I cant figure out how to make this antenna work with my tv
    Master:
  • 525 Answers
Antennas are a thing of the past. Everything has gone digital including television stations. Get yourself a digital converter box.
Posted on Mar 24, 2011
On menu I cant find the antenna to search for channels dont have cable
Change the input selection to whatever it calls it to connect to antennae
Feb 11, 2015 | RCA 20F420T 20" TV
Cant tune channels
It sounds like you need to do a complete installation as if TV were new.
This is done from installation menu
Feb 14, 2014 | RCA Televison & Video
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
Tv wont work with antenna
There should be an antenna to receive local transmission signals.
Apr 01, 2013 | Emerson CR202EM9 TV
HELP ME FIX MY WET TELEVISION
If the T.V. itself got wet you need to remove back panel to insure it dry completely. If there is anything that looks as though it is burnt on it then do not try plugging in because it will only do more damage. if everything looks to be normal and there is nothing looking as though it is burnt or dicolored then you need to take it to a repair shop or figure out what is burnt or discolored and find that part and replace it yourself. If it is the Antenna then you will problably be better of replacing it because tv antenna are designed to have direct lines meaning once a line has been cut or burnt or damaged it cannot be fixed and would be cheaper to replace the entire wire.
Jul 03, 2012 | Protech Televison & Video
I want to use an antenna on my emerson 2703 flat screen, but the menu doesn't have an antenna option . how do i get the antenna to work?
either you plug the antenna in ... or you cant use an antenna and have to buy another which allows antenna
Feb 17, 2010 | Emerson EWF2703 27" TV
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
Toshiba 50h12-reception problem with ant 1 & 2
the tv has a built in decoder. if its scrambled it may be on the wrong setting. try resetting tv to factory settings and see if it sorts its self out. if not it may need the av board changing as it has a fault with the decoder chip.
May 23, 2017 | Toshiba 50H81 50" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
