Question about Skylink Group Skylink Ad-433s Dial Alert Emergency Dialer
I have the AD-433S model Emergency dialer and when it dials my cell phones (two) it disconnects right away. It will dial both phones but drops the connection and you don't get to hear the message. Doug
Tip
How to Operate a Home Security System Without a Contract
Many homes have alarm security system installed, even though the current tenants may not have been the ones who paid for it. Some did pay for it but just can't afford the high monthly cost of alarm monitoring. Many people don't realize that once the alarm security system is installed only the monthly monitoring fee stands in the way of free home security. The alarm system still works without monitoring, and it is easy to configure on your own.
  • Install the dial capable motion detectors in place of the entryway motion detectors. The mounting directions and hardware will be included in the motion detectors' packaging. Often the old motion detector's hardware will mount the new one.
  • Connect phone lines to the new motion detectors as instructed by the manufacturer. Usually the lines connect from the new motion detectors to a phone or third-party dialer.
  • Program the dialer or the dial-capable motion detectors to dial the phones of your choice. Your cell phone is usually the most important phone number to program into the dialer to alert you quickly if there is an intruder.
  • Arm the alarm as you normally would. If there is an intruder, the new motion detectors will sense the movement and will dial your phone to alert you.
  • Tips & Warnings
    • Consider replacing the motion detectors that cover the windows and alternate entry and exit points, especially if you have a large home or one with several different entry doors.
    • If the dialer-enabled motion detector is capable, program a second and third phone number into the dialer to maximize effectiveness. Dialing your cell and your neighbor's home phone, for example, would be more effective when you are away from the area.
http://www.securityalarmchina.com/
on Mar 29, 2016 | Home Security
I have an elderly parent that keeps dialing the emergency number by mistake when he has no signal and the Emergency number is the only option. Is there a way to block that?
PDF]Anonymous Call Rejection Automatic Busy Redial ... - HTC
www.htcinc.net/.../Calling_Feature_Instruc...
Horry Telephone CooperativeDial "*87". 3. Listen for confirmation tone, hang up. Automatic Busy Redial. Available ...There's no need to run to answer a ringing phone ever again! ... number will not be announced if the caller chose to block the delivery of his phone number. ... may onlyreceive calls from the number that you have forwarded your calls to.
Is there a way to completely disable the dialer including ...
android.stackexchange.com/.../is-there-a-way-to-completely-disable-the-...
Mar 26, 2014 - The phone has no service, but can still make Emergency calls and I'm ... you can dial 911 in a country where the landline emergency number is 11 .... The SIM card is just a memory chip, containing authentication information. ... the SIM card, the phone will request access to the strongest signal available, ...
Dec 28, 2015 | Cell Phones
I forgot my lock code for my c7
You have to do factory reset for your phone. Go to emergency dialer and dial up *#7780# and continue with default code 12345.
Dec 14, 2011 | Nokia C7 (8 GB) Smartphone
I have a Panasonic Easa-phone Model KX T-3135. I need information on how to program the memory to use the automatic dialer keys.
Panasonic ESA-PHONE - KX-T3135
Program instructions for the "Automatic Dialer"
On the right side of phone set the 'Memory' switch from 'Set' to 'Program'
If programing the upper entry of a 'Automatic Dialer' buttons:
Press the button - enter the phone number as it needs to be dialed - press the 'Memory' key on the left side of the phone's face.
If programing the lower entry of a speed dial buttons:
Press the 'lower' button on the left side at the bottom of the 'Automatic Dialer' pad;
When all entries are complete, on the right side of phone slide the 'Memory' switch from 'Program' to 'Set'.
May 03, 2011 | Cell Phones
Hello, I have a Remo-Con Tone Dialer but I cannot remember How to use it ! What is it meant for ? Kind regards.
That's not a brand I remember, but it's most likely a tone generator from the days when you still found phones with rotary (pulse) dials. Before tone dialing was the standard, if you wanted to use any kind of service (banking, alternate long-distance phone carriers, etc.) from a rotary phone, you needed a dialer to generate the tones. You held it up to the mouthpiece on the handset and pressed the numbers on the dialer keypad. Some of these dialers also allowed you to store some phone numbers so you could quickly dial them if you were using a tone dialing service. As tone dialing has almost completely replaced pulse phones, you seldom see these devices except maybe at yard sales. They have no practical use any more.
Nov 23, 2010 | Cell Phones
HTC Hero voice dialer does not recognize my
The Hero's voice dialer is a piece of ****. I would not use it at all. It defeats the purpose of voice dialing if you actually have to look at the phone to confirm who you want to dial.
I would see if there is another app that can do voice dialing that is better. I cannot give you any advice on that, since I don't use voice dialing.
Good luck.
Jan 29, 2010 | HTC Hero Smartphone
Right after dialing. it says the 'you are disconnected'
do as follows
settigns network setting s automatic
this would refresh ur mobile network connection
Jul 16, 2009 | Nokia N95 Cellular Phone
Skylink Group Skylink Ad-433s Dial Alert Emergency Dialer Logo
46 people viewed this question
Top Skylink Group Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Skylink Group Home Security Expert? Answer questions, earn points and help others
