Question about Vizio P50HDTV20A 50 in. Plasma HDTV
My 50 inch vizio plazma keeps turning off and i have to unplug for awhile then plug back in to get it to come back on, but it doesnt stay on long. help
  • clslawns Mar 24, 2011
    it started awhile ago happening every once in awhile. now it happens alot more sometimes stays on for hours and some times just minutes. in the last half hr it is turning off every few minutes. when i try to turn it on the light does blink but tv does not come on. i have to unplug it for awhile.
  • Vizio Master
  • 2,098 Answers
Hi clslawns,
Does the unit take a few mins/hour before it will turned off. Does the symptom happened recently or just for now. Does the led light flashes/blinking? Let me know to assist you further.
Jdvillanueva
Posted on Mar 24, 2011
  • Jdvillanueva
    Jdvillanueva Mar 24, 2011
    This is an indication of out-of-regulation in the power supply section. This was caused by leaky/dried electrolytic capacitor in
    that section. It will drop the supply from normal voltage and
    will disable the unit.It needs a little warm-up to make itself stable but the
    symptom will get worst like what you've experienced right now. Sometimes it has a bulged/dome at the top but not all, it is better
    that you have a capacitor
    checker/tester
    to determine
    its condition. Your unit will back to normal again if the leaky capacitor is
    isolated.
    If you don't have necessary tools
    and test instruments
    , and can't do the job yourself, I would advice you to
    look for a professional to troubleshoot the problem. Don't
    attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored
    electricity enough to hurt you with a little mistake only.
    Another option is to find a shop that will repair the power supply board only, no need to send the entire unit since the affected parts is the capacitor only. It will save you some money for service fee.
    Also check if your unit is under warranty /extended warranty,
    avail it because the manufacturer of your unit will fix it for free. Don't open
    the back panel, this will void the warranty.
    Hope I helped you.
    Have a nice day!
    Thanks for using Fixya.
    This is an indication of out-of-regulation in the power supply section. This was caused by leaky/dried electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit.It needs a little warm-up to make itself stable but the symptom will get worst like what you've experienced right now. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Your unit will back to normal again if the leaky capacitor is isolated.
    If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
    Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
    Hope I helped you.
    Have a nice day!
Turned itself off. I turned it back on and the green power light blinks for awhile then blinks red for awhile.no picture or sound
Get rid of this TV. Had one and replaced the bulb and light engine many times. Just buy a Samsung or Vizio 50+ inch instead and be very happy. Those Panasonic projection TV's were terrible. You will find a 50 inch Vizio for around $500 bucks and it will blow your mind how great the picture looks.
Oct 16, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Vizio m320sl "no power" but will stay on if I don't turn it off
The internal power supply is failing. It keeps trying to start over and over again but only succeeds occasionally.
Dec 11, 2013 | Vizio Televison & Video
My 20 inch Dell Monitor keeps shutting down..
mcdevito75 here, Sounds like the monitor itself, contact Dell for rep[lacement on warrantee if warrantee applies.
Jul 14, 2010 | Dell ST2010 20" Monitor
Magnavox plazma 50 inch flat screen wont turn on
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Televison & Video
Once you turn the vizio 50 plazma vphdtv10a off it wont turn back on after it cools of if you keep turning on and off for 30 min it will come on and stay on until you shut it off and let it cool off
I have a 32inch vizio that kept going off. the company said remove it completly from all power,wait 30 seconds,push the on button for 15 seconds.plug back in and it should work.
Mine worked at first then it quit completly and the company did not return any of my e-mails. probably cause it is past the warrenty(they only warrent for 12 months)A friend of mine had the same problem, neither one of us will ever buy a vizio again and I tell everyone I know about this problem.
Feb 26, 2010 | Televison & Video
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV20A 50 in. Plasma HDTV Logo
143 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
