Question about Samsung DLP HL-P5663W 56" TV
Verticle black stripe
I have a black stripe running vertically on the left side of my screen. The bulb has been replaced but the stripe is still there. Any suggestions?
    Sergeant:
  • 368 Answers
The most likely cause is a light tunnel issue. There is a small metal device shaped like a cylinder about 5/8 inch diameter by about 1-1/2 inch long that contains 4 small mirrors arranged so there is a rectangular light tunnel through the cylinder. The light coming from the color wheel passes through this tunnel and it shapes the beam in the right shape to be directed at the imaging chip. If one or more of these mirrors does not stay in place it can cause a shadow on an edge of the screen.
The mirrors are held in place inside the metal cylinder with a couple of springs around the cylinder and also by glue or plastic material between the cylinders metal walls and the mirrors. The simplest way to fix it is to replace this light tunnel with a new one. The cylinder can be replaced in the wrong orientation and it can then interfere with the color wheel causing it to be damaged. If someone is good with fine detail they can carefully move two of the mirrors toward each other, insert a little super glue between the mirrors and the metal wall and then move these mirrors to the walls so they are again in the right position.
The process for gaining access to the light tunnels involves removing screws holding the electronics modules in the TV so they can be separated from the TV. The lamp assembly, cooling fan assembly and color wheel can be removed so the projector parts can be removed. The light tunnel has a cover over it that can be removed so the light tunnel can the be removed to be worked on.
Learning how to do this takes a lot of patience, mechanical inclination and risk. I was successful but not all are.
There are other descriptions of this issue that provide similar information so your might want to look for them and study them before deciding to do surgery or not.
Posted on Jan 14, 2013
Its your light tunnel
Posted on Aug 05, 2008
My samsung hl-r5087w has black verticle lines how do i fix that
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help to fix the fault, do take care in handling the solution
May 26, 2011 | Samsung HLR5087W 50" Rear Projection HDTV
TV picture not available.
Hope this help....
Jun 21, 2010 | Vizio L37 Television
I have a 42' LG plasma that has now has a 1 1/2 inch verticle stripe on the right side. It used to come and go but now rarely goes away. Any ideas?
I believe that this could be a type of "burn in". If you watch anything with a black stripe on the sides or bottom of the screen often, then this could be the problem. My suggestion is to watch things that have no black side bars for a while (>week) and see if this eliminates the problem.
Good Luck!!
Jun 11, 2009 | LG 42PC3D 42 in. Plasma Television
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
One big black verticle line 2 inches from left side...Help
Honestly you have a big problem because the driver IC & Tape Carrier Package inside controller board at vertical area are damage or itself defective could cause you have 2 inches line appear in your display. The best solutions for this replace lcd panel to fix vertical line.
Mar 28, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
HD Pavillion Media CenterDv8225nr Notebood Pc. Verticle stripes
I would try a couple of things. First and cheapest way is to try and update your driver. If that does not work, then try to remove and reseat your memory card(s), and if all else fails you will need to buy a new graphics card approx 75 to 150 depending on how good you want to go.
Feb 04, 2009 | IBM ThinkPad T21 Notebook
Display has 2 inch black stripe running vertically down screen
I have an IBM think pad that developed a 2 inch black strip on the left side of my dispaly. I tried restoring to a previous setting, I updated video drivers, I reset display properties. None of the above worked and am now thinking of formatting and reinstalling windows as a last hope unless someone has any other ideas.
Dec 26, 2008 | Toshiba Satellite P105-S6104 Notebook
Hp r4252 white vertical stripe on left side, 5 in wide
Well sound as if a segment or Ic driver has failed on the panel. And a 42 inch replacment panel can run you $1250.00
Jan 30, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Portable DVD player
check settings and make sure your player is set to play NTSC AND NOT IN PAL MODE
Jan 02, 2008 | kawasaki PVS-10921 Portable DVD Player
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Samsung DLP HL-P5663W 56" TV Logo
229 people viewed this question
Henry  Thomas
Henry Thomas
