Question about Plumbing
How much would it cost to replace the water pump on a 96 eclipse?
  • 10,515 Answers
The water pump and timing belt and gasket is 166
The labor is 240
There can be some optional items depending on condition of idler pulleys and tensioner wheel. Tensioner wheel is 88, and idler pulley is 75, two fan belts are 30.
This job will range between 465 and 680 depending on optional items.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 24, 2011
Where is the water pump on my mitsubishi eclipse
the water pump is located behind the timing belt cover and is driven by the timing belt, if replacing the pump put a new belt on at the same time
Jun 27, 2014 | 2001 Mitsubishi Eclipse GT
96 Firebird, Replaced water pump, fuel pump - Now blows head gasket.
Get yourself another mechanic. This guy is not doing his job. It shouldn't cost $1600 to change a water pump and fuel pump. No proper mechanic would remove a thermostat to replace the O-ring and put the old thermstat back in. It wouldn't be uncommon for the coolant level to drop after changing the thermostat. It probably only needs to be topped up. No, the motor doesn't have to come out to replace the head gasket and I don't see it costing $2500. Before you spend any more money there, take the car somewhere else and get another opinion. I bet that if you fill up the coolant bottle for 2 0r 3 days it will stop losing coolant. Hope this helps.
May 10, 2012 | 1998 Pontiac Firebird
I have a water leak on my 96 camaro. It has a 3.8 v6 engine. The water is leaking, not from the water pump itself but from behind the part the water pump mounts on. Not immediately behind the water pump...
It is your Lower Imtake Manifold gasket (LIM). Late Production Camaros and Firebirds used Dex-Cool coolant which nortoriously caused the LMI to actually disintegrate. The failure of the LIM allows coolant to leak to the exterior of the engine as well as into the interior of the engine eventually getting into your oil. Check your oil for a brown milky color... if you have it immediately drive your car to you favorite repair shop and replace the LIM gasket. The GM 3.1L, 3.4L and 3.8L engines are famous for disintegrated LIM gaskets and a good shop will have replaced 30-50 of these in a year. The LMI is part of the reason the public dissed Pontiac and eventually led to its demise (not to mention bad management at GM). Find a shop familiar with the LIM problem and it shouldn't cost more than $500 to replace (or less). If you have any mechanical skill you can replace it yourself... the gasket kit costs about $35 at NAPA AutoParts and it takes a whole Saturday if it's your first time. I just finished replacing the LMI on my wife's '94 Firebird.
Mar 13, 2010 | 1996 Chevrolet Camaro
Were is the fuel pump relay in a 96 eclipse gs 2.0
your fuel pump relay is located next to the Master Cylinder,
you have three relay the close to the master cylinder is your fuel pump relay.
Let me know
Sep 27, 2009 | 1996 Mitsubishi Eclipse
Fuel pump relay
No --You know that it was not fixed the first time or you have multiple problems. TAKE IT BACK
Sep 26, 2009 | 1996 Mitsubishi Eclipse
96 eclipse electrical diagram for getting dc
If you send me your email address, I will send you the wiring diagrams for you car. Outdoorsman592003@yahoo.com
Sep 08, 2009 | 1996 Mitsubishi Eclipse
Engine shut down
regularly clean the carburettor of the car
May 17, 2009 | 1996 Mitsubishi Eclipse
Plumbing Logo
35 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
