Question about D-Link DAP1360 IEEE 80211n (draft) Wireless Access Point DAP1360 (DAP1360E) Pre80211n
I cant get into config my dap1360 by typein in the dlinkap or 192.168.0.50
    Guru:
  • 610 Answers
Just make sure that you belong with in the same IP range.
default DAP-1360 IP is 192.168.0.50
username : admin password : <blank>
change your PC IP address to 192.168.0.xxx (e.g. 192.168.0.2)
from there you may choose wizard or manual configuration.
you may change your DAP-1360 IP add according to your network settings in the office and you must change you PC IP address with in the same range.
Posted on Mar 24, 2011
Dlinkap
http://support.dlink.com/emulators/wbr2310/lan.htm
Aug 06, 2014 | D-Link DAP1360 IEEE 80211n (draft)...
Bought the D-Link DAP-1360 and my problem is that my laptop does not have a port to take the ethernet cable. How do I set it up nw as a range extender?
You don't need to connect via ethernet. In your laptop set the IP address to 192.168.0.2. subnet 255.255.255.0
This will probably temporarily disconnect you from your internet but you can reset the IP address back later. It might be a good idea to write your current settings down for later.
Open your browser and enter dlinkap or 192.168.0.50
You will connect to the Dlink AP
follow the directions in the user guide found at the link below.
http://global.dlink.com.sg/site_support/DAP-1360/Manual/DAP-1360_Manual_v1.00.pdf
Feb 11, 2014 | D-Link DAP1360 IEEE 80211n (draft)...
Dlinkap not work
hi I want an explanation of the problem
you can do a rest to this modem!!!!
Aug 23, 2012 | D-Link DAP1360 IEEE 80211n (draft)...
I just got a dap-1360 and i cant set it up when i type dlinkap or 192.168.0.50 in my URL it keeps sayin webpage cannot be found
just make sure that you belong with in the same IP range.
Mar 24, 2011 | D-Link DAP1360 IEEE 80211n (draft)...
I cannot have access to the setup page when typind dlinkap on my browser. even after resetting the device.
The D-Link configuration URL is
http://192.168.0.1
The default login = admin
The default PW = blank (just press enter)
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 17, 2010 | D-Link DAP1360 IEEE 80211n (draft)...
My cisco 4503 keeps losing it's configuration file.. any ideas why this is happening? thx.
The case gives me hints towards the configuration register value which is not set to proper value, so the switch is not checking the the saved configuration in the config file.
Please do the below steps.
1. Log into the switch
2. Come to enable prompt
3. Typein the below commands
config t
config-register 0x2142
end
write memory
The find an example of the prompt and the commands below
Switch# config t
Enter configuration commands, one per line. End with CNTRL/Z.
Switch(config)#config-register 0x2142
Switch(config)#end
Switch#write memory
After this you can configure your switch as per your requirement and then save the config by typing write memory
Now you can reboot your switch and the switch will come up with the configuration as you set.
Best Regards
Nov 06, 2010 | Cisco Catalyst 4503 (WS-C4503) 12x1000...
you need to type the default URL in the browser. it is ::: 192.168.0.1
and then enter the user id and password.
Oct 31, 2010 | D-Link DAP1360 IEEE 80211n (draft)...
When i write hhtp://dlinkap on the explorer internet i have nothing
Hi i believe that you do have dlink access point device...
if the http://dlinkap doesn't work, try to asign STATIC IP to your computer
assign the following:
IP address:192.168.0.55
Subnet mask: 255.255.255.0
Default gateway: 192.168.0.50
the try to access again the http://dlinkap or simply typein 192.168.0.50
and thats it you're now in the login page of the access point device.
hope this will help
Aug 04, 2010 | Computers & Internet
Cant konfigure router, when i type 192.168.0.50 or
Reset using the button on the back the do an ipconfig - so if you ip is 192.168.1.1 try that to get in to the router
Jul 05, 2010 | D-Link DAP1360 IEEE 80211n (draft)...
Open Questions:
My WIFI networks starts in my flat (5th floor) with a ALICE router; I've added a TP-LINK range extender, which brings the WIFI signal (by means of a directive antenna) down to the garage gate. The - In my house, distance from main router (ALICE) to first TP-LINK TL-WA730RE extender: 6 m with one wall in the route; - TP-LINK TL-WA730RE extender connected to a directive antenna (on my balcony at 5th floor) which aims to the garage gate (ground level) with no obstacles (air-air) - Signal power measured with a mobile app (MERAKI WIFI STUMBLER) in front of the directive antenna: 65 dB - Signal power measured at the garage gate (ground level): 24 dB - DAP-1360 extender positioned in the garage, 30 cm just behind the gate - DAP-1360 antennas placed at one meter distance one from the other - DAP-1360 right antenna placed on the external garage wall, in front of the directive antenna and one meter from the DAP-1360 extender - DAP-1360 left antenna placed close to the DAP-1360, 30 cm behind the garage gate -WEBCAM DCS-942L placed at 4 meters distance from the DAP-1360, with no obstacles (air-air) WIFI CONNECTION WORKS FOR SECONDS: from a PC I connect to a D-Link WEB SITE and I manage the WEB CAM remotely (need it &#39;cause of thieves problems in the garage). But after less than 3 minutes the connection drops. Apparently the DAP-1360 doesn&#39;t connect anymore to the network...Trust me, I&#39;m goin&#39; crazy and I&#39;m fed up of spending nights in trying all the different configurations...PLEASE HELP!!!! Thanks to everybody
Mar 01, 2017 | D-Link DAP1360 IEEE 80211n (draft)...
See all D-Link DAP1360 IEEE 80211n (draft) Wireless Access Questions
D-Link DAP1360 IEEE 80211n (draft) Wireless Access Point  DAP1360 (DAP1360E) Pre80211n Logo
1,438 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
