Question about Fisher and Paykel (IWL12)
Machine says "I need service"
    President:
  • 1,654 Answers
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
I took this from the service repair manual. Hope it helps.
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66. On some machines the pressure switch is seperated and sometimes the plastic tub for the switch gets clogged up and blowing through it will sometims clear this fault. Not sure about this particular machine, but you can try adjusting water level to see if it will work at a different level of water.
Posted on Mar 24, 2011
I have service manual for GW612. The error code 01000010 (66) is not listed. Comes up all the time.
I can't find that service manual. Is it possible there's only 7 LEDs and the fault code needs to have 128 added to it?
You don't say which country you're in - you could phone Fisher & Paykel support.
Jan 30, 2018 | The Office Equipment & Supplies
What does the fault code 66 on a fisher and pykel
The problem with the washer is that the motor controller has sensed the lack of water in the machine as so to speak, hence the error.
If you disconnect your water hose off the backside of the washer there may be screens behind them. I would start there. Good Luck
Oct 18, 2014 | Washing Machines
2004 Honda CBR 125 R code 54
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
https://cbrforum.com/forum/other-models-125-250-400-66/cbr125r-2010-fault-code-54-a-156083
Honda Motorcycles Fault Codes Motorcycle Manuals PDF
Honda CBR125R Owner Manual service
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR125RW Owner Manual
Jan 14, 2014 | 2004 Honda CBR 125 R
Hi - I have a Fisher & Paykel GW512 washing machine. it keeps giving an error showing these light on the cycle progress 01000010 (code 66)? I pulled the top off and if I disconnect the display module from...
I can't remember what fault 66 is off hand, but I can check tomorrow.
fault 130 (which has one extra 0) is a common fault, and will do what you say. it is an intermittant RPS fault. RPS is a small chip on the side of the motor, and they are a little touchy at times. easy enough to replace by removing motor cover, loosening the motor and removing the RPS from it's harness.
Oct 20, 2013 | Fisher and Paykel Washing Machines
I have a fisher and paykell GW712 washing machine that has the 2 green light and 7 red light flashing and beeping after turning on at power point.after pushing buttons 4 or 5 times and turning the power on...
The second light and the seventh light on and beeping is fault 66.
This is info on fault 66.
66. (01000010) Phase 6 - Pressure Transducer (Ptx)
Error - Frequency > 90 kHz
Note: this supersedes Fault code 65 from V41 Motor Control Module
code onwards.
The Motor Control Module has received signals from the water level
sensor (Ptx) above normal frequency values.
Primary Source: Motor Control Module.
Action: Replace Motor Control Module.
Oct 07, 2013 | Fisher Paykel EcoSmart GWL15
Yamaha r1 error code 66
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/161-09-14-r1-mechanical-help/286089-09-r1-error-code-66-a.html
Yamaha Fault Codes
Yamaha YZFR1Y 2009 Service Manual
OEM parts for Yamaha
Yamaha YZFR1Y Owner Manual
Aug 01, 2013 | 2008 Yamaha YZF-R1
Lights 2 and 7 and constant beeping
Error code 66 is water pressure sensor.
Dec 06, 2012 | Fisher and Paykel GWL11 Top Load Washer
Needs service code 66
The pressure sensor is faulty and needs a new/good secondhand one
You can get one from an old dead board,
But it needs to be calibrated to that board.
To calibrate the new one set machine to fill to low water level,
The plastic hex with red on it needs to be turned up to raise & down to lower the water level.1/8inch of a turn will adjust water by 15 to 20mm.
Jun 17, 2012 | Fisher and Paykel Washing Machines
Jun 17, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
690 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
