Question about Maytag UMV1152 Microwave Oven
Maytag Microwave UMV1152CAB with door closed the turntable turns and the light is on and we are not running the microwave.
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave runs with door open
I would say you have a failing door switch or the mount which holds your door switch is loose or broken. In most designs, it is the upper door switch that will produce these very symptoms when it is intermittent or its mount is broken or loose. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. Slamming the door, damage during shipping or transportation and sloppy manufacturing techniques or materials are the primary causes of trouble with the door switch mounts. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 22, 2007
fridgetech
  • 473 Answers
SOURCE: when I open my microwave door, it starts running
Yes it is running.  This should be checked by a professional for safety reasons.  If it is older I would just replace the microwave because repairs can be too expensive compared to a new one.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Problem with Maytag MMV5000BDB Microwave
The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 18, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave turntable won't stop running
This is usually caused by either a bad door switch, but may instead be a loose door switch mount or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 19, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Maytag Microwave MMV1153
First of all, it's under warranty. So I would contact Maytag for a free fix.
See http://maytag.com/support/service_parts.jsp
For an out of warranty reply:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Posted on Nov 28, 2007
When I shut the door on the microwave the turntable starts running even though it's not turned on and the light stays on
Maybe a failed triac that switches the motor and light.
Also try pulling it out from the wall for some time.
Mar 16, 2015 | Maytag MMV1153A Microwave Oven
Maytag microwave model mmv1153baw light won't shut off and won't start
Either the latch in door (spring related) is not in the correct location or you have a door switch issue and its not expensive to fix if you husband is handy. Part number you can use is 28QBP0495 or the factory one 3405-001034 (more expensive). This issue is common and these switches are located inside the control panel on the left side, the switch you seek is the lowest one in the bracket of three. Good Luck and I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 20, 2014 | Maytag Microwave Ovens
Magic chef microwave runs backwards with door closed and no time set - works normally when time is set and door is closed - any ideas?
Probably a bad door switch or door switch mount. See help file here.
It's normal for a microwave turntable to run either direction at random. That's common in such AC motors.
Dec 26, 2012 | Magic Chef Microwave Ovens
Our Microwave keeps running unless we give it a whack!
Hi firstly to see if it is producing energy, buy some 5mm light emitting diodes from an electronics store. cut off the leads close to the plastic body.
place in microwave and put on cook for max 10 secs, if the led's light up you have microwave energy, shut off the oven as soon as they glow otherwise you end up with a mess.
If you have energy then your problem is most probably the door interlock micro switches which after time do not operate properly. let me know the results and we can go further.
Feb 23, 2009 | Danby DMW1153 Microwave Oven
Turntable won't stop
Sounds like a door switch problem or stuck relay contacts on the control PCB. Do the light and fan run too or just the T/T??
Nov 07, 2008 | Jenn-Air JMC9158AA Convection Microwave...
Nov 27, 2007 | Maytag MMV1153A Microwave Oven
Maytag UMV1152 Microwave Oven Logo
125 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
