Question about Briggs & Stratton Garden
Montgomery Ward Riding Mower/ Briggs Stratton 12.5 hp engine... makes a humming sound and won't start when I turn the key, sounds like a starter selenoid thing? It won't even begin to try and turn over... battery's fine, spark plug's fine, gas, oil, all fine.
num1wrench
  • 14 Answers
SOURCE: i have montgomery ward riding mower and cant
Line up the deck where it needs to be, and lower the lever....the hanging links should come close to where they go, then use the pins (or whatever) to insert into the hanging levers....Leave the handle lowered, then hook the belt onto the engine pulley, then line it up with the pulley on the deck...you may have removed the belt guides, so put them back on...They help keep the belt from falling off.
Check your work to make sure things look right...You should be done.
Posted on May 10, 2009
  • 86 Answers
SOURCE: gas comes out of spark plug hole
You have a Float problem you also make have gas in oil.
Posted on May 12, 2009
  • 376 Answers
SOURCE: Murray riding mower won't start
Sounds like a defective starter solenoid.
Posted on Jun 18, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
  • 496 Answers
SOURCE: Snapper Briggs and Stratton riding mower
It's mounted in an enclosure directly over the carburator.
Posted on Sep 22, 2009
Why won't my yard man briggs and stratton 7.5 hp engine crank
Check for blown fuse if good put a light tester on the starting then turn the key if your tester lights up then you know that the stater is bab if it does not then you do not have power to the shotch. One red wire should have power all the time and the other red wire should have power only when the key is on.
Jun 20, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
12 hp briggs and stratton starter
the battery may be to weak try jumping it with your car its the same voltage the starter needs to spin out fast to in gauge
Mar 29, 2012 | Husqvarna Garden
I have a old Snapper riding mower with an 8hp Briggs and Stratton engine, The other day it wouldn't crank so I changed the switch and the solenoid, the battery was fully charged and it still won't...
make sure thers power going into the starter
if there is then see if the starter is siezed, try turning the fly gear, but not just up against the flywheel but try turning the starter backwards to see if it moves
Jul 29, 2011 | Garden
Riding mower won't start
clean all your battery connections from battery to starter and selonoid connections and ground cable also where it connects to frame
May 23, 2010 | Garden
Lawn Mower wont start
You need to obtain a manual for Briggs & Stratten engines. All the info you need will be in it. The most common cause for non starting in these engines is "Tight Tappets" Wether it's an OHV or the old "L" head engine, because they rev and work so hard, the valves seat themselves deeper into their seat which reduces the valve clearance. There is no adjustment on the older "L" engines, so you have to remove metal from either the valve stem, ot the lifter itself. I have in the past done this in situ with a point file, but it is a tedious job. Otherwise you must remove the head and take out the valves and grind the stems. A tricky task and probably should be done by a mechanic.
Apr 06, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
PLEASE HELP! My husband is driving me crazy about Riding Mower
Sounds like the gear on top of the starter is stuck or broken. Inspect starter. If it's broken, the starter must be removed to replace the starter drive. You may need to buy a Starter Drive Kit. If you starter has a flat piece on top held on by a retaining ring, it's part # 696541. If you have the older type starter with roll pin holding the drive on, you need part # 696540. You probably have the first one. To install the retaining ring, use a 3/8 socket to tap it into the groove. Dwain
Jun 17, 2009 | Briggs & Stratton Garden
Craftsman 19.5 briggs & stratton mower new battery, new solenoid new brushes on starter. fuse & wiring good shape. when i attemp to start ignition all it does is click.
Check the voltage on the battery to see if it is 12 volts or higher. If not, charge battery.
Then check all starting-related electrical connections-- sounds like there is a dirty connection somewhere if the battery is charged.
May 03, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
258 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
