Question about Toto Carlyle 1-piece Elongated Bowl Toilet
After flushing the tank and bowl both refil properly. After about 20 minutes the water in the bowl has decreased about 1-2 inches. The tank is still full. Not sure what the cause and/or fix is
  • jerry earick Mar 24, 2011
    Does it gurgle after the level drops?
  • 349 Answers
Vent pipe may need cleaning out, vent stops up your system has to get air to work so it will take it from where it can get it and the toilet maybe the easied place.
You may have a vent pipe that may be partly blocked or clogged up. To check a vent pipe out you can have someone fill a sink or tub up to the flood level rim and plug the drain. Have them remove the stopper and watch the toliet you have had issues wit to see any water movement. Once you deteemine which one is the cause you can snake the vent pipe or run a water hose down the vent and turn it on to flush out the vent pipe.
Hope this will help you out.
Posted on Mar 28, 2011
Re. Duravit Happy D toilet (tank No. 0929100005)
Remove and clean the flush valve and the flush valve seat(it is the flap that opens up to allow water to flush the toilet). Once the edges of the valve and the seat are cleaned, possibly with "0000" grit bulldog steel wool, it should not leak anymore. To make sure it is not leaking, once tank has refilled completely, put some food die in the tank. If, after 10-15 minutes, the water in the toilet bowl is colored, you have a leak from the flush valve. Replacing the flush valve is very easy - just bring the old one with you to the hardware/plumbing store and ask for a replacement. Blessings and good luck!!
Sep 23, 2017 | Duravit Home
Why wont my have a cimarron k3489 toilet fully flush? the water empties from the tank but the water from the bowl does not go down.
That's an interesting one! Does the flush valve close properly so the tank can refill? Does the float valve allow the tank to refill fully, to near the top of the overflow? That can be adjusted, if it doesn't.
Check fhe flush valve - you may have an obstruction under it. Also check the water port from the bowl side - feel up inside the port for obstructions or buildup of hard water deposits.
WASH YOUR HANDS THOROUGHLY afterwards.
Jul 29, 2014 | Kohler K-3489 Cimarron Comfort Height...
My Mansfield toilet flushes but only 1/3 of the water in the tank flows out during a flush and the bowl does not get enough water to flush everything.
Check the water level int he tank for it coming up to fill line in tank. Make sure the 1/4 " fill line from the fill valve is connected and in the stand pipe tube to allow water to fill bowl. Fluid master makes a flapper that has adjustments on it to increase or decrease water used to flush. It has a dial to move on it this would be another option if the above tried doesn't help.
Thansk and I hope this will help you with this problem.
Mar 26, 2011 | Mansfield Plumbing Products Home
Toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Jan 23, 2010 | Toto Aquia II Dual Flush Toilet
G-max flushing system is not filling to proper level
Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
Jan 06, 2010 | Toto Drake ADA Compliant Toilet with...
Tank not holding fill level...
Most likely, you do not have a good seal on the flapper valve at the bottom of the tank. To confirm, try this:
Turn off water and flush toilet. Then lift up the flapper valve and put a light coating of vaseline on the mating surface where it contacts the toilet tank when closed.
Turn water back on and see if it continues misbehaving. If that fixes it, it was a bad seal. Usually that is all it takes.
Dec 15, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Bowl will not fill.
There is usually a small tube on the top of the ballcock or the fill valve in the toilet tank. The tube should be clipped to the top of the flush valve pipe so that the water will flow into it. Should the small tube become loose and fall off of the clip, the refill water will not make it back into the bowl.
Aug 09, 2009 | Home
Super low water level in bowl decreases after flush refills
First, fyi, adjusting the knob? in the tank, or the fill level will not increase the amount of water in the bowl. The bowl fills to a certain point, and then as more water is added it starts to go over the built in trap, and down the drain. When you flush the toilet, all the water in the tank dumps into the bowl, and the existing water is pushed over the trap and down the drain. All of this being said it sounds like you may either have an internal crack, between the bowl and trap; you may have a crack that is draining under your toilet, (water spots?), or you have a more serious plumbing issue, improper venting, which is causing a vacuum, and pulling the water out. Hope this helps.
Jun 16, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
When I flush the toilet not enough water comes back into the bowl
There should be a small plastic tube (about 1/4 inch in diameter) running from the fill valve (at the left side of the tank) to the overflow tube (about 1 inch in diamter) located near the centr of the tank. The small plastic tube is supposed to have water flowing when the tank is refilling. This is the water than helps refill the bowl. The little plastic tube some times gets knocked off from its position at the top of the overfill tube.
Jun 11, 2009 | American Standard Home
Toto Carlyle 1-piece Elongated Bowl Toilet Logo
225 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
