Question about LG 42PJ350 42 in. TV
No video,screen is dark,there is audio - LG 42PJ350 42 in. TV
  • LG Master
  • 2,098 Answers
Hi doubles,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 24, 2011
  • LG Master
  • 8,457 Answers
The tv now turn on have flashes of video only a few sec.than dies have audio left only?Yes,than those 2 long LCD inverter boards are dead.These 2 long LCD inverter board provide a backlight for the LCD screen panel to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
What should I replace next, I have a samsung lcd with no backlights but picture shows with a flashlight in a dark room.
sir,
even if you changed the back light inverter the fault remain as same, it seems to be the back light LED is damaged carefully remove the outer frame of the panel then dis connect the LCD then remove the frame of the defuser screen , take out plug your TV, check the LEDs
Feb 15, 2016 | Samsung LN46E550 46 inch LCD HDTV 1080p...
My tv ,whites glow way too bright,dark colors way to dark,what is wrong
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 08, 2010 | Philips 60P8342 60" Rear Projection...
I cant get the x box 360 to show the screen but the consle will turn on i hear the fan runninf but just no screen
I would check your video connections. If it is dark behind your TV, use a flashlight and make sure all of the audio and video connections are correct. Make sure the connections are firmly in place for your XBox and TV for the audio/video cable. Also, be sure to be on the right video setting on your TV (Video 1, Video 2, etc.).
Feb 02, 2010 | Microsoft Xbox 360 Console
Dark screen on my headrest tv
its defective, need to be repaired or replaced
May 29, 2009 | Car Audio & Video
JVC GD-V425PZW no Picture
motherboard needs replaced, to test take a flashlight TV on and shine on screen from above at an angle, do you see a faint image, replace MB
Oct 30, 2017 | JVC GD-V425PZW Television
XBOX
A. You have the wrong inputs on your audio and video, do you know anyone who may've tampered with that? IE older brother, dad, etc.
B. Your 360 has the dark screen malfunction, but if that was the case, you should be able to hear audio.
CrossCut
Nov 02, 2008 | Microsoft Xbox 360 Console
Mitsubishi rear projection tv white screen goes dark and....
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0157" use the audio button to select "video chroma" adjustments, use the video button to select item "68 - AG1", use the adjust button to change the setting to 0, then press the enter button to store the change
Mar 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Receiver lcd display doesnot work
Does the 605 have the "pure audio" setting (my 705 does)? If that is selected, it cuts out the lcd display on the front.
Jan 04, 2008 | Onkyo TX-SR605 Receiver
53FDX01B Picture went black
is the screen lit up?
If so the video module is bad.
replace the surface mount caps app. 8 to 10
or replace module
guy9
Aug 20, 2007 | Hitachi 53FDX01B 53" Rear Projection...
LG 42PJ350 42 in. TV Logo
442 people viewed this question
