Question about Whirlpool Duet GHW9150P Front Load Washer
SUD Code appears on Whirlpool Duet Washer Troubleshooting says to Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) - how do I do that?
    Sergeant:
  • 170 Answers
Sud means over suds are you useing he soap maybe too much.......
Posted on Mar 24, 2011
I have an older Whirlpool duet that reads sue code.It has water that has not drained fully with a odd sound towards the rear of machine possibly a short in board?
Is it SUE or SUD code?
Sud SUDS LOCK (Overdose of detergent detected during the wash cycle) The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Dec 06, 2013 | GE WBSE2090A Top Load Washer
I'M GETTING A SUDS F35 CODE
Hi
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Why do I get a sud code flashing? I use only HE detergent and still have a problem.
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.Check the drain hose and make sure it is not plugged or kinked.
Check/Clean Drain Pump Filter of foreign objects
Check Drain Pump Check Pressure Switch Check CCU
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHAT DOES THE CODE MEAN WHEN IT SAYS SUD
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Thank You
Sep 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F35
Hi, Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Take care
May 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It says sud on the front wont start do i drain it manuelly?
To drain manually you'll need a siphon hose or small pump. A siphon hose can purchased at an auto parts store for about $5 and you can drain the water into a bucket.
According to Whirlpool for a SUD error:
? If too much detergent was used: —Run the unit through a Rinse/Spin cycle. —Run a Normal cycle without adding any detergent. This should clear the unit of the excess detergent. 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU). 4. Check/clean drain pump filter of foreign objects. 5. Plug in washer or reconnect power. 6. Check drain pump. 7. Check the pressure switch. 8. Verify CCU operation by running a Diagnostic test or any cycle.
May 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool error SUB
To fix this problem do the following:
  • Check Drain Pump
  • Check CCU
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet front load wash machine- it keeps freezing up and flashes the word sud
this is what the code book says that could be you problem. Overdose of detergent detected during the wash cycle. this may signify a bad pump, an extra heavy load, excessive detergent or excessive suds.
If to much soap was used run the unit through a rinse/spin cycle than a normal cycle without add any soap. this should clear the unit of the excess soap.
check the drain hose and make sure it is not plugged or kinked.
check wire harness connections to the drain pump,pressure switch, and central control unit.
check/ clean drain pump filter of foreign objects.
check drain pump
check the pressure switch
check CCU.
Replace failed component. Hope this helps
Nov 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer flashes F35 shortly after start
From the book :
SUD Code=
or kinked.
cycle.
Feb 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Machine stopped and says "sud"
Sud SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
  • Check Drain Pump
  • Check CCU
Jul 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
951 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
