Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
Where can I buy the water flow meter When I start the machine, it warms up properly and after the lcd shows it ready, I select the numbre of cups I want. Unfortunately, the machine only pumps a small amount of expresso and I have to start over again. It takes a number of cycles in order to get a fulol up of espresso.
Same problem I have, flow meter! you could buy it @ http://www.smallappliance.com/product.asp?pid=13677&cur=USD&cam=krupsusa although I am not sure which cluster you would connect the flow meter to the power board. My husband and I have opened the machine and we forgot to reconnect the flow meter to the power board. If you could take a look for us either J3 or J6 I will be more than happy to know. thks
Posted on Apr 20, 2011
I have lavazza expresso pointe machine. I put in cartridge and select cup size and water keeps going. It doesn't stop so cup overflows and ends up just water flowing thru
need to remove the back cover, which has a few screws in the bottom left corner is a round and white plastic device that is said meter. Disconnect hoses from it and open it. Clean it well and then close it and put in place. Should be fine!
Jan 06, 2014 | Lavazza Espresso Point Capsule Machine
Keurig B70 automatically pumps water when turned on
When you purged the lines or tubes retained debris and need full purging and flushing.
May 30, 2012 | Keurig Platinum B70 Coffee Maker
Programmed buttons not working. I have to manually stop the water for making the small medium and large cup. How do I reprogram?
The buttons cannot be reprogrammed. What sounds to be the problem is the Flow Meter near the pump which regulates water flow. They also call this the kick-back element. This functions by having a wire connection run from the Electronic Card to the Flow Meter where there is another plug connection on top of the unit. Within there is a magnet and spindle that measures the amount of water flowing through. When this is not functioning properly the pre-measured volumes for espresso do not work.
When you make a selection, the selected function light will blink if the operation is working correctly. If the light is solid this is usually an indication that there is a malfunction somewhere. The Electronic Card may be bad or the Flow Meter may be bad. If the light goes off and remains off while the selected function is in use it will usually result in the same probable cause I listed above.
Before hunting down a repair location try descaling your machine with a descaling unit made for your machine. Fine pieces of sediment may have gotten lodged in the tiny holes within the Flow Meter causing it to malfunction. If this does not solve it, have the flow meter replaced by a certified tech.
May 10, 2011 | Lavazza Espresso Point Capsule Machine
When making espresso half way through the pump quits working and display back light blinks with all icons lit. The steamer works fine, it is just when making espresso.
Most likely you will see the problem when doing a single or double espressos and when just producing hot water. All these three functions work based on specific amounts of water. Most likely your flow meter is not working properly. I replaced my flow meter (< $20) and the unit now works fine.
Nov 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
My mother decided to make a cup of coffee. She
Make sure the k-cup holder is snapped completely back into place. If the arrows aren't aligned and you don't snap the arrow-side in first, it won't work. If that doesn't do it, check your water reservoir to ensure it is properly seated in it's base. Hope that helps...best of luck!
Jul 14, 2009 | Keurig B60 Coffee Maker
Espresso function very sporadic! Sometimes it works ok, other times the espresso function switches off. Also, the cups on the LCD display keep blinking suddenly. Out of warranty too - boo!
Make sure there is no water in the area where the container plugs into the unit on the expresso side. If there is water the water container cannot seal properly and the unit acts as if it ran out of water. If that is not the issue then you likely have a leak in the seal/valve itself and the unit would have to be opened to tighten the screws holding the seal/valve in place.
Feb 20, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
No espresso
I had the same problem and found out that the flow meter was not working. The control unit was not getting flow information and after about 5-10 seconds it will just stop and blink all the lights. I replaced the flow meter and solved the problem. The flow meter is located between the water tank and the pump.
Aug 24, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Solis 983-40P Palazzo
Try to make a cup of water to see if it gets in ready position.
If you have a magnet in the water tank, make sure that flow up when you fill the water tank with water.
If the problem still are ther i think you have to replace the flow meter in the machine.
Aug 09, 2008 | Solis Palazzo Espresso Machine
I am getting an error message that says VENTILATE
Try draining the machine. Page 37 of the user manual, Drainage. Place cup under the steam/hot water tube, turn knob clockwise around to 9. If the pump is ok, it will start automatically and start filling the cup. Drain about 1/2 cup of hot water and return knob counterclockwise to start position. If the flow meter is not damaged, the Ventilate message should be gone.
Nov 07, 2007 | Saeco Royal Exclusive 30153 Espresso...
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
181 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
