Question about Philips GoGear SA3125/37 MP3 Player
My gogear vibe keeps on getting frozen after updating and charging
  • 436 Answers
I actually have the exact same issue with my phillips. Make sure you dont have overloaded drive. thats when i seem to lock up. i try and leave a 1/2 gig buffer in there.
Hope it helps
Posted on Mar 24, 2011
My philips gogear vibe is frozen and wont move from screen its on and wont power down, I have pluged it in to see if that will work and nothing, what do I do?
Try the repair function of the Songbird software and restore VIBE to the factory settings. Before you proceed, bach up your files stored on VIBE if possible because the following procedure erases all files you have on the player:
1: Launch the Philips Songbird on the PC
2: In the Philips Songbird menu bar (at the top), click on the Tools pull-down menu and then select Repair My VIBE.
3: Follow the on-screen instructions to complete the repair procedure.
I hope this will help you.
If you haven't Songbird it can be downloaded from Philips website: www.p4c.philips.com/
Thanks
gylacz
Apr 12, 2011 | Philips GOGEAR SA6045 MP3 Player
My Vibe ihas stop updating at 96%
sometimes it takes a while to update mp3s.Just keep an eye on it. dont push any buttons because it might make it take longer and if its finished updating make sure to put it to charge
Apr 08, 2011 | Philips GoGear ViBE Digital Media Player
My MP3 Go gear vibe freezes up when updating files
try to reboot it using the disk come with philip 4 gb gogear flash or download from internet
Mar 08, 2011 | Philips GoGear Flash MP3 Player
Go gear vibe has been frozen for about 25 min. wont shut off or anything
Hi, i stuck a pin in the reset hole, (to the right of the lock switch) and it shut it off, than all you have to do is turn it back on..
The Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
Unresponsive
1. Your GoGear may not respond to button presses from time to time. This is often caused by an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
GoGear Does Not Power On
Problems with powering up the GoGear are often the result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
In some instances there is an error with the device that is keeping it from powering on. Unlike the errors that freeze the device, errors that keep it from powering on cannot be cleared by pressing the "Reset" button. The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
Memory Full
The GoGear allows you to make voice or FM radio recordings and saves the recordings to the internal memory. The internal memory is limited and the GoGear may show the message "Memory Full" when trying to save recordings. When you receive this message, plug the device into the computer and delete any extraneous files or files you no longer want to keep on your device. This will free up memory so you can save more recordings or place additional music files on the GoGear.
Hope it helped..
Have a nice day.
Feb 22, 2011 | Philips GoGear ViBE Digital Media Player
Batterylife,GoGear Vibe 4GB how long between each charge, getting 5 to 6 hours.
The battery life is rated at 25 hours for audio and 4 hours for video. If the charge is not holding you can try ensuring device is secured while charging. If this does not work the battery is bad and should be replaced. This is not horrible news, batteries for the GoGear Vibe 4GB are only $10.00.
Aug 05, 2010 | Philips GOGEAR SA6045 MP3 Player
My Gogear Vibe MP3 is frozen on the playlist screen. Won't change screens, won't turn off, doesn't do anything when you plug it ino the pc
Try Resetting it, by getting a sharp edge (something) and pressing the button on the left side of the device..if that doesnt work, try waiting for the battery to die, the reset, then try charging it again. Hope this helps.(:
Jul 11, 2010 | Philips GoGear ViBE Digital Media Player
Gogear Vibe is ''frozen''
I just reset it, and it works great. Need to keep it updated.
Jun 12, 2009 | Philips GOGEAR SA6045 MP3 Player
New GoGear Vibe will not turn on after first charge!
This is not a solution to fixing the mp3 player, but I no longer need assistance, I returned the product for a refund.
Jun 04, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear SA3125/37 MP3 Player Logo
61 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
