... I would be contacting I.R. in a hurry and be ready to pay the service fee...
Dec 24, 2013 | Ingersoll Rand Air Tools & Compressors
Simplicity Champion Hydraulic Oil overheating
I would have to say you will continue to have this problem until you resolve it. If it continues to overheat with an oil cooler installed, I would check to see if the pump is operating at the proper pressure.
Jun 05, 2013 | Garden
O&k f106a grader hydraulic pump pumping all the time then overheats
Make sure the oil cooler is clean and the fins are not plugged. dirt and grime in the cooler will not allow system to cool oil and shut. use compressed air to blow out if real bad cooler may need to be removed and cleaned. start there
Dec 25, 2012 | Cars & Trucks
1998 jeep cherokee new waterpump new thermostat still overheats gauge reads hot and then back to normal when I get out and pop the hood it is running hot????
YOU HAVE AIR TRAPPED UNDER THE THEROSTAT
THE BEST WAY IS TO DRILL A 1/16" HOLE IN THE FLAT RING OF THE THEROSTST THAT WILL ALOW THE AIR TO EXCAPE AND KEEP YOUR MOTOR COOLER
Aug 01, 2012 | 1995 Jeep Grand Cherokee
Can I install a freestanding wine cooler under my existing cabinet?
I strongly suggest you find somewhere else for it. Freestanding wine coolers are designed to disperse heat from the back. If you put the cooler under a cabinet, the heat cannot escape and will in time overheat the unit.
Jul 31, 2012 | Furniture
My cooler for my laptop wont work. it over heats and makes my laptop over heat also.
make sure the cooler fan is getting power test the leads that attach to the cooler make sure the connection is good and not faulty
also you should clean the cpu make sure there is no dust built up on the fins of the cpu
(dust will cause static) to computer overheat and lots of unforseen problems
also you purchase a portable usb laptop cooler pad
hope this helps
Mar 06, 2011 | Rocketfish Universal CPU Cooler RFUCPUCF...
System will overheat and not function properly, screen displays for 10 minutes then purple/pink colors appear and the system freezes and will not show anything until it cools
Make sure it is in a well ventilated area, and if that doesnt cool it down buy a fan cooler from best buy, its basically two to three fans that hook to the back of the console to cool it down.
Jul 15, 2010 | Sony Playstation 3 (PS3) Console
Egr cooler repalced to get us passed warranty - oil cooler was not replaced prior to 160k warranty exipred- on vacation 2000kms away (only 11000kms after egr cooler fixed) from home towing a trailer...
If the dealer put an egr cooler on and didnt replace oil cooler, it can blow out egr cooler again , restriced oil cooler causes egr cooler to blow out , which in turn can cause overheat and blown headgasket also, if you are seeing white smoke now it is possible for the egr to be blown out again as wel as the oil ooler and/or headgasket
Aug 03, 2009 | 2005 Ford F 250 Super Duty
We can only play movies
make sure your fans are coming on. Buy canned air and blow the fans out. Sometimes dust collection will make it overheat because air is not circulating properly.
Jul 20, 2009 | Sony PlayStation 3 40GB System
Transmission oil in coolant?
Trans fluid can get into radiator by the trans cooler built into radiator side, automatics...
Engine oil can come thru cracked block, head gaskets
Which oil is it? Either way it needs to be fixed.
Typically with automatic trans they can overheat and cause engine temp issues, because they cool thru the radiator using an in tank cooler along side.
IF you overheat the trans you CAN overheat engine
IF you overheat the engine you CAN overheat the trans
Jul 17, 2008 | 2001 Chrysler Town & Country
Compaq Presario Laptop Cooler Logo
151 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
