SOURCE: Blade number for Ariens Zero Turn Model 1840. Need
Depending on which version of the 1840 you have and when it was built it could be several blades...
Please get your model and serial number and then enter them into the following site's search engine. You should then be able to identify the parts you need.
http://partsradar.arinet.com/scripts/EmpartISAPI.dll?MF&app=ariens&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer
John
SOURCE: mower only runs two min and quits
Sounds like a blocked or dirty fuel inlet.
Remove the carb bowl and work the float up and down until gas flow improves. Be gentle! Just a little light pressure from beneath and the float should swing up about a quarter inch.
The short run is due to the carb bowl not refilling fast enough to keep up with full throttle demand.
Make sure when you put the carb bowl back on there arent any fuel leaks before trying to run the mower.
Good luck and be careful!
SOURCE: I need an owners manual for an Ariens Sierra 1640
Go you to this page and enter your model and serial number:
http://apache.ariens.com/cgibin/ctrg0005?SESSIONID=0.8213132047263072&Site=ARIENSS
Good Luck
SOURCE: When I start my Ariens
You either need a carburetor rebuild or you need a valve adjustment. Either of these things would cause this to happen.
Good Luck!
Jim
IMPORTANT: SHOULD YOUR TRANSMISSION REQUIRE REMOVAL FOR SERVICE OR REPLACEMENT, IT SHOULD BE PURGED AFTER REINSTALLATION BEFORE OPERATING THE TRACTOR.
Step 1- Place the rear of the mower safely onto jackstands on a level surface with engine off and parking brake set.
Step 2- Disengage transmission by placing freewheel control, located at the back of the frame, in the freewheeling position.
2a- Mowers with seperate pumps and wheel motors the freewheel is activated by turnign the bypass valves, one on each pump, two full turns.
The oil resevoir needs to be filled to the specifications listed in the owners manual before starting the purge procedure.
Step 3- Sitting in the operators seat(riders), start engine. After the engine is running, move throttle control to slow position. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 4-Move motion control levers to full forward position and hold for five (5) seconds. Move levers to full reverse position and hold for five (5) seconds. Repeat this procedure three (3) times.
NOTE: During this procedure there may be some movement of the drive wheels, but they are not under load. The air is being removed from hydraulic drive system.
Step 5-Move motion control levers to neutral (N) position. Shutoff engine and set parking brake. Check and add oil as needed for units with an oil resevoir.
Step 6-Engage transmission by placing freewheel control into driving position, or by closing the bypass valves on the pumps.
Step 7-Sitting in the operators seat, start engine. After the engine is running, move throttle control to full speed. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 8-Slowly move motion control levers forward, after the tractor moves approximately five (5) feet, slowly move motion control levers to reverse position.
After the mower moves approximately five (5) feet return the motion control levers to the neutral (N) position. Repeat this procedure with the motion control levers three (3) times.
Step 9-Your mower is now purged and now ready for normal operation.For further information or assistance, we recommend contacting your lo
