Question about Garden
I have a cat pump that overheats and the pump oil is full but still overheats and melts the oil cap
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: How full and with what oil to fill pump vent.
Any pressure washer pump should be no more than half full. The reason is if you fill it completely up when the piston strokes it will blow the seals out of the pump. Usually there is a sight gage on the side of the pump. I will look your model up and see what I can find as far as quantity for the pump. I won't be too long just read the 2nd response and please do not rate this one. I will get back to you ASAP.
Kelly
Posted on May 17, 2010
Why wont my radiater hold water and why is my catalatic converter getting red hot?
You may have a small leak in your water pump and it only leaks when you drive. Or god forbid a cracked block and the water is mixing with your oil (see white smoke coming from tailpipe?)
Nov 30, 2015 | 2003 Ford Windstar
The oil cap for the water pump is missing. what possible d
it takes a lot to harm a pump , just replace oil and cap
Feb 09, 2014 | Ridgid Garden
Pacific hydrostar 2800 pressure washer
did it overheat if so replace the pump it will overheat again only two things the packing can be worn overpressuriztion in pump head by a faulty unloader is another this symptom has many variables even a cracked plunger can cause this i can and will help you give me more info like is the oil milky in color or is sight glass melted etccc.will be glad to help 30 years plus exp..
Jul 31, 2013 | Garden
What would be the best oil to use in a 1999 3.5lt v6 magna with 305000 klm
Spark plug leads need to be good as high resistance in a lead can cause coil problems, which in turn can cause high hydrocarbon readings to damage O2 Sensor and overheat and melt the CAT. In fact any miss be it plug, valve, lead, coil or compression will lead to O2 Sensor and CAT damage.
Jul 29, 2012 | Chevrolet Cars & Trucks
1999 mercury grand marquis occasionally overheats, leaks around radiator cap, makes gurgling noise on passenger side. Have replaced heater core, water pump, thermostat, hoses,& radiator cap.
Check the antifreeze for oil, pull your dipstick out, see if antifreeze is in oil or smells sweet or over full, sounds like you may of a bad head gasket. You can also check this by having a compression test done on the cylinders.
Feb 18, 2011 | 1999 Mercury Grand Marquis
1995 Isuzu, 2.3L engine overheats, chnaged rad cap, water remians
head gasket, if a crean collor is on the oil cap, lools like water pump etc are good
Apr 14, 2010 | 1995 Isuzu Pickup
What is the red cap on the cat pump for? And why is oil or some type of redish colored fluid coming out of it?
The red cap is for adding lubricating oil for the crankcase in the pump. If oil is coming out of it while it is running a seal in the head wore out and water is getting into the crankcase and displacing the oil.
Mar 03, 2010 | Northstar Professional Series Pressure...
I have excell 3700 pressure washer...the pump cover vibrated loose lost oil and cam melted.how do i get parts and change pum cam?
When you get down to it, purchacing oil end parts for a pressure washer is not cost effective.
The crank(cam) shaft runs about 280.00 dollars. The oil seals, new bearings, possibly new pistons and almost definatly new seals would be at least a hundred more. You can get a new pump for about 400 dollars and won't have to do all the work.
Dec 18, 2009 | Psi PowerBoss 20262 Pressure Washer
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
