Need a microsoft ISATAP adapter for my desktop
  • 2,632 Answers
Welcome to Fixya. For clarification do you need what operating system you are you using and you need a microsoft Isatap driver?
Thanks for using Fixya
Posted on Mar 24, 2011
Need new download of ISATAP drivers
Greetings,
On a Windows Vista-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark (!) next to it in Device Manager.
You can safely ignore this error message. This error message does not indicate a problem with the adapter. The adapter will continue to work correctly.
Check out this article for more information on this:
http://support.microsoft.com/kb/932520
If this is still not working,
First try to reset Winsock from command prompt, this will reset all the Network components to default:
Click on start, type CMD,'Right click and Run as Administrator'.
At the command prompt type:
netsh winsock reset catalog
In such a case, I suspect this problem to be caused by network adapter missing or corrupt. Please firstly reinstall the driver for your wireless network adapter. Then try to reinstall Microsoft ISATAP using following steps:
1.In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
2.Still in Device Manager, click Action and select Add legacy hardware.
3.Click Next, and select Install the hardware that I manually select from a list (Advanced), click Next.
4.Select Network Adapters and click Next.
5.Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
6.Click Next and finish the remaining wizard.
Hope this helps you to solve the issue. Please do vote or provide feedback on this solution, your response will be appreciated.
Thank you and Kind Regards
Gowtam R
FIXYA Solutions Engineer.
Mar 18, 2013 | Microsoft ISATAP Adapter
I need microsoft ISATAP adapter #3 driver
you can try this:
Step1:
However, try the below steps to fix the issue you are experiencing:
1. Click on Start, type Device Manager in the search box.
2. In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
3. Still in Device Manager, click Action and select Add legacy hardware.
4. Click next, and select Install the hardware that I manually select from a list (Advanced), click next.
5. Select Network Adapters and click next.
6. Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
7. Click next and finish the remaining wizard.
Step2:
The ISATAP is related to Internet Protocol 6.
Please check if IPv6[Internet Protocol version] is enabled on your computer to obtain an IPv6 address.
however this driver only pertains to ipv6, so your internet adapter should still function properly. if it is, you can do this:
Disable but leave ISATAP in the hardware list and go to your manufacturers Website
and check for Post SP1 Driver updates for your computers Chipset.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Feb 01, 2012 | Toshiba Computers & Internet
Microsoft ISATAP Adapter This device is not working properly because Windows cannot load the drivers required for this device.
ISATAP is Microsoft trying to allow IPv6 to function over an IPv4 infrastructure, however, it was released extremely prematurely, and as a result, doesn't like to work, or install. According to Microsoft, your computer should continue to function without ISATAP functioning,and the error message may be ignored. However, if you believe that this may be causing you some problems, then you may navigate to the device manager ( Start > Control Panel > Hardware and Sound > Device Manager ) from this window, see if you can find ISATAP adapter and 4TO6 adapter, right-click these, and select "Disable" NOTE: this may cause Internet Explorer and Windows Mail to run slower and have a few errors.
I hope this helps!
May 08, 2011 | Microsoft Computers & Internet
In Device Manager under Network Adapters the following have a yellow triangle in front of each one; 1. Microsoft 6 to 4 Adapter, 2. Microsoft ISATAP Adapter, 3. Microsoft ISATAP #2, 3. Microsoft Teredo...
the yellow mark on device manager means the driver has not been installed and the driver is connected to the motherboard use your motherboard drivers CD and install them or you can download them from the net
Dec 15, 2010 | HP Pavilion m7640n PC Desktop
EXCLAMATION MARK IN THE DEVICE MANAGER
Regarding the Microsoft ISATAP Adapter error, you can ignore it safely. Please refer to the following link:
On a Windows Vista-based computer or on a Windows Server 2008-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark next to it in Device Manager, and you also receive an error message
http://support.microsoft.com/kb/932520/en-us
Dec 07, 2008 | HP Pavilion dv6000z Notebook
There is a exclamation mark in the device manager beside the microsoft ISATAP adapter#5. Should this exclamation mark be here?
No. If you have the driver for it try reinstalling it. If you don't I would delete the device and reboot. This will force the drivers to be reloaded unless they were deleted...If they were deleted and you are not very good in computers, you may need a bit more troubleshooting than on line help.
Dec 07, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
