Question about Philips 50PFP5332D 50 in. Plasma Television
I replaced three cans. they were bulged on the top. i plugged the tv in and it did the same thing. i said it blinks 4 times fast but it is only three. blink code says 3=RESERVED. i pulled the the y-sustain plug off the power supply board and it does the same thing blinks 3 times fast. when it is powering up i hear a popping noise and then 2 green lites just to the right of where power cord plug is, they come back on then it pops again they go out, the 3 time it pops, lights go out, they stay out and the red light on the front blinks 5 slow , 3 fast. is there a place i can a picture so i can see where the y=sustain, power and where is the low B+fuse thank you pawpa28
    President:
  • 662 Answers
Philips lists 3 models of your TV:
1) 50PFP5332D/37
2) 50PFP5332D/37B
3) 50PFP5332D/37E
User Manual for your TV (actually for the 50PFP5332D/37E):
http://download.p4c.philips.com/files/5/50pfp5332d_37e/50pfp5332d_37e_dfu_aen.pdf
The user manual doesn't document the logic board blink codes for errors.
What this tells me is that the TV went thru two revisions before reaching version E.
in case it helps: Philips Customer Support: 1-888-PHILIPS.
If they can't help otherwise, they can at least tell you if your set is eligible for warranty service.
Posted on Mar 24, 2011
Toshiba TV you when I turn it on it runs for 10 minutes then it shuts itself off light blinks three times pause three more blanks then it turns itself back on runs for minute then repeat
Use a canister cold spray and take a wooden pencil and manipulated some parts on the print , resoldering parts and coils and lalso ook for top/bulged capacitors to replace .
Feb 20, 2016 | Toshiba Televison & Video
When power it'll blink three times and shuts off
It is probably the power board. When the capacitors on the board fail they can make a hissing noise. If you look at the board and the small cylindrical things on the board ( which are the capacitors) are bulged on top instead of flat this indicates a failed capacitor. The board should then be replaced. Hope this helps.
Jan 01, 2014 | RCA D52W19 52" Rear Projection Television
I havea Sony KV-40xbr800 screen won't turn on red light blinks 6 times, tried plugging directly into wall outlet & no picture still. Any help please ?
Power supply. Disassemble and be careful tv is not plugged in. Check capacitors on power supply for bulges on top. Replace but make sure u deenergize before removal by touching the two poles together. I use a small nail file
Aug 08, 2012 | Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm...
I have a 42PFP5332 which doesn't turn on. When plugging in the power the green led on the power circuit board turn for a few seconds and then blinks for 9 times. After that it blinks for 10 times
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Philips 42PFP5332D 42 in. Plasma...
My sony kdl 40 u 2530 e is not staring properly. the red led signal blinking 4 times periodically .any idea about the problem? If i turn off tv for hours then it starts for 2 minutes and again the same...
The tv power supply board have problems and the caused,check the tv power supply board have it fixed or services by u or tv tech.most likely those capacitors parts are dying on the tv power supply board like bulging or puffing up.Take the tv aparts,check the tv power supply board that board where the power a/c cord plug into it.Carefully check for capacitors parts for bulging and puffing up on to it tops.Changes all these dying capacitors,tv should be work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 18, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sounds like it's turning on. The power light goes out and the standby light blinks 4 times and keeps repeating that.
The tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Ur power supply board might have dying capacitors parts.U have all the tools,can u also do basic soldering and understand basic eclectronic?Yes,check all over the power supply board for dying capacitors parts.These dying capacitors alway bulges or puffing up on it tops.Replaced all these dying capacitors are bulging or puffing up on it tops.Will solved this probelems.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement
Jan 13, 2011 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Our TV will not come on, the standby light is the only thing that happens. We have tried unplugging everything then re-plugging but nothing changes, the light continues to blink. It blinks twice then in...
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care.....
Aug 15, 2010 | Televison & Video
Wont turn on
Hi
With the back removed from the Tv look at the power supply for swollen or bulged capacitors on top, they may even leak a brown like liquid substance from them and are usually valued around 1000uf / 10v.
This is a common fault of these power supplys, any you suspect change with a higher voltage but always keep the same uf.
Lets say 1000uf / 25v
Hope this helps.
Apr 09, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
MY TV DOESN'T TURN ON....POWER LIGHT BLINKS
power supply board is dead and needs to be replaced. very common problem.
Oct 30, 2009 | Samsung LN-S4051D 40 in. LCD Television
Will not reset
4 caps in the standup shielded module get bulges on top--obvious failure. Replace them. Seen it many times
Oct 10, 2006 | Mitsubishi WS-55513 55" Rear Projection...
Philips 50PFP5332D 50 in. Plasma Television Logo
1,019 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
