Question about Dryers
How do I get the front of the dryer off? It looks like its just one big skirt from the front to the back. I have a maytag mde4658atw. I was able to get the top off and can see the drum. The belt is on and the drum will not turn not even by hand. It makes a huming sound when I try to turn it on. The vents are all clean-I am trying to check the motor but I can't get to it. I'm really not even sure what to check for when I do get to it?
    Genius:
  • 1,400 Answers
Hello
Best to go in from the back or tilt the dryer on its side and remove bottom panel.
Before you go too far make sure the door switch is not messing with you.
Try holding it in with your finger the turn on the dryer.
Also could be a bad motor if you can not turn by hand.
Posted on Mar 24, 2011
How do i access the back of a Model #MDE8600AYW - MAYTAG Dryer. i think i need to replace the drum rollers but dont think i can from the front panel.
yes it can be accessed from the front panel as it is located on the back right inside of the dryer.
1) unplug dryer
2) open door remove screws
3) with a flat tip screw driver pry gently up on the top corners it will pop
4) move front panel forward and disconnect door switch
5) sit panel aside
6) lift top lid of dryer 90 degrees it has clip/hinged on back
7) look to the right back of dryer, it looks like a spring in a metal box disconnect and replace.
Hope this helps Tim
Sep 25, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
What do i take apart the dryer to replace the heating element in my mde308dayw maytag dryer? the back seems to be attached to the sides and unable to remove. thanks
the steam on the front was 2 spring clips,one on each side in the front, use a putty knife to pop it up,then looks on the back wall and you will see the thermal fuse and the heater coil-mike
Feb 04, 2010 | Maytag MDE308DAYW Electric Dryer
Belt replacement on an electrical maytag dryer
hi. thanks for the question. to replace belt . lift up top, remove front panel, slip belt over drum. reinstall front and top, and clean all lint . pull dryer from wall ,remove back panel . motor on right, idler pulley on left, pull belt through idler and to your motor.
May 13, 2009 | Maytag PYE2300AY Electric Dryer
Maytag pye2300ay dryer grinding noise from front
You generally have to open up the cabinet from the back by unscrewing the fasteners.
Feb 06, 2009 | Maytag PYE2300AY Electric Dryer
Maytag electric dryer over heats
I removed the front by getting the screws out from inside that hold the front on. I unhooked the lid switch and got the front out of the way. Guess what I found? A big ball of lint right in front of the blower. The whole filter housing was full of lint!. To make matters worse the blower was loose!. So I used my super duty shop vac to clean it up and I replaced the fuse(mounted next to heat element)yes it was blown because of the lint ball. 3e11794.jpg
Dec 18, 2008 | Maytag PYE2300AY Electric Dryer
Dryer making squeaking noise
Usually there's a kick plate or panel at very bottom front of dryer. Take that off, then you can take the front off and then the top to look inside.
Jul 05, 2008 | Maytag Neptune MDE5500AY Electric Dryer
LD 8410 MAYTAG DRYER .... DRUM TURNS .... NO HEAT......HOW DO I TAKE OFF THE BACK
  • before taking it apart, if it is an electric dryer, then check the circuit breaker in the house. sometimes only one side of the dual breaker will trip leaving you with a running dryer with no heat.
  • maytag dryers are accessed from the front. look for 2 screws on the front panel near or at the bottom. these hold the front panel on.
  • let me know if you need more help
Jul 04, 2008 | Maytag Dryers
Dryers Logo
56 people viewed this question
Top Dryers Experts
