Question about Sanyo Televison & Video
Color on my 42 inch sanyo lcd tv is messed up
Highdefjeff
  • 124 Answers
SOURCE: need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Posted on Mar 03, 2009
  • 8457 Answers
SOURCE: Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 02, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: sanyo 42 inch lcd dp42647 - turns on, video audio pulse on off
Need s to be replaced the main board.
Posted on Apr 17, 2010
dvdcdlaser
  • 1285 Answers
SOURCE: how do i hook up external speakers to my sanyo
if there are jacks in the back of your sanyo you can hook up 2 speakers if your sanyo do not have external audio RCA jacks for speakers...you will need a home entertainment receiver to hook up the 2 -7 speakers...
Posted on Jun 21, 2010
mpaint
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
How much does picture tube for 42 inch flat screen Sanyo TV cost
There is no picture tube in a modern flat screen TV.
And unless it's physically broken, it's usually something else that has failed and not the screen.
A picture tube is a CRT (cathode ray tube) that sends electrons from the back to the front to light up different color phosphorous dots.
A modern flat screen TV on the other hand is LCD (liquid crystal display) that turns on and off to allow backlighting through multi colored filters. (LED TV also uses a LCD screen, the only difference is the backlighting is LED and not fluorescent lamps.)
Nov 26, 2016 | Sanyo Televison & Video
IS THERE A REPLACEMENT BULB IN THE 42' SANYO FLAT SCREEN TV
There is no bulb, likely an LED with RG colors. You need to get the right LED part number and replace it yourself if you are handy with a soldering iron.
Jun 25, 2014 | Sanyo 42 in. LCD TV
42 inch sanyo lcd tv shut down now it turns on for about 30seconds turns right back off
Get the model number and chassis version from the label at the back of the TV and try this:
http://www.coppelltvrepair.com/Diagnose/
Alternatively check out this:
http://www.coppelltvrepair.com/productag/597/sanyo
Given the information you supply here this is just the best I can do.
Mar 25, 2013 | Sanyo 42 in. LCD TV
Sanyo 2008 flat screen 42 inch no picture have sound
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 26, 2012 | Sanyo 42K40 42 inch Multi-System LCD TV
Sanyo 42 inch tv model number dp47460 turns off after a half hour
Hello
Check its power regulator board's soldering points for any loose solderings. Resolder all the suspected solder points by applying a little more solder.
Mar 05, 2012 | Sanyo 42 in. LCD TV
My Sanyo 42" flat screen
There is a problem with the board of your television.That problem is in vertical section, theres a leak capacitor at the vertical section of the board.Its better to replace all the leak capacitor to make the picture back to normal appearance.If you can't do the repair or replacement of of capacitor try,Call a repair technician to do the repair or troubleshooting..Thanks..
Aug 25, 2011 | Sanyo 42 in. LCD TV
I have a Sanyo 42 inch Mode Number: DP42647. I bought it 2.5 years ago, and suddenly, the video is out. The sound is ok, as well as the "power" green LED. By looking at other forums, it seems...
I would just replace the TV, because any guess you make without the testing and equipment is just an expensive guess. New TV's are cheap by comparison. I have had a lot of TV'ds and the best do far is my Vizio 42 Inch LCD. 11 years old no issues.
May 20, 2017 | Sanyo 42 in. LCD TV
Televison & Video Logo
63 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
