Question about Eiger Vision EVP-152FP 15.2 in. Car Monitor
Model # evp-104dl,how do u wire it to work,i purchased 1 with no manual............thanks.mike
I have a flashing code of 3-4 what is it
David,
DTC 3-4 at idle means the EVP voltage is above the closed limit.
Translation: The EVP sensor (EGR valve position) is unplugged or the wiring between it and the computer has an open. The EVP sensor has a 3-wire plug on it, and you can find the EVP on top of the EGR valve (that's the metal mushroom between the intake and a pipe coming from the driver side exhaust manifold (on a v-8)).
It's also possible that the EVP sensor is bad (open).
Good luck.
Mike M, 35-year Phord Phixer
Nov 17, 2014 | 1995 Ford Bronco
I have a part that I don't know where it goes on the NS1200. I need to see a schematic of the gun please. Where would I get this?
The NS1200 changed slightly in 2007, so if it was purchased before 2007, here is the parts list and diagram:
http://www.crosman.com/pdf/manuals/NS1200-EVP%20Phase%201.pdf
but if it was purchased in 2007 or later, then this is the parts list and diagram:
http://www.crosman.com/pdf/manuals/NS1200-EVP%20Phase%202b.pdf
Dec 06, 2010 | Crosman (4032)
I have a 2005 Dodge Dakota V8 4x4 My check engine light turned on. I took the truck to Autozone to have them hook up the machine and see what the problem was. It said I have a bad EGR Valve. I havent...
It can affect mileage, but it might not be the valve. EGR systems tends to get clogged by gunk. Take the valve off and see how dirty things are. If the system is clogged up, take apart as much as you can to clean it up. You can test the valve for operation with a good scanner (autozone doesn't do this--they just tell you the code). Here are instructions from autozone.com:
Linear EGR Valve Diagnosis
The linear EGR valve diagnosis procedure varies depending on the vehicle make and model year. Always follow the recommended procedure in the vehicle manufacturer's service manual. The scan tester may be used to diagnosis a linear EGR valve. The engine should be at normal operating temperature prior to EGR valve diagnosis. Since the linear EGR valve has an EVP sensor, the actual pintle position may be checked on the scan tester. The pintle position should not exceed 3% at idle speed. The scan tester may be operated to command a specific pintle position, such as 75%, and this commanded position should be achieved within two seconds. With the engine idling, select various pintle positions and check the actual pintle position. The pintle position should always be within 10% of the commanded position. When the linear EGR valve does not operate properly:
  • Check the fuse in the 12 V supply wire to the EGR valve.
  • Check for open circuits, grounds, and shorts in the wires connected from the EGR valve winding to the PCM.
  • Use a digital voltmeter to check for 5 v on the reference wire to the evp sensor.
  • Check for excessive resistance in the EVP sensor ground wire.
  • Leave the wiring harness connected to the valve, and remove the valve. Connect a digital voltmeter from the pintle position wire at the EGR valve to ground, and manually push the pintle upward. The voltmeter reading should change from approximately 1 V to 4.5 V.
436f9a1.jpg Linear EGR valve circuit. Courtesy of Chevrolet Motor Division-GMC.
If the EGR valve did not operate properly on the scan tester and tests 1 through 5 are satisfactory, replace the valve.
Here is what your valve looks like:
If you have more questions, please let me know.
Oct 13, 2010 | 2005 Dodge Dakota
Wine cooler FWC20T is not working , purchased 4/2009
Mike, what I would do is get a stick of dynamite( not really) Go to an appliance parts house with the model and serial # of the unit. You may still be able to purchase the board in question from them. If they can't help you I would find a store that sells wine coolers and ask them. Unless the company you bought this cooler from had a patent on the circuit board then they are mostly generic. You may have to wire the board up a little different but the new board's information paperwork will tell you the wiring diagram for the unit.
Good luck hope this helped you in some way
Dave
Jan 29, 2010 | Refrigerators
I took apart my 66 powermaster bb gun and i cant put it back together? can u give me a diagram of picture
C66-OM
C66-EVP & PL 1 & 2
Powermaster. Pneumatic, BB repeater, .177 cal., single shot pellet. First variant w/zinc receiver. 1983-1988 Some parts are available. 66 pdficon.gif
C66-OM
C66-EVP
Powermaster. Pneumatic, BB repeater, .177 cal., single shot pellet. Plastic receiver. 1988-2001 Some parts are available. 66 pdficon.gif
C66CLIP-OM
C66CLIP-EVP
Powermaster. Pneumatic, BB repeater, .177 cal., single shot pellet. Plastic receiver and 5 shot manual clip. 2001-Present Some parts are available
HERE IS MANUALS I FOUND..HOPE THIS HELPS..
Apr 11, 2009 | Crosman (4032)
I have a Honeywell H220a humidistat and have everything hooked up, but I cannot get the wiring to work. The wiring diagrams do not include the selanoid that comes with the humidistat. Any suggestions. The...
Thanks for your question Mike,
The wiring for your humidistat and solenoid are fairly simple, you will need 24volt t-stat wire, you have the two wires at the Solenoid, one wire goes to the terminal board at the furnace, it connects to the (c) or common terminal, the other wire connects to one leg of the humidistat, run another wire from the other leg of the humidistat, to either the HUM terminal on your furnace circuit board, make sure its not a 120v leg, should say in the owners manual, if if is or your not sure, connect that same leg to the (w) terminal at the furnace, this way it only comes on in heating mode, some models need a second 120v-24v transformer, but you would still wire it through the same way, only exception is that you have to hook up 120v to the transformer, and route your wiring like I told you above but through the transformer to complete the circuit, hope that helped you out Mike, please let us know, thanks again, mr.grzz
Jan 10, 2009 | Honeywell HE220A1019 Whole House...
Motherboard Manual JFP1 Connector
Hi Pierre,
Though many MSI boards are similar, it would help if you would include the model number of your MSI board?
(Many times Fixya does not show your current correct model number but you can add it into your posted question). The pic's included below belong to the MSI K8N Neo3MB.
Look to page 2-16 (In manual). What is not included in the manual are the wire colors. Case wire colors do vary from case to case.
The colors: red, blue, green, light blue, light green & light red are commonly ( + ) = positive. The colors white & black are commonly ( - ) = negative. Some case wires-connectors are marked +/-, some are not marked. (The common color of each set of case wires is usually ( + ), positive)!
If your board is not like the pic's above than include your model number & I'll adjust my answer.
Good luck Pierre!
Mike
Nov 08, 2008 | Intel Motherboard
VPR matrix 2250 motherboard configuration to connect the wires I disconnected to change another motherboard. Now I cannot reconnect all the wires. Can you help me? Thanks, Teg
You Need to go to The Motherboard Manufacturers Web-Site.
And Download A User Manual For That Model.
You can,t guess Or assume which wires go where, or your likely to damage the mainboard.
** Please Note** All motherboards Differ Slightly Unless you Purchase A Identical replacement.
Hope This Helps Mike @ Compurepair.
Feb 26, 2008 | Computers & Internet
Eiger Vision EVP-152FP 15.2 in. Car Monitor Logo
74 people viewed this question
Top Eiger Vision Car Audio & Video Experts
xxxxxx xxx
Are you an Eiger Vision Car Audio and Video Expert? Answer questions, earn points and help others
