Question about LaCie Wireless Space 2TB Wireless Storage Hard Drive
Hi There How do I connect my wireless space to my laptop via Ethernet and while still being able to connect to my wifi internet at the same time,, keep in mind i do not have WAN internet line connected to Lacie, my only internet is via Vodafone Pocket wifi > or direct usb I cant seem to work it out ??? When Lacie is connected to my laptop via ethernet,, my wifi internet connection disconnects from internet, as soon as i disconnect the Ethernet cable, it connects to internet again. Am I doing something wrong ??? are there Ip issues or also read about possible metric configuration in TCP/IP properties to be adjusted ?? please help as its driving me insane becuase everytime I need to acces data on the drive I cant be on the internet. AC
  • 158 Answers
SOURCE: Hubs don't work on LaCie minin 250 GB Hard Drive
there is not enough power coming through ports each device re-quires 1-5 volts to run and if your mac has not got enough power to boot all devices then sadly all things pluged into will not reconise and with mac the os is not properly designed for it now if you got yourself an external usb 2.0 hub powered then yes all devices will be seen in mac windows firewire is unsafe at moment for this to happen ask them what system they had had configuration on. hope this has helped
Posted on Aug 14, 2007
  • 3587 Answers
SOURCE: Unable to locate Lacie Ethernet Disk Mini on the network
Lacie's out to may be experiencing the old drivers are shot issues..get em from the main site, and reinstall, ok?
Posted on Mar 24, 2008
SOURCE: Vista (32) will not recognize my lacie d2 external harddisk
solved: after referring to the userguide, I found that I formated my drive with a OS format, which can not be recognized by VISTA >> formated to FAT32 and now it works...
Posted on Jan 03, 2009
  • 1285 Answers
SOURCE: Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive: I want toconnect my Lacie drive directly to my com...
do you have a router?.....yes, plug the ethernet cable from 500hd to router and ethernet cable from pc to router.........
have fun
Posted on May 21, 2010
SOURCE: Hi, I cannot connect my
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Posted on Feb 02, 2011
My next book wifi quit working.
hi Martha.
this is all i could find out.
First, make sure your laptop is 'not' connected to the modem/router via an Ethernet cable and follow the steps:
1. Go to "Control Panel".
2. Next go to "Network and Internet" and then "Network and Sharing".
3. Now click on "Manage Wireless Networks".
4. On this screen, remove all wireless connections by "right clicking" on it and select "Remove network" from the drop down menu.
5. After doing this, close the open windows and reboot the computer.
6. Once the computer is fully reloaded, scan for the "Wi-Fi networks".
7. Click on the available network that you want to access and select "connect".
8. It takes a moment, but then you will be asked to give a password for your Wi-Fi connection. Type in the password and click the "connect" button.
It should now be connected.
NOTE: If this doesn't work, you may want to reset your modem/router, and then once it is fully loaded again, repeat the above steps.
If this doesn't work, test seeing if your laptop will connect via Ethernet. If so, then your WiFi card may be going. You can either look to replace it/have it replaced, or get an external (plugs in via USB) WiFi card.
or try this link.
nextbook wifi problem
Dec 03, 2017 | Book Computers & Internet
What is wreless network connection
wireless network connection or wifi lets you connect to the internet via ethernet modem with wireless capabilities, with your particular laptop it should pick up the signal all you need is the network key to have internet on your laptop
Aug 12, 2014 | Lenovo G575-438343u Amd E-350 1.60ghz...
I have an issue with Wireless Access Point D-Link DAP 1155 When i'm connected to the internet via WiFi by mobile device (different ones Galaxy Note 1, Galaxy Note 2, Galaxy ACE) when browsing internet is...
Do other wireless laptops connect to your wireless router, and give good speeds? Do you have many wireless networks, other than your own, that show up when you try to connect? It could be interference from other wireless networks in your vicinity.
Aug 21, 2013 | D-Link Computers & Internet
Can,t conect to the internet via wifi
When was the last time you could connect to the internet via wifi? You could do a System Restore back to that time.
And/or, connect to the internet via an ethernet cable and update the BIOS on your computer.
And, make sure you can find your current wireless driver on the internet; delete the wireless driver, from your computer (it might be corrupt), while in safe mode. Then restart and download the current wireless driver in normal mode.
May 19, 2011 | Computers & Internet
First, you will need a place to connect to the internet. An ethernet cable (landline connection, wired connection) or a wireless connection (via wifi). You will only be able to connect via wifi if your laptop has a wireless network card as not all laptops do (though most new ones do have a wifi card).
For a wired connection, if you have a plcae then all you should need is to connect an ethernet cable from your PC to the wall or place with the interent service (home, cafe, etc).
For a wireless connection, you will need to open and view all wireless networks. Connect to the one you want to use. You may need a security code (WEP Key) or another passcode of a sort. Enter the passcode and you should be on your way. Let us know how it goes!
Mar 10, 2011 | Computers & Internet
Belkin Play N600. Acer Vista laptop. Wifi only, laptop wifi connects then disconnects. With ethernet connected the wifi and ethernet shows connected, when unplugged, the wifi will disconnect also.
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 24, 2010 | Belkin Play N600 Wireless Dual Band Router...
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
I have a wireless router hooked to my computer & my son recently got a wireless-G USB adapter so that he can play his xbox 360 online. Will this work, or will we have to put the router on the xbox...
XBOX 360 will only work properly with a 'genuine' USB WIFI adapter designed specifically for it (and at an over inflated price IMO!).
One popular way to play 'network' via the internet is to connect the XBOX 360 to your PC via Ethernet cable and have the PC connecting to the internet either via another ethernet connection or more likely via a Wifi connection which could be via your USB adapter connected to your PC and talking to your Wifi Router)
Dec 26, 2009 | Computers & Internet
You can go for a wireless router, so that you can access internet anywhere in your house, ,
Jul 18, 2008 | Dell Inspiron 5100 Laptop
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | 2wire (1000-400108-001) Router
LaCie Wireless Space 2TB Wireless Storage Hard Drive Logo
118 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
