Question about Dewalt Garden
Pump overheats - Dewalt Garden
    Master:
    Sergeant:
  • 411 Answers
Water cools the pump if its running with no water going threw the pump will overheat electric or gas?????
Posted on Mar 24, 2011
  • tonpalaipai Apr 01, 2011
    the pump is getting good water pressure but it still overheats
  • Freeman Jul 15, 2013
    Those this unit have a Thermal Relief Valve ,if it does it may not be releasing the pressure when the pump is in idle mode.
Can a bad tensioner cause an engine to overheat?
A bad tensioner can cause an engine to overheat in the sense that when a bad tensioner breaks, it will cause a loss of turning movement to all the accessories of the engine including the water pump, and when the water pump stops turning, the flow of coolant will stop and the engine will start to overheat.
Oct 11, 2016 | 1999 Cadillac DeVille
1999 Cadillac Eldorado ,overheating changed thermostat , overflow cap ,no white smoke coming from exhaust.hot blowing from heater
Are the cooling fans coming on ? Go under the hood in the engine compartment , with the vehicle running have some one turn on the A/C , do you see and or hear the cooling fans come on ? Could be the coolant temperature gauge is bad ! How many miles on the vehicle ? Ever have water pump replaced ?
Check for a loss of system pressure.
Is there a loss of system pressure?
Go to Step 2 yes
Go to Step 3 no
Inspect and repair any faulty hose connections.
Does the engine still overheat?
Go to Step 3 yes
System OK
Check for low coolant protection (-37?°C/-34?°F).
Is there low coolant protection (-37?°C/-34?°F)?
Go to Step 4 yes
Go to Step 5 no
Test solution. Replace the coolant if necessary.
Go to Step 5 yes
System OK
5
Check the water pump belt for low tension.
Is the water pump belt tension too low?
Go to Step 6 yes
Go to Step 7 no
6
Replace the water pump belt tensioner.
Go to Step 7 yes
System OK
7
Check for an inoperative thermostat bypass.
Is the thermostat bypass inoperative?
Go to Step 8 yes
Go to Step 9 no
8
Replace the bypass.
Go to Step 9 yes
System OK
9
Check the water pump.
Is the water pump inoperative?
Go to Step 10 yes
Go to Step 11 no
10
Replace the water pump.
Go to Step 11 yes
System OK
11
Check the radiator fins for obstruction.
Are the radiator fins obstructed?
Go to Step 12 yes
Go to Step 13 no
12
Inspect and clean the radiator fans.
Go to Step 13 yes
System OK
13
Check the cooling system passage for obstruction.
Is the cooling system passage blocked?
Go to Step 14 yes
Go to Step 15 no
14
Inspect and flush the system. Reroute or replace the hose if necessary.
Go to Step 15 yes
System OK
15
Check the water pump belt for damage.
Is the water pump belt damaged?
Go to Step 16 yes
Go to Step 17 no
16
Replace the water pump belt.
Go to step 17 yes
System OK
17
Check the cooling fans.
Are the cooling fans inoperative?
Go to Step 18 yes
Go to Step 19 no
18
  1. Inspect the electrical connector. Replace if necessary.
  2. Does the engine still overheat?
Go to Step 19 yes
System OK
19
Check the throttle body circuit flow.
Is the throttle body circuit flow restricted?
Go to Step 20
Go to Step 21
20
  1. Inspect the orifice and associated hose. Replace if necessary.
Go to Step 21
System OK
21
Check for a stuck thermostat.
Is the thermostat stuck in the closed position?
Go to Step 22
22
Replace the thermostat.
System OK
Sep 16, 2015 | 1999 Cadillac Eldorado
OVERHEAT
It sounds like there is a leak in the radiator. We can determine that it's a leak and not the pump. If it were the pump it would not last any time at all. You Must take care of the issue because you could easily overheat and can even seize the engine.
Repost and let me know if you have any further questions.
EJ Kudelka
Mar 26, 2012 | 1994 Honda Accord
I have a mazda 626 and it overheat on me and also my timing belt is lose can a timing belt cause a car to overheat and shut down
as the timing belt usually turns the water pump yes it is possible. i am not sure what motor you have in this but i would think you ar elooking at your serpintine belt as your timing belt is behind plastic covers and is not visable. maybe your serpintine belt runs the water pump and as it is loose then it will not spin the water pump causing it to overheat
Jan 05, 2011 | 1998 Mazda 626
HERE IT IS. I HAVE A 2004 PASSAT. IT OVERHEATS WHILE DRIVEING IN ABOUT 2- 4 MINUTES TIME. WHEN I STOP OR PUT THE CAR IN NUTREAL IT COOLS BACK DOWN IN ABOUT 15 SECONDS. BUT WHEN IM IN PARK I CAN IDLE THE...
you have a 1.8 liter turbo engine correct? it is the water pump that is driven by the timing belt. 100% positive this is correct i have replaced countless water pumps for this reason. the reason it overheats while driving is becuase the splines on the water pumps plastic impeller are gone and it is just freewheeling on the pump shaft. at idle the pump spins slow enough to get the impeller to turn. very very very very common. replace water pump timing belt and tensioner.
Nov 02, 2009 | 2001 Volkswagen Passat
I have a 94 nissan altima that overheats. I
sounds like where the water pump meets the engine has warped or the gasket has been blown. Since the water pump has to come out anyway to fix it then i would suggest replacing the pump. It is 30 to 40 more.
Jul 09, 2009 | 1996 Nissan Maxima
What would cause a fuel pump to overheat
When the fuel pump is short circuit it will start going bad and thus gets hot. Replace witha brand new one. It will not cost much.
Rate this
Mar 24, 2009 | 2000 GMC Sonoma Extended Cab
Garden Logo
308 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Tim Venetis
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
