Question about Brita 35530 UltraMax Digital Water Dispenser
How can i separate the two parts of the reservoir to wash it without breaking it?
I just figured out how to separate the two parts of the Brita Ultramax water reservoir so they can be cleaned!!!
Empty the Brita of water. Whatever water is not removed through the spigot will drain out if you turn the filter upside down. Then let the two parts air dry for an hour or so. Now hold the two parts between the thumbs and middle fingers on each end, press your middle fingers against your thumbs. Then slide your middle fingers up, and the white part lifts out of the clear bottom! Yay!! Now the clear reservoir can be CLEANED!!
Posted on Jun 17, 2012
Brake reservoir leaking?
Clean up any oil leaks.
Have someone sit in the car and depress the pedal while you check around for leaks.
You need to check all brake lines, and calipers etc.
Locate your leak and repair or replace parts as necessary.
Nov 13, 2012 | 2000 Toyota Tundra
Which is the break fluid container in front engine? I need to add some break fluid in Dodge 2000
The break fluid goes into the container that sticks straight out of the firewall(the wall that separates you and the engine) Its connected to a big round metal thing that looks like a pan(its called a booster) It should be the only fluid reservoir that is sticking out from the firewall.
Mar 09, 2011 | 2000 Dodge Caravan
Can i change breake pads without bleeding brakes as i have read on net that I can compress caliper pistons without opening resevoir and or bleeding lines
Brake pad replacement does not involve brake fluid loss or air entrainment in the brake lines. It is a good idea to loosen the lid on the master cylinder reservoir while you compress each piston. It may make it a bit easier to do. If you do put a rag around the reservoir in the rare event there is slight spillage. Use a small block of wood or an old brake pad as a protective caul to cover the piston end in the caliper, Use a C-clamp or similar tool to gently compress the piston back into the caliper head. When initially positioning the C-clamp, pay close attention to where it will grip on the back of the caliper so you do not inadvertently damage other parts. Once you are all done with the pads check the reservoir and top off with a little fresh brake fluid if necessary. Be sure to securely fasten the lid to the brake fluid reservoir.
May 14, 2010 | 1998 Mazda MPV
I need to know what the part is called and how to fix it. The part is leaking hot coolant fluid, it is a ''y'' shape tubing that feels like hard plastic, black in color. It runs on the left side to the...
sounds like hoses going to heater core but they are rubber usually. But it could be the hoses for the degs bottle mounted on the passenger side inner fender.
Coolant Recovery System NOTE: When the water thermostat (8575) is closed, coolant flows through the degas tube and hose assembly from the lower intake manifold to the radiator coolant recovery reservoir (8A080) .
Trapped air in the cooling system must be removed. A pressurized radiant coolant recovery reservoir system is used which continuously separates the air from the cooling system.
  • When the water thermostat is open, coolant flows through both the small hose from the top of the radiator outlet tank and the degas tube and hose assembly from the engine to the radiator coolant recovery reservoir.
  • The radiator coolant recovery reservoir separates any trapped air from the coolant and replenishes the system through its radiator coolant recovery hose.
  • The radiator coolant recovery reservoir serves as the location for:
    • service fill.
    • coolant expansion during warm-up.
    • system pressurization from the pressure relief cap.
    • air separation during operation.
  • The radiator coolant recovery reservoir is designed to have approximately 0.5-1 liter (0.53-1.06 quarts) of air when cold to allow for coolant expansion
Apr 08, 2009 | 1995 Ford Taurus
Broken hinge on reservoir cover for Cuisninart model DCC-2200
The hinge itself is not orderable, but a lid with the element that fits into the hinge was available from Cuisinart the last time I checked. Call 1-800-726-0190 to be sure. It is not easy to put the replacement lid into the right place without breaking the part, but it is possible - you have to put one bar into the hinge, and then pull the other bar just enough to fit it into place without breaking it. If you are out of warranty, the lid will cost somewhere betwen $15 and $20 with shipping.
Feb 26, 2009 | Cuisinart DGB-300 Coffee Maker
Separate miele washing machine and dryer
if you go to sears .com click on parts put your model number in(should be inside dryer door)it willl break down and show you everything you need to know,let me know how it turns out,mike
Sep 28, 2008 | Miele XLWDSTAND Washer and Dryer Stand
Brita 35530 UltraMax Digital Water Dispenser Logo
3,588 people viewed this question
Top Brita Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Brita Kitchen Appliances - Other Expert? Answer questions, earn points and help others
