Question about Krups Bravo Plus 872 Espresso Machine
We baby this ****** - distilled water only since brand new, and never missed. The steamer just started coming on while in the coffee making mode - can this be remedied? We are now out of water before coffee is 2/3 done.
2 Suggested Answers
  • 8 Answers
SOURCE: My espresso quit working and the steamer wont work
how doomed it is depends on how handy you are...
First check if the unit has an illuminated power switch or indicator of any kind. If so check if it is lit. If it is not lit, it may be as simple as a power cord problem which can be checked by a voltmeter.
Otherwise, several things can go wrong:
1- a loose internal connection. This will require redoing the connection in a similar manner to the original.
2- a bad heater. This will require a replacement parts
3- the thermal protection is blown. This can be purchased from an electronic component store for a dollar or two and will require soldering or crimping.
All of the above requires basic electrical knowledge and a voltmeter.
If you are not handy and the unit is worth more than a 100$ then a local repair shop may be able to fix it for 40$ to 60$ (mostly labour as parts will never exceed 10$)
Posted on Mar 15, 2010
Testimonial: "Thank you so much however the vinager cleasing worked! I will keep this on hand in case of future use. Thanks again (:"
My steamer is not steaming. I thought the holes were pulgged up with old water left in steamer. Is there a way to unplug it. I have put boiling water through it.
Try a tank of 1 part white vinegar and 3 parts water and see if that does not clear up the problem. Be sure to follow that with three fills of distilled water to rinse out any residual vinegar or calcium deposits left by using tap water. Many steam appliances are tap water rated, but a gallon of distilled water is about $1.25 and will save you this headache. Don't use plain tap water or mineral drinking water in steam appliances - it's asking for trouble.
Nov 19, 2017 | Coffee Makers & Espresso Machines
Low flow, pump starts normal and within a few second becomes quiete
Hi There,
Try descaling - sounds like the the solenoid is blocked with lime - don't use vinegar! Try that 1st.
If machine is more that 2 years - not regularly descaled or no water filter replaced regularly, it probably the solenoid.
It the machines is 4 years + replacing both would be a good idea. Gaggia classic solenoid Vibration pump Gaggia Rancillio
Jul 06, 2017 | Gaggia Baby Coffee Makers & Espresso...
Water dripping not running when making coffee
First question:Are the rest of the machine still working correctly?
Second question:How was the waterflow before descalling?
Here are short description on how most of these machines work.
It will have a cold water reservoir for filling with cold water with some sort of water full sensor, it will then be followed with a high pressure pump.which are used to fill the boiler.After the boiler it will then go out to your to disspencers.in your case the steamer and one for coffee.The outlet at the boiler will propably be split in two by using valves.
To come back to your problem i assume it had a waterflow probleme before you descalled.When you are descaling your machine their are some times pieces of scale that is not propably disolved by the descaling process which will get stuck in the pipe work acting as a valve
causing waterflow problemes.
The other probleme might be that your water dispencers valve might be faulty either by a poor supply(power) or the sollenoid is starting to size up.
Just switch of the machine when taking of any covers you are working with water and electricity which do not mix well
Mar 26, 2012 | Gaggia Baby Espresso Machine
No water coming through coffee filter. I have descaled twice. You can hear the pump but no water and then it goes quite with no water. I have tried to prime the pump but still does not work. The steamer is...
If you open the steam tap while the pump is running does water come out? if so then you might have a blockage in the coffee solenoid or the bottom of the boiler. Do you hear a 'click' sound when you hit the coffee switch? If not the coffee solenoid may not be operating. The most common cause of the problem you are having though, is scale flaking off the boiler walls causing a blockage where the coffee water comes out. Try hiting the coffee switch, opening the steamer and then if water starts pumping out, close the steamer and see if water starts flowing out the coffee group. Do this without the portafilter (coffee holder) in place.
If you do get water flowing trough the group, try backwashing the machine.
If these things dont help then you should take it to an authorised repairer or open up the boiler yourself if you are a handy person and have access spare parts. Good luck, these machines can make a great espresso when in the right hands and working order.
Dec 01, 2010 | Gaggia Classic Espresso Machine
My baby gaggia dose (brand new out of the box) leaks
HI
Call who ever you bought it from and have them diagnose the problem. I think you have a disconnected hose or something worse.
Nov 18, 2009 | Gaggia Baby Espresso Machine
No water coming through but steamer working
Check the shower screen it might be clogged.
Aug 11, 2009 | Gaggia Baby Espresso Machine
Is there a product to run through a rowenta pro garment steamer to eliminate build-up?
To start with, use distilled water for steaming. This will prevent calcium build-up. I buy bottles of distilled water for ironing/steaming only. I have never had calcium build-up from using distilled water for ironing/steaming. Do not use tap water!!!
You can buy some CLR (stands for Cacium, Lime & Rust) (can be found at Walgreens, CVS, Target, Walmart, etc.). You can run this product through your steamer to eliminate build-up.
May 14, 2009 | Rowenta Commercial Garment Steamer - White
GAGGIA BABY. NO WATER COMING OUT.STEAMER FINE
I had exact same problemeven took entire machine apart - all fine. Solution is very simple... descale with Gaggi descaler solution. Remove filter and block, mix solution with 1.5L of water, turn on for 20 seconds, wait 20 rinse through steamer, wait 3 minutes and repeat until all solution used - rinse compeletly with clean water
Jan 19, 2009 | Gaggia Baby Espresso Machine
No water getting through to the coffee holder
If the machine is making very load noise while trying to make coffee ie. water to grinds or steamer this is more than likely a pump problem.
Dec 26, 2008 | Gaggia Baby Espresso Machine
New gaggia baby class "d" espresso mch
it seem the pump is not prying itself you have to inject water try with a turkey blaster the pump to put juice on a turkey fill it up with water start the machine inject the water in the water hole try that out let hope it work if not you have warranty good lock
thanks for using fixya
pierre
Feb 28, 2008 | Gaggia Baby Espresso Machine
Krups Bravo Plus 872 Espresso Machine Logo
91 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
