Question about AOC 416Va 24" LCD Monitor
I was using my AOC 416Va monitor and turned it off for an hour for dinner. When I returned, I powered if on and now it will not show a display. I have rebooted both computers (connected to a PC and MAC Mini) but get nothing. My second screen (dual screens on both MAC and PC) functions fine and shows a display. The behavior I see is that when I press the button to switch displays (Mac or PC) there is a flash where the screen breifly lights up, but then goes back black.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Try checking the Video cable (probably HDMI) try replacing the cable.
Posted on Jun 10, 2017
3 Suggested Answers
  • 33 Answers
SOURCE: aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Posted on Jul 10, 2008
  • 2567 Answers
SOURCE: When I turn on my MAc G4 my 19
This is more likely to be a problem with the connection between the graphics card & the monitor. The connection might be loose at one of the ends. Another possibility is that the cable connecting the graphics card & the monitor is damaged & needs to be replaced. Also, it might be because of a damaged VGA socket. Check the VGA socket for broken or bent pins.
Posted on Oct 31, 2009
Power led brightly on but no display on AOC S5G10
It is understood that your AOC monitor is not working, you had followed troubleshooting steps like connecting VGA and Power cable from monitor to computer and the monitor panel light is ON but still no display. You have tried connecting another monitor and it is working fine, so it is advised to contact AOC support to check if the monitor is under warranty and it can be replaced or repair. To help you do these, please follow the link given below:
http://us.aoc.com/aoc-technical-support/?page=contact-technical-support
GuruAid.com
May 24, 2016 | AOC Computers & Internet
Aoc monitor shows error message while connecting with i ball tv tuner
What resolution is the AOC monitor capable of using?
What is default resolution of the device you are connecting?
If the default is 1080P and the monitor is not 1080P capable then that would be your problem. You could attach to another monitor or HDTV and possibly turn down the resolution then try again.
Feb 05, 2016 | AOC 917Sw 19" LCD Monitor
Used the cd that came with the monitor. Now size, pixels, etc. are wrong, so much so that it cannot be used. How do go back to pre-cd-use? Thank you AOC 2036S Serial # Q81A8HA267758 LCD 20 inch...
If You really can't read anything on the screen this wont help. If you can make out a bit, then right click on a vacant area of your screen, then select "properties". On the Display Properties Menu, select "Settings", then select "Advanced". This will bring up a menu that shows your Monitor and Display Driver info. Select "Display", then select "Properties", then select "Driver", then select "Roll Back Driver". This will restore the old driver for the Display. If this doesn't help, go through the same menus again, and on the "Monitor and Display" menu select "Adapter" instead of "Monitor", and roll back that driver.
Best of Luck
Dec 08, 2010 | AOC 2036sa 20"TFT LCD Monitor
My AOC 19" color display turns red, whats the reason of this?
my 3 aoc tft1560ps 15inch back light is off plsss help me capacitor replace already
Jun 26, 2010 | AOC LM729 17" LCD Monitor
No display on AOC 17" CRT Monitor
My AOC 17" flat monitor (model number P7S80) is not displaying properly. Only 80% of monitor is displaying and the edges at the bottom are tapered of. If somebody is having a solution please post it.
Sep 07, 2009 | AOC CT720G 17" CRT Monitor
On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
Aug 29, 2009 | AOC 917Sw 19" LCD Monitor
AOC LM725 LCD Monitor
try looking for bloated caps, check all diodes... see if its not shorted/leaking and finally check the power regulator ic if its not shorted! note: some capacitors and diodes are very tiny, you should use a lens with good amount of light...
if it does not help..... well, what the hell? try pouring some gas, then light it up! that should solve the problem, at least it turned on right? hehehehe!
Mar 21, 2009 | AOC LM729 17" LCD Monitor
Aoc lm725 display off after few seconds
Jul 10, 2008 | AOC LM729 17" LCD Monitor
Aoc 5en no display
I alreeady encountered this problem. I fix it temporarily.... I just turn it off, Press all the Function btn and the recall btn, then pres the On btn... wait for 2 sec then release the func, recall btn. Then I already able to use the PC for about o hours without interrupted signal (on/off). I call it temporary fix because whenever you turn off the Monitor, you have to do the same process again..
Try it it can help.. Thnaks.... If you already find solution , maybe you can share it to me too .. Thanks..
Jun 25, 2008 | AOC 5 En 15" CRT Monitor
AOC 416Va 24" LCD Monitor Logo
37 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
