Question about Aiwa XC-RW700 2-Disc CD Recorder
Does not power up, and fuse is good - Aiwa XC-RW700 2-Disc CD Recorder
    Problem Solver:
  • 12 Answers
Replace power supply..
Posted on Mar 25, 2011
Power Accessory jack used to have power even with ignition off. Inside cabin Under hood main ignition fuse is good. Are there any fusible links in this circuit ??
main ignition fuse is only for just that...
if you checked that the circuit to that power outlet is OK, including the wiring, maybe the jack itself is bad
disconnect it, then use jumper wires to the battery to see if it powers on
Apr 10, 2015 | 2001 Nissan Frontier
Obd port no power, ltr fuse under hood is good, no blown fuses
8b7039ac-88a4-4bf8-9225-c835a0bb02a3.gifto be sure test terminal 16 with test light to a good ground
test terminal 4 and 5 with test light to good power
if all good check for terminal wide open to much
if power is not good underhood block fuses turn over check connector c2 d9 for power if good wire cut ckt 640
Oct 10, 2013 | 2007 Chevrolet Silverado 2500HD
My car is a 2006 honda accord. a friend somehow mixed the terminals up and the radio went dead when we finally got it right. it hasnt come on sinse then
Terminals for what, the battery? Anyway, you likely blew a fuse-check the fuse panel under the dash-should be a radio fuse. Radios often have two power sources, both would be fused, sometimes a power wire has an inline fuse.
If you find the radio fuse and it is good, better use a test light and check that your fuse panel is getting power to it. The radio fuse would have power to it with the key in ON. In fact, with key on, every fuse in the fuse panels would show power on a test light. The little slots at the top ends of every fuse are open to the metal strip inside the fuse. Ground the test light lead to a metal bracket or screw, and touch the test light probe into the slot. With key on, every good fuse will light the test light on both ends of the fuse-fuse is good and has not blown-a bad fuse will only light up the test light on one end of the fuse-the metal strip inside has blown apart.
You can check all your fuses this way-don't have to pull them out to inspect. But also most important for you to know is, does your fuse panel have power being fed to it. If those terminals were battery terminals, you may have blown a bigger fuse that feeds the fuse panel, one of your maxi fuses under the hood in the Power Distribution Box.
Good luck. Post back with what you find.
Sep 13, 2013 | Honda Cars & Trucks
Auxiliary power point does not work check all fuses all good
Did you check both sides of the fuse installed with a meter to a known good ground ? There are 2 or 3 power point fuses ( depending on the cab configuration ).
Engine compartment Fuse # 22 is the cigar lighter
Engine compartment Fuse # 65 is the dash power point
Engine compartment Fuse # 66 is the inside the console power point
Engine compartment Fuse # 72 is the rear power point
Jul 19, 2011 | 2009 Ford F-150
Cig Lighter does not work: Fuse good (power to fuse good) No power to the back of the cig lighter plug can you help?
Is the power going through the fuse?
I have seen fuses that looked ok, but were broken inside.
If power is getting through the fuse, then the power wire must be broken or cut somewhere.
You will have to trace it back to the fuse box, checking along the way with a 12 volt DC testing probe.
Apr 16, 2011 | Ford Mustang Cars & Trucks
Need a diagram of fuse panel on 91 buick park avenue for heater fan
GET A GOOD FUSE TESTER TURN ON IGNITION SWITCH. TEST EVERY FUSE. 2 FUSEBOXES ONE UNDER THE HOOD, ONE INSIDE THE CAR. FUSES CAN BE TESTED WHILE IN THE BOX. FUSES HAVE TEST POINTS FACING OUT. POWER ON ONE SIDE, BAD FUSE, POWER ON BOTH SIDES, GOOD FUSE POWER ON NEITHER SIDE, SPARE FUSE.
Jan 13, 2011 | 1991 Buick Park Avenue
Location of the turning signal fuse
GET A GOOD FUSE TESTER, TEST EVERY FUSE. 2 BOXES ONE UNDER THE HOOD & ONE INSIDE THE VEHICLE. THE FUSES HAVE TEST POINTS FACING OUT. POWER ON ONE SIDE, BAD FUSE POWER ON BOTH SIDES GOOD FUSE, POWER ON NEITHER SIDE, SPARE FUSE.IF THE FUSES TEST OK, YOU MAY HAVE A BAD FLASHER, OR BAD TURN SIGNAL { COMBINATION } SWITCH.
Jan 06, 2011 | Daewoo Lanos Cars & Trucks
No rear signals or brakelights except third brakelight
TURN ON IGNITION SWITCH,GET A GOOD FUSE TESTER, CHECK ALL FUSES INSIDE THE CAR & UNDER THE HOOD. THE FUSES CAN ALL BE CHECKED WHILE STILL IN THE FUSE BOXES THERE ARE TEST POINTS FACING OUT ON EACH FUSE. POWER ON ONE SIDE OF THE FUSE, BAD FUSE. POWER ON BOTH SIDES, GOOD FUSE. NO POWER ON EITHER SIDE , SPARE FUSE.
Jan 05, 2011 | Dodge Pickup Cars & Trucks
Interior dash lights, signal lights and 4 way flashers don't work.
Jan 05, 2011 | Toyota Tacoma Cars & Trucks
AMP DOES NOT POWER UP
if it dont smell blown then make sure your fuses in the amp are good and the fuse to the power is good
Mar 24, 2009 | Kenwood KAC-729S Car Audio Amplifier
Aiwa XC-RW700 2-Disc CD Recorder Logo
99 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
