Question about Electrolux Dishwashers
My dishwasher will pump water out but wont take it in
    Problem Solver:
  • 10 Answers
Check the over flow float inside. It may be stuck in the up possition. It sould go up and down easy. If thats not the problem you might have a cloage or defective inlet valve. make sure water is off to dishwasher befor removeing the inlet valve.
Posted on Mar 24, 2011
My dishwasher does not fill or empty?
wont fill
sounds like the water intake solenoid
wont pump out
could be timer control board
water pump /solenoid
Nov 10, 2016 | Dishwashers
Dishwasher has water in the bottom
check and be sure you don't have something stuck in the water pump for the drain or else the pump maybe bad and needs replacement. In addition, be sure the pump belt or motor is driving the pump.
Dec 26, 2015 | Frigidaire Dishwashers
FDB251OLCC1 dishwasher wont clean top rack
Possible that the main pump for the spraying system is not working, you will need to check the INLET valve , remove and check if there is flow when the washer is switched to start, if not the inlet valve is faulty as it does not allow water to the pump.
check this link for tips to check the pump;
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Oct 18, 2011 | Dishwashers
Dishwasher wont take in water, inlet valve ok, pump ok
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 10, 2011 | Tricity Bendix Dishwashers
Dishwasher won't fill with water
Check the power supply to the water pump through a pocket electrical line tester or volt meter.
Poer reaches and the pump mot rotating, check the capacitor associated with the motor.
May 27, 2010 | GE Nautilus 24" Built-in Dishwasher
I have an FDF780 dishwasher that wont spray water
Sounds like wash pump is weak or siezed.
Sep 28, 2009 | Dishwashers
Bosch integrated dishwasher water pump wont go off
sounds like the drain pump stays on. take the kickplate off and check for water in the base. if no water then make that little red bar to the left of the watervalve in the base go up and down a few times. you could have a stuck microswitch on the pressure chamber
May 29, 2009 | Bosch 24 in. SGS43C12 Classixx...
My dishwasher wont drain out? any ideas?
Start checking drain hose first.
Check water level switch.
If water level is ok check drain pump lines , and test drain pump.
If everything else is ok, test the control board (uncommon).
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 17, 2009 | Kenmore Dishwashers
Dishwashers Logo
61 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
