Question about Intermatic TN111C - Heavy Duty Lamp and Appliance Plug-In Timer - 2 On/Off
I have two of these and neither will turn my lamp on. And the backing of the timers got really hot for the hour or so I had plugged in for testing. I can't return them to the store bec it has been too long. Now I am afraid to use either one of them bec of how hot they got! scary. I would worry about them causing a house fire while gone. There must be gadzillions of these out there..has there been any recalls I wonder.
  • gshufy Mar 24, 2011
    Thanks a zil! I will check out the website. You've been very helpful.
    Kind Regards,
    GS
    Kind Regards,
    GS
    Genius:
  • 1,400 Answers
Hello
If the timer is in the on position by turning the dial at the top and it still does not operate your lamp then throw it out.
Ive had 3 or 4 of these go bad on me at my work.And one that is 5 yrs old still working on a coffee pot.
If you feel uncomfortable by the heat its giving off then by all means unplug it and get rid of it.
There are better timers on the market.
Posted on Mar 24, 2011
  • 3 more comments
    Thanks mpcheeseman1! I had in the OFF position understanding that OFF means manual override off. I did not think it would affect the operation of the timer. It did work that way at one time but it has been a long time since I've used them. It is not only that I feel uncomfortable using them it is the issue of whether or not they are safe that concerns me. Does anyone know? Could the heating up just be normal for this model of timer?
  • mpcheesman1
    mpcheesman1 Mar 24, 2011
    There is a minimum amparage and voltage maked on the timer.120volts 15 or 10 or 20 amps.So a nomal house lamp should be fine.
    I cant recall one getting hot on me,warm yes but not hot.
  • mpcheesman1
    Here is a link to there website maybe some usefull info.
    http://www.intermatic.com/customer%20ser...
    Well, mpcheeseman that is good to hear your experience with them. I would have to say very warm, not actually too hot to touch. Makes me wonder if in several days the heat would be cumulative. Anyway, my dilemma is to chance the timer IF I can get them working, or just leave on several a small wattage lamps but that seems risky too.
  • mpcheesman1
    ITs up too you.Good luck with what you decide.
Does th lamp have to be on when programming the timer?
Lamp must be on AFTER timer is programmed and when you plug lamp into timer.
The timer does not 'reach up and turn on the lamp switch' or change between high-medium-low settings on 3-way bulb.
The timer just turns power on... so lamp must be turned on for timer to operate.
http://waterheatertimer.org/How-to-troubleshoot-timers.html
Keep in mind that after a programmable-timer's internal battery is charged for 1 hour, you can unplug timer and hold in hand to set ptograms... THEN plug lamp into timer and plug timer back into outlet
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 13, 2015 | Hardware & Accessories
Failure to change Filter Time
unplug projector for about an hour, and then remove bulb, and filter, inspect areas for damage, also inspect it to make sure your inserting it correctly. put filter and bulb back in, put covers back on, then plug it back in. reset the timer. if you still have problems let me know.
May 06, 2008 | Hitachi Performa CP-RS55 Multimedia...
Lamp didn't strike
lamps are affected by strikes. each strike erodes a part of the anode. so in essence, the lamp wears out. However a Xenon has a much longer hour life as once it is running, it cares "relatively" little about how long. SO for commercial units, this is an advantage. there are also larger potential issues about colour stability over life.
with UHP, they care only minimally about strikes, it really is not even a strike, so while frequent on and off can kill it early, with normal usage, you are going to be fine. However with a UHP, if a lamp runs for longer times... then you have issues. THe way i had it explained to me was as such;
With a UHP, it gets up to proper operating temp in about 5 mins. once it is there... it SLOOWWWLLLLLYYYYY continues to heat up. After about 2-3 hours, it starts going outside the nominal operating range. once it does so, it starts to degrade the lamp. thereby lowering life expectancy. if you shut it off after about two hours or so and let it cool for ten mins then do it again for two hours... you are in a much better place. In a grand scheme, apparently if you run the proj for an average of 4-6 hours every time, then expected lamp life goes to about 50%. THis is very rough and in a general sense so just take it as general guidelines.
TIPS TO EXTEND PROJECTOR LAMP LIFE:
Lamp life for a projector will vary based on many factors including application, installation, intake of cool air and exhaust of hot air, usage, and proper maintenance. Heat buildup can reduce lamp life and even damage your projector. Here are some tips to help your projector lamps last longer.
Once you turn on your projector, wait at least five minutes before turning it off to allow the fan to properly cool the unit. After the fan has cooled your projector, you may unplug it and store it as desired.
Do not obstruct the air intake or exhaust vent. Paper should not be placed on top of a projector, or where vents are located.
Keep the exhaust vent at least two feet from any object.
If the projector is built into a compartment, wall, ceiling or shelf mount, the minimum distance requirement (usually at least two feet) stated in your owners manual must be maintained.
Clean the projector's air intake filter every three to six months -- or more frequently -- based on your operating environment.
Do not move your projector until the lamp has cooled (about five minutes).
Run your projector for two weeks and/or 20 hours shortly after your purchase. If the lamp is going to fail, it will usually occur within the first ten hours of operation. Lamp warranties typically last just 90-180 days from the date of purchase, rather than the first installation.
When you purchase a replacement lamp for your projector, remove the existing lamp and use the old lamp as your spare. If your projector is new, test the original lamp for the two weeks/20 hours before removing and storing as a spare.
I hope the info. which i have given you solves ur problem if not i am sad to say you have to get it repaired..
Goodluck,
Please don't forget to rate me as fixya..
Feb 11, 2008 | ASK Proxima C170 Multimedia Projector
On this timer is the light color of time Day and the blue cover on time for night?
You posted under GE 7-day random vacation timer.
This timer shows 7 days of the week.
The nighttime hours are white with blue background.
Daytime hours are blue with white background.
Timer dial rotates clockwise, and make 1 revolution each week.
To set timer, manually rotate dial until current day and hour line up with 'time now' pointer.
Move slide switch to TIMER ON.
Timer randomly turns on-off at preset times.
To watch timer in action: turn lamp ON, plug lamp into timer, plug timer into outlet, and then manually rotate dial clockwise several rotations and watch lamp turn on-off.
http://waterheatertimer.org/images/GE%2050462%207-Day%20Random%20Vacation%20Timer.jpg
http://waterheatertimer.org/GE-timers-and-manuals.html#50462
Aug 13, 2011 | GE 50462 7Day Random Vacation Timer
How do I operate the pins. I get the Current time and can set the on time but am confused about the off time because it seems like the off time ends up to be pm and I am turning it on in the am.
Open following link to see photos of pins and tabs:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Here's a generic instructions for plug-in timers.
Locate pins on dial: move 10 pins in a row. This will be for testing purpose.
Plug timer into outlet located on kitchen counter-top so you can see what is happening.
Turn lamp on. Plug lamp into timer.
Manually rotate dial clockwise and watch when lamp turns on-off.
This will tell you how to position the pins.
Most of these timers have a slide-switch.
Move the slide-switch one direction and then the other.
Manually rotate dial each time and see which way slide-switch should be positioned.
Set pins for on and off times.
Dark background is pm. Light background is am hours.
Final step is to set current time. Manually rotate dial until current time lines up with arrowhead located on inner dial.
As time passes, the dial rotates, and the pins click a lever that turns lamp on-and-off
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | Woods 3C 24 Hour Indoor Mechanical Timer...
Please assist me in setting this light timer. brinks-42-1020
Instructions for Brinks 42-1020
1) There are plastic segments located around outer edge of timer dial.
These segments divide each hour into 15 minute periods.
Push segments down like a piano key for all hours you want timer ON-or-OFF
2) Push switch to Auto ON -or- Timer
3) Turn lamp ON, make sure bulb is working, plug lamp into timer.
4) Plug timer into wall.
Manually rotate timer dial clockwise to observe light turning on-off.
This action will say if light is ON when segments are up or down.
5) Unplug timer, and set segments for times you want lamp to turn on-off.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial
7) Plug timer back into outlet. Dial rotates as time passes, segments click a switch that turns lamp on-and-off.
Add a comment for more free help, or to further clarify this free answer.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 11, 2011 | Hampton Technologies Brinks Timer
I have a First Alert model 610 timer. It is an older model and I need the instructions for it.
I called First Alert @ (800) 323-9005 and they faxed me the instructions for Model LS510 which is the same and got it working. They will mail it too but not email. Choose Fixed or Random mode. Choose how many hours it will stay on after dusk. Turn your lamp off and unplug the lamp. Plug lamp into timer. Put function in Fixed or Random position. Put hours on switch to number of hours you want it remain on after dusk. Plug timer into the wall outlet. Turn the lamp's switch on and Timer's LED light should be on and the lamp should be off. Turn the lamp's switch off then on again TWICE. The second time you turn the lamp's switch on the bulb in the lamp will flach on then off quickly. This indicates that the Timer is controlling the lamp's operation. Leave the lamp switch in the ON position. The timer is now set for automatic. I hope this helps.
Jan 06, 2011 | Vacuums
How do i set the Brinks 44-1040 timer?
Brinks 44-1040 is a 24-hour plug-in timer, with 1 on tripper and 1 off tripper.
Dial has 24 hours with each hour marked for am and pm times.
Push tripper down and rotate until tripper aligns with time you want for ON and OFF.
Rotate dial until current time lines up with arrowhead located on inner dial.
Turn lamp ON. Make sure bulb is good.
Plug lamp into timer. and plug timer into wall.
Move slide switch one direction or the other to control mode.
When switch is one direction, lamp in ON all the time.
Move switch other direction, and timer programs work.
Dial rotates as time passes, and trippers move on-off lever that turns lamp ON-and-OFF.
Dec 24, 2010 | Hampton Technologies Brinks Timer
I have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
Resetting outdoor light timer
I would unplug the timer. Change the setting to 6 hours then plug back in.
Dec 08, 2008 | Coleman Cable Outdoor Easy Set Timer #4604
Intermatic TN111C - Heavy Duty Lamp and Appliance Plug-In Timer - 2 On/Off Logo
102 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
