Question about Adobe Computers & Internet
How to use the downloaded Brush? - Adobe Computers & Internet
  • 495 Answers
Take your brush file, go to your C:\ drive (or wherever Photoshop is installed), find Program Files, click on that folder, then look for the Adobe folder, click on it, look for Photoshop CS3, click on it, look for Presents, click it, then clock on brushes and put your brush file in there. Volia.
Posted on Mar 24, 2011
In photoshop shape dynamic is again and again missing
If you are drawing with brushes.
With the exception of the pen tool, the brush tool is the most versatile tool in Adobe Photoshop's arsenal. There are a multitude of tasks for which you can use the brush tool. including retouching, freehand drawing and stamping. However, in order to truly exhaust the brush tool's potential, you need to understand how to change your brush style, import brushes into your toolbox and make your own brushes.
Changing Your Brush's Size and Shape b> To change your brush's and shape, press the F5 key on your keyboard to open up the brush window. A number of pre-formatted brushes will appear, along with a menu of options you can use to customize your brush. Choose the brush that best fits your preference by clicking on its display square on the right-hand of the brush window. Use the sliding bar under the heading "Master Diameter" to increase or decrease your brush's . You can further change the texture, shape or dynamics, or further stylize your brush, by checking any of the boxes in the brush window's tip shape menu on the left. b> Importing Brushes b> You can download custom brushes from the Internet in variety of styles and shapes. To load a brush set you have downloaded, select the brush tool in the basic toolbar and click the small arrow next to the brush indicator at the top of the screen. Click the arrow next to the indicator to open the brush menu. Choose "Load Brushes." When the file selector opens, choose your new brush file--brush files will always have an .abr extension--and click "Load." Your new brush set will be added to your brush palette. Creating Your Own Brushes b> Before creating your own brush, you need to have an image or freehand drawing that will serve as the basis for your brush. Brushes can be simple or incredibly detailed depending on the image used to create them. To make your brush, open the file containing its design. To make the best brush possible, it may be necessary to tweak the file. If you are using a color image, convert the image to grayscale by choosing the "Image" drop-down menu from the top of the screen and choosing "Mode" and "Grayscale." Select "OK" to discard the color information. Continue to tweak the image by choosing the "Image" drop-down menu again and selecting "Adjustments" and then "Levels." Using the slider bar at the bottom of the screen, adjust the settings until you achieve an image that has a sharp contrast between its black and white portions. Once you are happy with the image, choose the "Edit" drop-down menu from the top menu and "Define Brush Preset." Name the brush in the pop-up window that appears. You can now use your brush and further customize its shape and style by using the basic brush preset manager at the top of the screen. Hope this helps.
Dec 22, 2012 | Computers & Internet
I can't switch from the brushless option to the rotating brush option.
You should be able to turn the brushbar on using the brush control on the cleaner's head, turning it from the 'Hard floors' to the 'Carpets' setting. For further guidance, you might find it helps to refer to the user guide supplied with the cleaner. In case you don't have this to hand, you can download a copy here:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
However, if the brushbar doesn't seem to be rotating when the brush control is set to 'Carpets', it's probably best if you get in touch with us directly so we can help. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Oct 17, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The brush does not spin when engaged. Everything else is working fine.
When you remove the brush, the release button resets a trip fuse on the pcb. If that does not work at sounds like you have either blown the rectifier pcb or burnt out the DC motor that is in the brush head. You can get a complete replacement brush head for 70 pounds.
Jul 28, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
I have a kenmore progressive upright vacuum can't find the reset
I would try turning the brush by hand to see if there is any resistance. I'm not aware of a "reset" switch that is end user accessible. If the vacuum still has suction, make sure you are using it on a carpet. The brush doesn't turn on wood or vinyl flooring.
Nov 05, 2017 | Kenmore Vacuums
Need manual for bissel powe steamer brush select
User Manuals can be downloaded from the Bissell website
Feb 07, 2010 | Vacuums
Brush roll turning very slow
You might need to clean out the roller brush. Here is the manual that has instructions:
Owner's Guide (1.5 MB download)
If you need a new belt you can get it here:
Eureka style D belt
Nov 21, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Need a manual for a RYOBI Model RY30530.
go to www.managemyhome.com and download a free copy of the manual.
Jun 26, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
How to install new brushes to photoshop
Hi..
there is no installation for brushes..
u have to load them to photoshop..for that
select brush tool..
clcik on brush options pane..
at right side(beside brush size) click the black arrow..
select load brushes or replace brushes..
browse ur downloaded file..thats all..
to change dem to default brushes...simply click reset brushes..
Dec 19, 2008 | Adobe Photoshop CS2 for PC
Computers & Internet Logo
46 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
