Question about D-Link DAP1360 IEEE 80211n (draft) Wireless Access Point DAP1360 (DAP1360E) Pre80211n
I just got a dap-1360 and i cant set it up when i type dlinkap or 192.168.0.50 in my URL it keeps sayin webpage cannot be found
    Guru:
  • 610 Answers
Just make sure that you belong with in the same IP range.
default DAP-1360 IP is 192.168.0.50
username : admin password :
change your PC IP address to 192.168.0.xxx (e.g. 192.168.0.2)
from there you may choose wizard or manual configuration.
you may change your DAP-1360 IP add according to your network settings in the office and you must change you PC IP address with in the same range.
Posted on Mar 24, 2011
Configure dap-1360 range extender
I THINK you are asking about a D-LINK dap-1360 range extender IF so see THIS YOUTUBE:
How to Configure Link DAP 1360 Wireless Range Extender
Be SURE to see this:
dap 1360 range extender Google Search
And this one too...
DAP 1360 Configure as repeater
NOT in English but lots in life is not... You can STILL see his setup steps clearly!
Anthony
Apr 17, 2018 | Computers & Internet
Dap 1360
1- first distance between Dap-1360 from the router wifi Nilox should be max the signal length around 50 meter,
2- try to update the Dap-1360 software from the internet then test the network cable again and the electric cable..
hope it help ...
Mar 19, 2014 | Computers & Internet
Bought the D-Link DAP-1360 and my problem is that my laptop does not have a port to take the ethernet cable. How do I set it up nw as a range extender?
You don't need to connect via ethernet. In your laptop set the IP address to 192.168.0.2. subnet 255.255.255.0
This will probably temporarily disconnect you from your internet but you can reset the IP address back later. It might be a good idea to write your current settings down for later.
Open your browser and enter dlinkap or 192.168.0.50
You will connect to the Dlink AP
follow the directions in the user guide found at the link below.
http://global.dlink.com.sg/site_support/DAP-1360/Manual/DAP-1360_Manual_v1.00.pdf
Feb 11, 2014 | D-Link DAP1360 IEEE 80211n (draft)...
Cannot access either dlinkap or 192.168.0.50 via web browser in order to set DAP-1360
Connect your computer to the router.
Assuming Windows 7, click the "Start" button.
Into the search-box, type 'CMD' and press ENTER.
Type 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Nov 24, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
Dap 1320 can't set it up using web browser link
These answers on all these sites are very confusing. Here's what I did to solve the issue of not connecting with a browser. 192.168.0.50 does not work nor does http://dlinkap.local. or whatever else is printed on the device. On my PC that is hard wired to my router, I logged into my router, checked which wireless devices were connected and found that dlinkap (note this is not the SSID that is printed on the device) was assigned 192.168.0.4. Set my browser to 192.168.0.4 and off we go to configure the extender.
Mar 09, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
DAP-1360 won't respond or reset.
Click the Windows 7 "Start" button.
Type 'CMD' into the search-box, and press ENTER.
Type 'IPCONFIG /ALL' and press ENTER.
Jul 31, 2012 | D-Link Wireless N Access Point Dap-1360 -...
I cant get into config my dap1360 by typein in the dlinkap or 192.168.0.50
just make sure that you belong with in the same IP range.
username : admin password : <blank>
Mar 24, 2011 | D-Link DAP1360 IEEE 80211n (draft)...
Cant konfigure router, when i type 192.168.0.50 or
Reset using the button on the back the do an ipconfig - so if you ip is 192.168.1.1 try that to get in to the router
Jul 05, 2010 | D-Link DAP1360 IEEE 80211n (draft)...
Can't open DAP-1150 configuration utility
The DLink URL WEB configuration uses an IP address not //dlinkap
Try http://192.168.0.1
The default ligin = admin
The default PW = blank ie. nothing
Jan 04, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Open Questions:
My WIFI networks starts in my flat (5th floor) with a ALICE router; I've added a TP-LINK range extender, which brings the WIFI signal (by means of a directive antenna) down to the garage gate. The - In my house, distance from main router (ALICE) to first TP-LINK TL-WA730RE extender: 6 m with one wall in the route; - TP-LINK TL-WA730RE extender connected to a directive antenna (on my balcony at 5th floor) which aims to the garage gate (ground level) with no obstacles (air-air) - Signal power measured with a mobile app (MERAKI WIFI STUMBLER) in front of the directive antenna: 65 dB - Signal power measured at the garage gate (ground level): 24 dB - DAP-1360 extender positioned in the garage, 30 cm just behind the gate - DAP-1360 antennas placed at one meter distance one from the other - DAP-1360 right antenna placed on the external garage wall, in front of the directive antenna and one meter from the DAP-1360 extender - DAP-1360 left antenna placed close to the DAP-1360, 30 cm behind the garage gate -WEBCAM DCS-942L placed at 4 meters distance from the DAP-1360, with no obstacles (air-air) WIFI CONNECTION WORKS FOR SECONDS: from a PC I connect to a D-Link WEB SITE and I manage the WEB CAM remotely (need it &#39;cause of thieves problems in the garage). But after less than 3 minutes the connection drops. Apparently the DAP-1360 doesn&#39;t connect anymore to the network...Trust me, I&#39;m goin&#39; crazy and I&#39;m fed up of spending nights in trying all the different configurations...PLEASE HELP!!!! Thanks to everybody
Mar 01, 2017 | D-Link DAP1360 IEEE 80211n (draft)...
See all D-Link DAP1360 IEEE 80211n (draft) Wireless Access Questions
D-Link DAP1360 IEEE 80211n (draft) Wireless Access Point  DAP1360 (DAP1360E) Pre80211n Logo
9,025 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
